I never liked frame ID posts, now I have one of my own.
2k miles from the midwest
Quoted: 525 Post(s)
Liked 930 Times
I'm thinking it should be fairly easy with the wrap-around seatcluster. Dropouts are campy, as are the braze on bb guides. English thread. Stamping on BB shell is 37448 and < E O >. Brazing on the canti mounts is pretty good, I can't decide for sure if they were added later, hence the repaint. I was wondering if Rodriguez or Davidson ever did that stay treatment, since I'm in the PNW.
Quoted: 4482 Post(s)
Liked 6,257 Times
No expert, probably way off but looks Holdsworthy to me.
Quoted: 3766 Post(s)
Liked 3,256 Times
Chainstay stop incorrect for a Holdsworthy product. Of course, it, toegether with top tube cable guides, w/b & cantis could have easily been mounted post manufacture & prior to the current respray...
Chainstay dimpling appears performed, at least partially, by builder. Looks as though done with a hammer.
Suggests a small scale operation.
We need to hear from @MauriceMoss - he shall know the significance of the E O marking.
Quoted: 963 Post(s)
Liked 1,447 Times
Picture from the Norman Kilgariff website, on which you can find all the Claud Butler and Holdsworth info.
I can't say for the quasi-wrapped seatstays, but the cable stops/guides and the seat stay bridge scream Holdsworth to me. It's probably from after they stopped using those Prugnat Type I lugs with the points on the sides of the head tube.
PM me your cotters
Quoted: 1137 Post(s)
Liked 588 Times
Someone thinned the lugs, which is a nice touch. I suspect the TT cable guides and canti braze ons are after the fact. The seat stay caps are reminiscent of Gitane's higher-end frames, but the brake bridge is higher quality and threading isn't correct. I'm guessing this was originally made in the 70s, maybe add-ons applied in the 80s?
Edumacator
Quoted: 2374 Post(s)
Liked 2,896 Times
Semi-sloping crown with the wrap around thick stays...and as FP says above, thinned lugwork. barrel brake bridge...hmm. Not ornate enough for Harry Quinn...was going to go Claude Butler as above? British Eagle? Bob Jackson?
Quoted: 4719 Post(s)
Liked 3,034 Times
<EO> is the trademark of Otsuya Iron Works, a Japanese company specializing in frame fittings, such as bottom bracket shells.
looks a lot like this holdsworth mistral:
New Old Stock 1980 Holdsworth Mistral Touring Frameset at Yellow Jersey
