Hope RX4 Discs Not Warranted For Tandem Use
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 463 Post(s)
Liked 546 Times
Glad to hear that the RX4 calipers seem to be working. My issues with Hope's E4 brakes showed up when I was making a panic stop from 45 MPH on a steep hill with a very strong tail wind. I suspect that there is probably more than a slight difference between your full up weight and the close to 500 pounds we, the bike, and our luggage weighed at the time.
Used to be Conspiratemus
Quoted: 297 Post(s)
Liked 245 Times
Rained out from Hurricane Delta this weekend. So didn’t do the ride with the long descent.
Today however did a 1000 foot vertical descent and tried to really abuse the brakes.
On a descent that we’d normally do 35-40 miles an hour, I dragged the brakes continuously and kept the speed around 10-15mph, and pedaled to add to the load on the brakes.
After a full 5 minutes of dragging the brakes, there was no fade, no odor, no change in the brake lever feel or travel, and when I did let it run at the steepest portion just at the end, we were able to stop quickly from 40mph or so.
I’m not sure this answers how well the brakes will do on a very long technical descent. However, the fact they stood up well to this intentional abuse makes me pretty confident.
Just to confirm the experience of a few others in this post:
Saint 4-piston front and rear with full metallic/sintered shimano pads
ST-R785 brifters
Magura "MDR-P" E-bike floating 203 discs
Best combination of braking I have experienced in 20 years, including long downhills with constant brake application. Even after 10 minutes of dragging the brakes, the stopping power at the bottom of hill is excellent.
additionally, the e-bike floating rotors do not warp significantly and only rub lightly and for a minute or so after heavy use.
ST-R785 brifters
Likes For Msteven:
ST-R785 brifters
ST-R785 brifters
Good to see the new Magura discs being put to the test on a tandem. I have not seen them being used on a tandem before.
It's also interesting to see that the Saint calipers work with the ST-R785 STI's. The fact that they seem to work well with the 8000, 7000 and the 785 STI's indicates that they use the same/ a similar piston design.
It would be cool if the upcoming 12 speed STI's remain compatible with the SAINT calipers. That would make a really sweet, electronic 2x 12 wide gear range setup of STIs combined with a XT/ XTR derailleur.
Magura rotors
Msteven Did you consider using the 220 mm version of that rotor? Or did you lack the clearance for it?
Regarding the 2x12. we currently run a 3x11 XTR system. what is imperfect with this is the road chainring c-c dimension does not match the XT(R) chainring c-c dimension, so dropping from the center ring to low ring has to happen under zero load. The road center ring is a couple of mm right of center compared to the mountain bike center ring. A 2x12 would be interesting, a 50/34 and 10-50 12s would be similar ratios to our 52-39-30 and 11-42.
Bikes: Cannondale tandems: '92 Road, '97 Mtn. Mongoose 10.9 Ti, Kelly Deluxe, Tommaso Chorus, Cdale MT2000, Schwinn Deluxe Cruiser, Torker Unicycle, among others.
Quoted: 276 Post(s)
Liked 201 Times
”Seem” is not “does”. Physics is an experimental science. Conjectures can be tested. (Which is why physicists sometimes mock the merely observational disciplines as mere stamp collecting (attributed to Rutherford whose own Nobel was in Chemistry, not Physics, likely because the Nobel committee didn’t fully grasp what he had accomplished in transmutation.)
So, people who tout new brakes need to show that they do resist heat fade during sustained use to ******** speed on a long hill. Thorn in the U.K. and Santana in the U.S. do this in selecting brakes for their tandems. (I have no connection with either company. I do own an old Santana, with rim brakes.)
Here’s the scenario I worry about. You have a familiar long descent with hairpins connected by tangents. Conventional technique is to coast as fast as you dare in the straights, brake hard for the bends, then use the higher speed in the following straight to let the brakes cool. Fancy stuff on the brakes ought to let them cool faster when they aren’t being used, sure, so you reach the bottom under control and able to stop at the intersection. Especially with some practice on it.
Now, suppose you have to follow a loaded coal truck or a camper caravan down that hill much slower than you can coast and you can’t pass. So you are using the brakes in the tangents, too. Will their little fins be able to dissipate heat under continuous use, plus going even slower in the bends? Show me that they can. We have descended some truly scary paved roads in Europe where we really did have to brake the whole way down and stopped frequently to allow brakes, of various designs over the years, to cool. And I’m not including the marquee mountains and cols like Ventoux and Tourmalet, which don’t require continuous braking. Some narrow twisting little road in the Dolomites can be scary challenging if the bends come right on top of each other.
