Removing valve core on mounted tubular
Any suggestions on how I would remove the valve core of a tubular tire that is mounted on a 50mm rim. I want to change the valve extender to the type that has a valve core, but my valve core removal tool doesn't fit inside the valve hole on the wheel.
Quoted: 1438 Post(s)
Liked 1,092 Times
Something like this should do it: https://smile.amazon.com/VTR-Valve-C.../dp/B07997ZL1N
Quoted: 4197 Post(s)
Liked 3,849 Times
Every tubular tire I've seen for decades uses a Presta valve. The imaged tool is for a Schrader valve.
The OP's question is one more reason to not use stupid deep rims Really, with sew ups any valve work is best done when unmounted. If you can't afford to do this then maybe sew ups are not the best choice. Andy
AndrewRStewart
AndrewRStewart
Quoted: 2952 Post(s)
Liked 3,106 Times
Liked 3,849 Times
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Liked 3,106 Times
Quoted: 1814 Post(s)
Liked 923 Times
The typical 30mm stem will be 20mm inside the rim.
Even if the valve core was removed, there's a good chance that the new valve extender wouldn't seal well without tightening the two parts against each other,
and it could be hard to even get the extender started- I've had that problem when one of those (stupid) Vittoria replaceable stems came loose.
Quoted: 2337 Post(s)
Liked 2,820 Times
ok.... OT sorta, but if you can't get at the valve to remove the presta core, how the heck do you pump up the tire???? this is bugging me
Senior member
Quoted: 943 Post(s)
Liked 658 Times
At the last shop I worked at, we saw lots of deep profile tubulars that used both types.
Liked 2,820 Times
When this type of extender is used, the valve is left in the open position before it's installed. The pressure in the tire keeps it closed. You have to pump it with enough pressure to crack the valve open to inflate it. I think the OP wants to swap it out for the type that has the valve on the end of the extender.
