Rustines Campy style hoods on Universal 68 levers
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
Like others on this forum, I was curious if the Rustines campy style hoods would fit Universal 77 brake levers. I chose to take the plunge and find out for myself.
Do they fit? Kind of. The hoods fit the body shape well, but the trouble comes with the large brake cable housing stops on top.
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
Lever without housing stop installed.
Lever with housing stop installed
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
Here is what I chose to do.
1) Trim the top off of the brand new beautiful hoods with a razor. I didn’t use a really sharp razor, so my cuts looked terrible. Someone with more patience and better planning could do better.
2) Burn the top cut to melt the rubber and smooth the cuts with a flat head screwdriver.
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
Terrible cut!
3, 2, 1, ignition!
Not perfect, but good enough for me.
Likes For mkeller234:
Quoted: 1372 Post(s)
Liked 1,751 Times
I tried something similar with little acceptable success. I never thought of the "ignition" method. Well done!
Quoted: 556 Post(s)
Liked 132 Times
Reading this thread left me scratching my head a bit. Nice adaptation, MK.
But if the Campy style hoods sort of fit your levers I suspect they aren't really Super 68 model levers.
Which looked like this. Rustines makes replacement hoods for those as I remember.
But more likely style 77 or 125 levers.
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
Nice job, I still like the floor!
Best, Ben
Voltaire
Voltaire
Likes For xiaoman1:
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
You are correct Scott. Can a mod change the title to universal 77?
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
OMG, you did that indoors!
Must have smelled terrible!
Results not bad!
Results not bad!
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
Thanks. I think I found my new back drop. I’ve lived here for years, I don’t know why I never took pictures of bikes down there before.
Yes, it smelled really bad. I’d recommend doing this outside.
Quoted: 3811 Post(s)
Liked 3,338 Times
Great job; thanks very much for posting!
The Super 68 brakeset comes with lever model Nr. 306.