Thing is, as tandem teams get heavier, they become less willing and able to climb up into the high country to find these descents, so their expectations of brakes are diminished. They regard quick two-finger stopping from the hoods as an adequate test. Then they turn their tandem into an electric motorcycle and discover that they’ve still got plain old crappy bicycle brakes intended to help an ectomorphic bike racer get through a hairpin, not brakes that the loaded coal truck needs.
Well, let's see. You get behind the hypothetical coal truck and realize your options:
1) Pass the truck and continue your descent as normal.
2) Pull over and wait for the dangerous condition(s) to pass.
Why on earth would you, on a loaded tandem, knowing what you know about tandems and brakes, then choose to ride your brakes behind said coal truck until your hydraulic fluid boils and your brakes fail? Would you ride the brakes down a hill in a car under the same circumstances?
If so, your problem is not your brakes, but your inability to use them, lack of braking knowledge, and inability change behavior based on current conditions. This does, however, place a higher burden on the riders to know the pitfalls of tandem braking on extended descents. Should the consumer be expected to have a higher level of proficiency? I guess only the lawsuits and courts will decide.
I find it rather funny that this issue is under such heated debate with a "new, really awesome technology" that replaces the tried and true drag brake. Sometimes we don't evolve after all.
PS Ha, ha! Spot the pun!
pan y agua
Quoted: 1441 Post(s)
Liked 710 Times
We’ve now had the chance to ride the bike in the Appalachians in NC for the better part of a year. The descents are not hugely long, rarely more than 1500 foot drop, but often steep(15-20% grade) and twisty.
We’ve experienced no brake fade or overheating issues. We do tend to descend fast, only breaking for corners, but for us, the RX4’s appear to be more than adequate.
You could get lost and die.
You could hit a tree and die.
Likes For merlinextraligh:
hi merinextralight
may i ask what rotors and pads you use ?
our tandem is set up similar to yours, although with a titanium frame (cycleschinook)
we use the red pads for the front and the blue ones for the rear brake combined with 180 mm swisstop rotors;
last weekend we had to descend 10km/1000m on a fireroad, so i had to brake all the way (took us 25 minutes)–there was enough braking power, no fading ;
for the road setup we use shimano xt rotors, which are fine, but from feel i prefer the swisstop ones
thanks andreas
thanks andreas
hi merinextralight
thanks andreas
thanks andreas
pan y agua
Liked 710 Times
We’re still using the original Pads that came from Hope.
the rotors are Shmino XT 203’s
Bikes: 1984 homemade 531SL road bike; 1988 Ritchey TimberComp; 1997 Nashbar tandem; 1998 Kona Explosif; Specialized Epic, Scott CR1 Pro; Salsa Beargrease; Curtlo custom Tandem, Curtlo custom S3 steel gravel bike.
Quoted: 67 Post(s)
Liked 49 Times
I have ST-R785 di2 brifters and BR-R785 calipers with 203 rotors on our new tandem. Rode a short but steep downhill yesterday and before the bottom the brakes were making all kinds of noise which stopped quickly once I stopped braking. I'm assuming this was from the caliper heating and then touching the rotor, but it also could have been the rotor heating, warping slightly when hot, and then straightening with cooling. Never had this problem on our old tandem running Magura MT6 calipers (which are 2-piston)
Either way, I'm thinking I should go to a 4-piston caliper and Shimano Saint or Zee sound like a good option, and upthread it sounds like this should work. My question is related to Shimano and their 2 different brake hoses. The lever-caliper combo came with BH59 hose with a banjo, and the Saint brakes use BH90 hose. So do I need to change out all of the brake hose, or can I just swap the caliper with the existing banjo?
I have ST-R785 di2 brifters and BR-R785 calipers with 203 rotors on our new tandem. ... Either way, I'm thinking I should go to a 4-piston caliper and Shimano Saint or Zee sound like a good option, and upthread it sounds like this should work. My question is related to Shimano and their 2 different brake hoses. The lever-caliper combo came with BH59 hose with a banjo, and the Saint brakes use BH90 hose. So do I need to change out all of the brake hose, or can I just swap the caliper with the existing banjo?
https://www.ticycles.com/components/...e-line-coupler
Quoted: 67 Post(s)
Liked 49 Times
Thanks - good to know this works. I suspect the BH59 banjo will work but if not this sounds like an easy solution.
Quoted: 67 Post(s)
Liked 49 Times
Brake update - Shimano Zee calipers replacing the BR-R785 calipers worked as a straight swap. The banjo is apparently the same across brakes and hoses.
For some reason, though, Shimano does not include a banjo bolt with the brake caliper. That just makes no sense since Shimano has several different banjo bolts, so you'd think they would include the right one with the caliper. Had to order the bolt separately.
