Anyone successfully added a rear brake to a Bianchi Pista?
Old 10-06-20, 10:59 PM
5 mph
Quoted: 177 Post(s)
Liked 66 Times in 50 Posts
Has anyone successfully added a rear brake to a Bianchi Pista? I have read lots of threads on people who have tried but have had issues. I read that there are aftermarket kits to do this?
5 mph is offline
Old 10-07-20, 04:20 AM
Altimis
Altimis's Avatar
Quoted: 76 Post(s)
I don't know which model you talking about but you said you want to put on a rear brake, I assume you also fitted a front brake to the bike as well.
Here thing is, you virtually don't need to have a rear brake, even if you have freewheel, you still don't need it.
80% stopping power came from front braking. The rest is your foot, weather you put it on tires or back pedaling to stop the bike or skiddzzzz.
Altimis is offline
Old 10-07-20, 04:54 AM
100bikes
Industry guy
Bikes: To many to name - I ride a custom built steel frame.
Quoted: 115 Post(s)
Liked 80 Times in 48 Posts
I build a set of adapters for a "pista " frameset out of flat aluminum stock.
The two parts bolted together over the seat stays and brake bridge, with the bolts just inside the stays.
Using nylock nuts they were very secure.
The brake centerbolt put enough pressure on the center of the adapters to keep everything in place.
Customer was pleased with the outcome.
rusty
100bikes is offline
Old 10-25-20, 04:07 PM
roka
roka's Avatar
Bikes: Moulton SST Alfine 11, Bianchi Pista, Surly Cross-Check Alfine 11, Brompton Electric M6R, Priority Brilliant L Train 8 Speed Disc
Liked 13 Times in 3 Posts
Maybe I’m missing something. Does the Pista frame set not have a rear brake mount? I bought my Pista complete and it came with both front and rear brakes. When I moved from 23c to 28c tires I had to play with the rear brake adjustments and find thinner pads due to clearance problems with the original setup.
roka is offline
Old 10-25-20, 06:54 PM
coopman
Bikes: Specialized Roll Sport Low Entry and Bianchi Super Pista
Quoted: 91 Post(s)
Liked 61 Times in 44 Posts
No, there is no pre-drilled hole for a rear caliper brake.
coopman is offline
Old 10-26-20, 07:35 AM
TugaDude
TugaDude's Avatar
Quoted: 586 Post(s)
Liked 612 Times in 447 Posts
You are right, some of the frames do have a rear brake bridge. Some of the older ones do not.
https://www.bianchiusa.com/bikes/track/pista/
Not drilled:
TugaDude is offline
Old 10-26-20, 10:20 AM
coopman
Quoted: 91 Post(s)
I find that a front brake only gives me plenty of stopping ability. I don't ride when the streets are wet though.
coopman is offline
Old 10-26-20, 10:50 AM
roka
roka's Avatar
Not drilled:
I didn’t know that. Mine is less than 10 years old. Thanks for the info!
roka is offline
Old 10-31-20, 09:36 PM
Philasteve
Philasteve's Avatar
Bikes: Surly CreamRoller. 98 Giant Rincon. SE UVT
Quoted: 5 Post(s)
Liked 12 Times in 9 Posts
Not drilled:
Is that your bike? I like it, what year is that?
Philasteve is offline
Old 11-01-20, 05:45 PM
5 mph
Quoted: 177 Post(s)
Same here. I use a 29er Mountain Bike with fat tires and hydraulic brakes on rainy days.
5 mph is offline
