Surly Steamroller Photo Superthread!!!
Old 01-22-18, 08:39 AM
  #726
50voltphantom
50voltphantom's Avatar
Bikes: Handsome Fredward, Trek 1.1
Quoted: 481 Post(s)
Liked 131 Times in 47 Posts
Originally Posted by rusheleven
^ @50voltphantom Does that make two for you? One for CX/Gravel one for pavement?
The new grey is hot.
My maroon one was stolen.
50voltphantom is offline
Old 01-22-18, 08:40 AM
  #727
rusheleven
Bike thieves can burn.
rusheleven is offline
Old 02-28-19, 01:41 PM
  #728
IAmSam
Quoted: 399 Post(s)
Liked 274 Times in 136 Posts
Who's that riding a 'Roller?
IAmSam is offline
Old 03-01-19, 06:34 AM
  #729
Bigpond
Quoted: 12 Post(s)
What kinda bike shop would let him walkout with only a rear brake? Methinks demographics say Beto is weak with hipsters.
Bigpond is offline
Old 03-01-19, 12:16 PM
  #730
mouse
dumb
Quoted: 174 Post(s)
Maybe I'm missing something.... who said a shop had anything to do with his brake situation?
mouse is offline
Old 03-04-19, 07:11 AM
  #731
Bigpond
Quoted: 12 Post(s)
Originally Posted by mouse
maybe i'm missing something.... Who said a shop had anything to do with his brake situation?
qbp
Bigpond is offline
Old 04-09-19, 11:31 PM
  #732
ShannonMP
Quoted: 5 Post(s)
WTB: Surly Steamroller
HI. I'm after an old 56cm Surly Steamroller with a 1" head tube for a threaded fork. Thanks.
ShannonMP is offline
Old 04-10-19, 08:17 AM
  #733
IAmSam
Quoted: 399 Post(s)
Sorry to rain on your parade, but IIRC - 2002 or so was the last year that 'Rollers took 1" quill stems, so you have your work cut out for you...
Since it is so unlikely to find one, may I suggest that you look at alternatives? Like a Soma Rush, which AFAIAC fits in the same general niche as a SR, but does have a 1" head tube, and while I'm not positive what fork it comes with now - I do know for a fact that at some time in the recent past it did have a threaded fork.
If you are absolutely stuck on getting a Steamroller, which I can understand from having had one myself that I passed to my son who has been riding the hell out of for years now...and must have a quill, and don't mind using an extra doohickey to get your quill stem - Soma does have a weirdly cool little item they call the Quill-inator that is the reverse of the usual quill-to-threadless adaptor and actually lets you put a quill stem into a threadless fork.
Or you might consider a 1-1/8" quill-look stem like VeloOrange's Tall Stack. I'm not sure if its the original or not but there are also several other manufacturers offering other versions of the same theme at various price points. I use the VO model on my only 1-1/8" threadless steertube bike and it is not bad looking at all, in fact I even get an occasional compliment on it.
Good luck...
IAmSam is offline
Old 04-10-19, 05:23 PM
  #734
ShannonMP
Quoted: 5 Post(s)
Good luck...
Thank you. I definitely require a 1" threaded fork with the loose ball cup and cone bearing system and a quill stem. I know that The Soma Rush has that and that it has the most clearance of new track bikes that have that have 1" head tubes. But I want the old Surly SR for even more tire clearance. I've seen pictures of Surly SRs with like 26 x 2.1" mountain bike tires. That wouldn't lower the bottom bracket because of the size of the tire. That would be so sweet of a bike to me. I could also have a wheel set with 650b x 45mm tires on it. Then of course the 700 x 38mm tires. So that's like a 3 in 1 do everything bike with the 1" head tube I require.
Soma says that you can't put 650b tires on the Rush because you really can't go any wider with them on their frame, so that would lower the bottom bracket too much.
So with the Surly SR, I'd have a bike with my required 1" threaded fork, loose ball headset and quill stem, and it could "mountain" bike, do urban duty and everything in between
But like you said they haven't made them for a super long time, so I probably won't be able to find one that is "like new." So I think I'll just get a Soma Rush with the loose ball bearings, and the decent tire clearance and just stick with the 700x32 tires and forget about my dream loose ball bearing all in one bike Surly SR.