Even 220 rotors with 4 pot brakes get too hot on singletrack downhills if you do not stop to let the brakes cool down. Rotors bent, pads glaze, hoses can melt. I use an extra magura hs33 in the rear with andra vbrake rim. This helps to dissipate heat better.
pan y agua
Liked 710 Times
Xt +xtr ice tech rotors are not up for tandem mountain use. The alu between the rotor melts at high temperatures. Seen myself on halfbikes on 2000 altimeter single track descent. The heavier the rotors the better.
I think the answer for any particular team is going to depend on a number of factors, not the least of which is how fast you descend.
Bikes: Schwinn, Nishiki, Santana, Trek, Rodriguez
Quoted: 189 Post(s)
Liked 106 Times
They're not unsafe if you keep in mind their limits. Same goes for tubeless. With rim brakes I had inner tyres that melted. With inner tyres I had tyre ventiles ripped of(even with a lot of talkum powder). I regularly brake tandem chains. In the mean time I recognize the sound the chain makes before breaking. And no, chainbreak was not caused by shifting mistakes. Brake pads sometimes not even last 1000 km. Rotors have to be changed more frequent. Cassettes and chains wear twice as fast. Same for fork bushings. Tyre carcasses are not stiff enough. Inherent to riding tandem. A tandem needs more attention. Special parts for tandems? Not a lot.. Luckily bike industrie is interested much more in Ebikes. A lot of developments there are very useful for tandems also. eg wheels up to 180kg max weight., tyres etc.
Likes For longpete:
pan y agua
Liked 710 Times
Again someone says in previous comment that even special bimetal disks melts under conditions that a drum would take without a problem. Of course it depends on total weight and "a number of factors" but most people just want to know that they are ALWAYS safe going downhill. Both rim and new age "disc" brakes use a caliper, the same physics, but the heat capacity of new age disc is mediocre, perhaps comparable if using a heavy downhill mtb disc, and even then as the previous comment states "ice tech rotors are not up for tandem mountain use". Advances in brake tech have not been safe for tandems, saying or even hinting otherwise is misleading. Perhaps your team is light weight and needs to do the race thing, good for you. We are not heavy for our height, but overall heavy, and under tour conditions, just heavy. "Disc" brakes are unsafe and everyone should just ignore the bike industry banter otherwise.
So if you want a brake that you can drag down a mountain continuously at 15 mph, drums are likely your best answer. That in no way means that disc brakes can’t be safely used on a tandem. Worst case scenario,if you’re paying attention at all, is stop for the brakes to cool for a few minutes. That said, riding steep twisty descents in the Appalachia’s we’ve never had to do that.
As a separate datapoint, a local team recently returned from a multi-month tour of Mexico and Central America. They toured on a full suspension Ventana while carrying a light touring load. Both riders are light and fit. The local roads and glorified cow paths frequently had grades of 20+%. They consumed countless brake pads and a set of rotors, but had not a hint of brake failure.
My personal experience is we had at least two non-catastrophic tire failures due to heating with rim brakes. Since switching to disks on the new Co-Motion this issue has disappeared. YMMV.
Likes For diabloridr:
pan y agua
Liked 710 Times
So I have to give an update, and a bit of a disclaimer to my previous comments. After two years of use, I needed to replace the brake pads on the Hopes. When I went to do it, the pistons just would not retract, even trying to force them back. According to the mechanic the seals on the pistons were shot, leading to contamination and the problem. So they either needed to be completely rebuilt or replaced.
Given that we needed the bike for a planned multi day gravel tour, and the unavailability of replacement Hopes in the needed time, we ended up going with Shimano XT brakes
the XT’s are working ok. When I was discussing options with The Calfee rep they said they are currently spacing tandems with 2 pot Shimano mountain bike brakes without issue.
I’ll likely put Hopes back on eventually. Compared to XT’s, the Hopes modulate better, and take less hand pressure for the same stopping power. And while the Hope’s died an early death, they never failed in the sense of failing to stop the bike.
Obvioulsy the higher heat load from the Tandem contributed to the Hope’s demiise. However, the Calfee rep and the LBS both thought that my delay in replacing the original pads, and having never re bled the brakes contributed to their failure
Given that the Hope’s meet all our needs, and work with our setup, If I can do a bit better than the two years next time with some better maintenance, I’m willing to accept that. And this time I can get the red anodized version!
Did you trie to push the pistons out without brake pads attached? If that worked put some brake fluid on them and push them back, (move them out a few times, push them back and clean off oil.
Brakes with dot u have to bleed once or twice a year.
