Asian Serial Number Guide
#301
Hi everyone! New here and wanted to ask what if the serial number on a frame doesn't match the current format? Would anyone have knowledge on this to help identify the frame I have.
The serial number is WAK22140T (located underside of the crank).
Other clues:
*Too new a member to post pictures right now but happy to provide more information if I'm directed where to get it. Thanks for your help in advanced!!
Other clues:
- "Made in Japan" sticker on seat tube;
- "SunTour" and "SUPERBE" on rear derailleurs.
#302
Quoted: 4722 Post(s)
Liked 3,036 Times
Other clues:
Other clues:
The WAK-prefix indicates a bicycle imported in Denmark by Age Kroll, while the T-suffix, in conjunction with Superbe, would indicate 1980. Age Kroll was the Danish importer for Centurion, so that should be the brand. Assuming the Superbe is OEM, my leading candidate would be a Centurion Professional. Photographs?
#303
#304
Again thanks so much Mr T-Mar! I’ve read a few of your articles and really amazing you’re able to compile that wealth of knowledge.
I think my question can be worded better. As in what indicators in the 4 alphas (and or numbers) helped you determine the make and model?
#305
Crank
Head tube
Head tube 2
Full
Seat stay
Seat post
Serial number
Rear derailleur
Rear derailleur 2
#306
Liked 3,036 Times
The frame features definitely fit the 1980 era but my impression of the frame workmanship is not so favourable. The tangs on the rear brake would normally be indicative of a high end model, the chrome stay caps are a nice touch and the tubeset looks lightweight. However, the stay end treatments and BB shell are not what I would expect on a higher end model. In fact I'd say the stay end treatments are disappointing even for mid-range, though I doubt it's lower than that.
Likes For T-Mar:
#307
Hi T-Mar, your assessment is definitely spot on! Tube set is very very light. To the untrained eye I see what you mean about the tangs and workman ship.
Thank you so much for helping me identify it! The knowledge you’ve been able to compile on Centurion serial numbers is fully appreciated!!
#309
Quoted: 420 Post(s)
Liked 379 Times
According to the OP, my Maruishi serial number should start with a letter (although I see this is somewhat uncertain)... but it is all numbers. It is an early-80s bike, based on what the person I bought it from told me. Any ideas?
(I've found two other references on the forum thus far to Maruishi bikes with a 6-number serial instead of two-letter-five-number, but not much info. One of those posts has a reply saying it should have letters but no reply after that from the person who posted the number; the other has the serial mentioned in the OP but no one comments on it.)
#310
Liked 3,036 Times
#311
Quoted: 420 Post(s)
Liked 379 Times
It's a women's-frame Eagle Ace... I can't find much or anything about that model, but it wouldn't surprise me if it was lower-level.
#312
Liked 3,036 Times
Its entry level, near or at the bottom of the line, based on the stamped dropouts, brake safety levers, stem mounted shift levers, nutted hubs and the several components. It's also appears to be no earlier than 1980s based on the aero crankarms and is probably early 1980s but the non-drive side photos complicate narrowing down the date range.
I don't believe this to be an actual Maruishi but a Maruishi owned Eagle Ace brand. Even on the ladies' models, the Maruishi brand name was placed on the down tube, whereas this one has Eagle Ace in that location. This is further supported by the large Eagle and 'E' on the head badge, which I haven't seen on any actual Maruishi brand bicycles.
There is a label at the bottom of the seat tube, which may indicate the country of origin. If it's other than Japan, that would confirm a contract manufactured bicycle.
#313
Quoted: 420 Post(s)
Liked 379 Times
I had wondered about the logo as well, considering that everything I read about Maruishi talks about kangaroos and this has nary a marsupial anywhere. (That is the only place it says "Maruishi," as well.) Unfortunately, Google nets absolutely nothing, so I'm unlikely to ever know much.
#314
Eccentric Old Man
Quoted: 248 Post(s)
Liked 173 Times
It's is a Ross but no model name on the bike.
Serial # RKG6F52162. Has a made in Taiwan sticker.
Shimano date codes are KB,KC,KD. BB spindle is 86C.
Brake Levers Shimano BR-AT50
Shifters Shimano SL-MT30
Seatpost 26.6 Chrome pin style
Crank Set Sugino VP 170 mm 48-38-28
Pedals VP-747
Front Derailleur Shimano FD-Z204
Rear Derailleur Shimano RD-L522
Freewheel Shimano MF-Z012 14-17-21-26-32
TIA
Pedals VP-747
TIA
#315
Liked 3,036 Times
#317
Liked 3,036 Times
Umm, yes and no. The Taiwanese Ross bicycles are an interesting story. According to an article in a industry trade magazine, Ross didn't have the bicycles contract manufactured in the traditional manner. Rather, according to article, they leased a Taiwanese factory. Unfortunately, it doesn't mention the factory by name and to what extent Ross personnel were involved at the factory. However, Ross set up a new entity, Ross Imports Division, which included the leased factory operations, so technically they were manufactured by Ross. It would also explain why the serial number format appears to be Ross specific with the 'R' prefix.
#318
GDFTR
Bikes: '74 Falcon San Remo, '80 SR Semi Pro, '88 Trek 360, '18 Fairdale Goodship
Quoted: 51 Post(s)
Liked 82 Times
Unable to figure this out so need some help. SR Semi Pro I was told 1982 by the seller... MOD20122
#319
Hi, can you help me id this frame? SN: SFL002715. There is a weird character before the SN. Looks like a small letter i or L.
Pic: bikeforums.net/g/picture/20132556
#320
Liked 3,036 Times
The 2nd character is almost certainly the number "zero", as opposed to the letter "oh". That would make it a 1980 model. The format is consistent is Miki, a known contractor for SR brand bicycles.
Likes For T-Mar:
#321
Liked 3,036 Times
#322
GDFTR
Quoted: 51 Post(s)
Liked 82 Times
thank you T-Mar! There is another one in the same color locally that’s on OfferUp and says it’s an 82 but the frame has a shorter wheelbase and adjuster screws on the rear dropouts. It’s not nearly as clean with quite a bit of patina, but has the complete arabesque group and I have thought about getting it and selling this one. Although this one looks like a 1 year old bike, not flawless but really nice.
#323
Welcome to the forums. Sorry, I don't recognize the serial number format. It appears to be an aluminum, TIG welded frame but that's about all I can say from the single picture provided. If you can provide pictures of the overall bicycle along with some picture of the major components (derailleurs, crankset, brakes), we may at least be able to narrow down the age, even if we can't identify the manufacturer or brand.
#325
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3884 Post(s)
Liked 6,478 Times
^ I knew that guy wasn't human!