Old 04-13-19, 01:14 PM
  #735
IAmSam
Quoted: 399 Post(s)
^^^I can't figure out whether the quill stem or loose ball headset is more more important to you, but it makes no sense to me to put those small bits above the frame itself in your decision. However, rather than pollute this pic thread with more gibberish - I'll just once again wish you good luck...you are going to need it. And since I'm already here, might as well try to get things back on track with a pic of what is my son's 'Roller now, back when it was still mine years ago and I ran it with 35mm CX tires as a FG MTB
IAmSam is offline
Likes For IAmSam:
Old 04-16-19, 11:54 AM
  #736
shroomaroom
shroomaroom's Avatar
Bikes: Genesis Croix de Fer 20, Surly Steamroller
Quoted: 9 Post(s)
Liked 17 Times in 8 Posts
So many nice iterations of the same frame here, I've checked the whole thing twice now, and soon will have one of my own to share :-)
shroomaroom is offline
Old 11-05-19, 03:08 PM
  #737
IAmSam
Quoted: 399 Post(s)
IAmSam is offline
Likes For IAmSam:
Old 07-07-20, 02:10 AM
  #738
good neighbor
hey, what size tires are you running and what kind of rear brake claipers?
Im running at 37c and having hard time fitting side pull calipers. Would greatly appreciate some information. thanks
good neighbor is offline
Old 07-07-20, 02:22 PM
  #739
good neighbor
what rear brakes are you using?
Old 07-07-20, 07:38 PM
  #740
Edward1066
Edward1066's Avatar
Bikes: Rivendell Appaloosa, 1990 Specialized Hardrock Sport/X-tracycle conversion, Surly Steamroller, 1995 Specialized Allez Sport, Early 90's VanTuyl TT bike, Flying Pigeon PA-06
Quoted: 43 Post(s)
Liked 105 Times in 38 Posts
mine, basic, solid transportation....
hey, it's paid for...
Edward1066 is offline
Old 10-21-20, 06:30 PM
  #741
Wendell F
My pants used to fit me
Wendell F's Avatar
Bikes: Surly Steamroller, All-City Super Professional
Quoted: 18 Post(s)
Liked 4 Times in 3 Posts
Does the steerer tube go all the way to the top of that stem?
Wendell F is offline
Old 10-24-20, 10:44 AM
  #742
GregLast
GregLast's Avatar
Liked 5 Times in 2 Posts
Here's my Steamy-boy before and during adventures.
Thomson Seatpost and Stem
Brooks All-Weather C17
Crankbrothers Candy 2 Pedals
39x17 for some red dirt roads
Alex Adventurer 2 Rims
Teravail Cannonball 700x38
TRP Levers
Tektro brakes with salmon Kool Stops
GregLast is offline
Likes For GregLast:
Old 10-24-20, 04:28 PM
  #743
Gresp15C
Gresp15C's Avatar
Quoted: 1062 Post(s)
Liked 665 Times in 421 Posts
Question: Are there any technical reasons why the Steamroller frame would not accommodate coaster brakes and/or a gear hub?
Gresp15C is offline
Old 10-24-20, 05:27 PM
  #744
TejanoTrackie
Veteran Racer
TejanoTrackie's Avatar
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times in 431 Posts
Any hub with an axle that is spaced at 120mm will fit in the rear dropouts of the Steamroller. So, any coaster brake hub or IGH with 120mm spacing will fit. Most coaster brake hubs are spaced at 120mm, but some IGH are wider, so you will need to check. For example, I have a Shimano Nexus 7-speed IGH that is spaced at 130mm. The only other requirement is that you be able to attach the reaction arm to the frame's chainstay, which is only a problem if the chainstay is abnormally large.
What, Me Worry? - Alfred E. Neuman
Originally Posted by Dcv
I'd like to think i have as much money as brains.
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
TejanoTrackie is offline
Likes For TejanoTrackie:
Old 10-25-20, 10:54 AM
  #745
Edward1066
Edward1066's Avatar
Quoted: 43 Post(s)
Goes almost all the way to the top. Not the stock fork though. Low trail fork from SOMAFAB. I wanted something that had double eyelets.
Old 11-04-20, 06:18 PM
  #746
takenreasy
takenreasy's Avatar
Bikes: ’83 Bianchi Special ’96 Specialized Stump Jumper Comp ’09 Gary Fisher Paragon ’09 Surly Cross Check ’11 Surly Long Haul Trucker
Quoted: 71 Post(s)
Liked 76 Times in 50 Posts
Love the basket but you might need to snug up your chain.
takenreasy is offline
Likes For takenreasy:
Old 12-05-20, 11:04 AM
  #747
speed king
Quoted: 11 Post(s)
Liked 84 Times in 22 Posts
speed king is offline
Likes For speed king:
ColonelJLloyd
Classic & Vintage
108
09-28-16 08:38 AM
br995
Singlespeed & Fixed Gear
2709
10-05-14 10:10 AM
CarLo
Road Cycling
23
08-12-11 02:32 PM
JPWendtinc
General Cycling Discussion
0
07-23-11 10:52 AM
wearyourtruth
26
03-04-10 11:39 AM
