MAFAC Racer drop bolt?
Bikes: many
Quoted: 1442 Post(s)
Liked 1,388 Times
MAFAC Raids are expensive, Racers are not. Is there such a thing as a drop bolt for Racers?
Quoted: 1088 Post(s)
Liked 1,205 Times
I haven't seen a drop bolt, but I have a single drop plate for Racers. It looks just like the standard mounting plate, but with an oblong bolt hole rather than a circular one. I have only ever found the one, a couple of years back on ebay. I'm holding out in case I ever find another. As far as I can tell, it looks to have been produced this way (vs. a home modification, which I suppose is also possible, though I would imagine that's risky). I'll post a pic later.
Bikes: many
Liked 1,388 Times
I'll have to make some measurements to see if that might give me enough downward movement for the 700c conversion on my Dawes. (I'm not married to Racers. It just seemed like the most likely to have a drop bolt.)
Liked 1,205 Times
Sounds interesting. It also sounds a bit like the Balilla center pull brakes on my Frejus TdF. A few pix:
Liked 1,205 Times
Here is mine:
Quoted: 1105 Post(s)
Liked 1,326 Times
There are three different bridges for Racers, check first to see if you have the short ones (they can be marked "451").
Short gets you 63, long is 68, adjustable goes to 75.
Likes For oneclick:
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 163 Post(s)
Liked 101 Times
Skip,
I have 2 bikes I'm running 650B wheels on (one with Mafac Racer brakes), and I use home-made "drop plates", as described on Sheldon Brown's website. In my case they are small steel plates that lower the brakes by 15mm. I had them made last week and am just installing and trying them out, so I don't have pix yet. But they work great. The guy charged me 30 pesos (US$1.50) per plate, and you need 2 plates per brake unit/ 4 per bike. I intend to post a thread here with the details, because I think it's a cheap, versatile, and neat solution to a problem.
Likes For kroozer:
Liked 1,205 Times
Skip,
Bikes: many
Liked 1,388 Times
https://sheldonbrown.com/home-drop.html
and the image:
Looks easy enough, given a bit of raw material.
vintage motor
Quoted: 163 Post(s)
Liked 101 Times
The plates on Sheldon's site are ridiculously long and I don't know what kind of bike they're for, but it's a good illustration of how versatile they are. With my drop plates, the lower hole is just low enough to clear the bottom of the fork crown and brake bridge. It's all I need for 700C-to-650B, and it's hardly even noticeable.
Liked 1,326 Times
Liked 1,205 Times
I googled "bicycle brake custom drop bolt," and several interesting images popped up, including this one. It's not my image. Maybe these are being produced or sold somewhere? Or worth reproducing?
Likes For noobinsf:
Disraeli Gears
Here's what you want:
and here's the whole poster:
I can't remember where I found this online; maybe someone else has a pointer to it.
Likes For Charles Wahl:
