Can't get BB off, but its weird :|
Old 09-30-19, 08:34 AM
chico1st
30mi/day commuter
Quoted: 5 Post(s)
Hi there quick question about removing this bottom bracket.
Someone gave me an old super cycle which is in perfect shape except it has a loose cartridge bottom bracket (I have the cranks off and the spindles flop everywhere).
I can't get the cups off and I just wanted to check some stuff before I destroy my tools:
  • Everything on the bike is shimano so I assume the non-drive side cup needs to be turned clockwise to loosen it, drive side is counter clockwise.
  • I need to use a bottom bracket tool AND a 20spline tool (I have a BBT32) to remove the drive side pictured below
  • The splines on my bbt32 don't engage that deep (maybe 1mm). Is that normal?
  • The BBT32 kind of pops out when I push really hard but there isn't a good way to force it to stay inside the teeth
  • tightening or replacing the cartridge should solve the issue.
Images
chico1st is offline
Old 09-30-19, 08:41 AM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times in 422 Posts
Images
Are you sure?
Take off the lock ring first.
https://www.sheldonbrown.com/gloss_bo-z.html#bottom
trailangel is offline
Old 09-30-19, 10:29 AM
Dan Burkhart
Senior member
Dan Burkhart's Avatar
Quoted: 942 Post(s)
Liked 656 Times in 370 Posts
Images
Actually, the loosening direction is opposite to that. It is the drive side that is reverse threaded.
I have a tool that holds the BB tool in place for removal and installation, but there are hacks that you can use to do it without the tool. We just had a thread on that here recently.
Dan Burkhart is offline
Old 09-30-19, 03:24 PM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 1173 Post(s)
Liked 927 Times in 612 Posts
Moved from General
Homebrew01 is offline
Old 09-30-19, 06:03 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1787 Post(s)
Liked 1,261 Times in 870 Posts
Like this-
Bill Kapaun is offline
Likes For Bill Kapaun:
Old 09-30-19, 08:45 PM
chico1st
30mi/day commuter
Quoted: 5 Post(s)
Originally Posted by Bill Kapaun
Like this-
Oooo right on. OK that problem is annoying enough that I will wander around looking for some washers before I try this again
Thanks for the tip!
chico1st is offline
Old 09-30-19, 08:50 PM
Bigbus
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times in 244 Posts
That's ingenious Bill. I would have just found a larger hammer...
Bigbus is offline
Old 09-30-19, 08:57 PM
Bill Kapaun
Thanks for the tip!
Keep in mind the bolts are 8x1.0mm, not the more common 8x1.25mm.
Take a crank bolt with you when shopping. Sometimes a crank bolt will work, depending on which tool you have & spindle length.
With 2-3 bolts & a "few" 3/8" (or 8mm) washers, you can cover any length spindle. (or 1 really long bolt & a lot of washers.
Old 09-30-19, 08:59 PM
Bill Kapaun
Then "Like" it and make me famous.....
Old 09-30-19, 09:04 PM
Bigbus
Very Senior Member
Quoted: 413 Post(s)
Are we happy now?
Bigbus is offline
Old 09-30-19, 09:22 PM
Bill Kapaun
Are we happy now?
My mother would be proud!
Old 09-30-19, 10:27 PM
WizardOfBoz
Generally bewildered
WizardOfBoz's Avatar
Quoted: 1152 Post(s)
Liked 341 Times in 251 Posts
Bill's idea is a great one. The first law of BB removal though, is "Thou shalt maketh sureth that one knoweth the thread direction".
As a bit of practical advice, once you get your tool threaded onto the spindle, you can put the tool flats in a vice and use the frame as a wrench. Often easier.
WizardOfBoz is offline
Likes For WizardOfBoz:
Old 10-01-19, 01:02 AM
cpach
Bikes: Too many. Giant Trance X 29, Surly Midnight Special get the most time.
Quoted: 532 Post(s)
Liked 312 Times in 236 Posts
It's pretty normal to have a challenging time keeping the splines engaged on the BB tool. The above suggestion is good, you can also just put a big clamp over it all also.
cpach is offline
Old 10-01-19, 10:52 AM
sch
Quoted: 303 Post(s)
Liked 136 Times in 104 Posts
Reminded me of an attempt ~yr 2000 to remove a freewheel from a rear hub in place since ~1974. Used a vice to clamp the FW remover and grabbed the rims and
after carefully checking which direction to turn the wheel proceeded to shear off the prongs on the FW remover and permanently cant the FW body on the threads,
such that the FW would barely turn. Probably turned the wheel the wrong way, or the FW was really stuck. Still have the wheel as a memento.
sch is offline
Old 10-01-19, 10:58 AM
WizardOfBoz
Golly, sch, nothing like that EVER happened to me...
I mean, I got all my wisdom from seeing OTHER people make mistakes.
_____________________________________
Experience is mistakes repeated many times....
Old 10-01-19, 11:01 AM
Bill Kapaun
You don't need a vise to break prongs on a Sun Tour remover.
Old 10-01-19, 11:18 AM
79pmooney
79pmooney's Avatar
Quoted: 4791 Post(s)
Liked 3,918 Times in 2,548 Posts
That was my standard practice with my old UO-8 (except the DS cup had flats, not the splines). I'd hang the frame from the ceiling, grab the cup flats in the vice and turn (both to install and remove). French threads, ie self-loosening if they were not very tight. Quite and operation.
79pmooney is online now
Old 10-01-19, 11:43 AM
B.C.Bikes
Bikes: Cinelli Nemo TIG w/ Campy S.R., Cotic BFE, Brompton, Pashley Unicycle, Sunday BMX, plenty of old and vintage bits and bobs.
Leverage is your friend. A big bar or extender from a spanner or socket drive will help enormously. A bit of penetrating fluid on the joints might be of use also.
B.C.Bikes is offline
Old 10-02-19, 07:57 AM
HillRider
Quoted: 2026 Post(s)
Liked 1,095 Times in 741 Posts
A variation is: "Good judgement comes from experience. Experience comes from poor judgement".
HillRider is offline
Likes For HillRider:
Old 10-02-19, 08:04 AM
Dan Burkhart
Senior member
Quoted: 942 Post(s)
My motto right there.
Old 10-02-19, 09:02 AM
the sci guy
bill nyecycles
the sci guy's Avatar
Quoted: 789 Post(s)
Liked 350 Times in 190 Posts
Love this. Definitely applicable in my diy bike work.
the sci guy is offline
Old 10-02-19, 10:16 AM
thumpism
Bikes are okay, I guess.
thumpism's Avatar
Quoted: 2647 Post(s)
Another wise man once said, "He don't know nothin' cause he never done nothin'."
thumpism is offline
Likes For thumpism:
Old 10-02-19, 12:49 PM
dabac
Quoted: 1074 Post(s)
Liked 295 Times in 222 Posts
+1
Back when I still had to think about it, my ”clue” was that with the wheels on the ground, and gravity as your helper, the wrench should point to the rear for loosening pedals, and forward for loosening BBs.
I’ve looked a bit for a long enough bolt with the right thread, but so far I’ve settled for a big C-clamp.
dabac is offline
Old 10-02-19, 12:55 PM
WizardOfBoz
Aha. I should be gaining experience at a record rate, then.
Old 10-02-19, 01:02 PM
Bill Kapaun
Originally Posted by dabac
.......I’ve looked a bit for a long enough bolt with the right thread, but so far I’ve settled for a big C-clamp.
8X1.0mm. I got mine at an an "older style" auto parts store with a good fastener selection.
The more common size is 8x1.25mm.
