Headset question
Quoted: 68 Post(s)
Headset question
is it bad to fully tighten the top cap once the stem is adjusted and the bolts are tight? It wouldn't be pressing down on the headset so why not?
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
If you have a lock ring in between the 2 nuts there shouldn't be a problem as loons you use one wrench to hold the bottom cup so it does not move while tightening the top nut....all should be fine. Yes, you need to lock the headset.
edit
If threadless what others have said.
Ben
edit
Ben
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
I assume this is the top cap on a threadless headset you are inquiring about. Once the stem bolts have been tightened after preloading the headset bearing tension, the top cap tension is no longer in play, and can even be removed if you want. Why would you want to excessively tighten the cap bolt, however?
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,219 Times
As others have said, it's not something to worry about once the threadless headset is adjusted. That said, you can damage the top cap if you put too much torque on it. I've seen people pull the bolt out of the middle of the top cap while trying to adjust the headset with the stem still tight on the steer tube. On the positive side, top caps are cheap but breaking one is embarrassing.
Stuart Black
Stuart Black
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
The compression plug that the top cap bolt screws into is held in pace by friction. Torquing the top cap bolt too much will pull out the compression plug.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
That's kind of bass ackwards. You tighten the top cap to get the right preload, then tighten (using a torque wrench) the stem bolts. I'd leave the cap setting as is. Removing it exposes the threads to the elements and leaves the possibly rough edge of the fork tube exposed.
There is no advantage in tightening the cap once the stem bolts are in place.
There are minimal advantages and some significant disadvantages to removing the cap.
But aggiegrads asked the right question: what do you hope to accomplish by tightening the cap screw?
Quoted: 68 Post(s)
Ok, I thought the top cap also provided some security for the stem because it's pressing down on it. Apparently it doesn't matter if it's completely removed.
Liked 4,219 Times
But, as with a star fangled nut, once the stem is tightened, the compression plug and top cap serves no purpose.
Stuart Black
Stuart Black
climber has-been
Liked 3,567 Times
An annoyance that is completely avoidable by using the compression plug the way it was intended.
