Quick release came loose today on my front wheel
Quoted: 7 Post(s)
brand new bike (well, rode it maybe 100 miles so far)
was coming up hill and felt the tire becoming super wobbly. pulled over and realized the lever was not engaged.
super concerning and a lesson learned in terms of checking the bike before riding.
i'm curious though, is this a common occurrence? how could this happen?
Likes For aggiegrads:
Expired Member
Quoted: 3674 Post(s)
Liked 5,432 Times
Agreed. Not common, in fact improbable w/o faulty installation or outside interference after installation. Plenty of how-to instructions online. That said, I've had the rear wheel shift when cranking hard on a climb. Some QRs work better than others and drop outs vary as well.
Likes For fietsbob:
Quoted: 1438 Post(s)
Liked 1,092 Times
https://www.alsbicycles.com/articles...ctly-pg314.htm
https://www.bicycling.com/repair/a20...quick-release/
Closing the QR should need enough force to leave a mark on your palm. Make certain that the lever is not facing forward when tightened, so that a passing object does not flip it open.
Likes For dsbrantjr:
Quoted: 1819 Post(s)
Liked 1,693 Times
Answers so far are pretty much par for the course. Very often new riders have no idea how to tighten a quick release. If the lever had the concave side facing out, it was your fault if you didn't flip the lever to tighten the wheel. It is very common for new riders to do this wrong
Likes For alcjphil:
Quoted: 7 Post(s)
a bike shop. it's a month old. i'm sort of pissed. if you look at my history i've already had some issues with the bike including a bent FD cage (which i refuse to believe i did - though i guess it's possible).
Quoted: 7 Post(s)
Quoted: 6193 Post(s)
Liked 4,809 Times
Don't leave your life and safety to others.
Likes For Iride01:
Quoted: 1324 Post(s)
Liked 927 Times
I FAR prefer the older closed-cam quick release skewers to the newer open cam ones. I bought a number of the old-style ones at a bike shop where they were very inexpensive. I put them on wheels friends have if the wheels have the newer open-cam ones. The old style closed-cam are much more secure in my opinion.
Cheers
Cheers
Likes For Miele Man:
Liked 927 Times
Oh, it's a good idea to check quick-releases on wheels and brakes if the bike has been out of your sight for any length of time. Some sick individuals think its fun to open them, or loosen them.
Cheers
Cheers
Quoted: 347 Post(s)
Liked 418 Times
I have two rules for QRs.
1) Never put a wheel on the bike without properly securing the QR as if you where going to ride it immediately. I have stuck a wheel on and thought I would come back and use a different wheel for tomorrow and not tighten the QR , forget the wheel was not secure and causing ensuing hilarity the next day. Leads to rule #2 ...
2) Before every ride “Quickly do your ABCs”. Check Air in the tires, check the Brake function, visually check all the Cables, check that the quick release is correctly engaged on both wheels.
Likes For billridesbikes:
Blamester
Always leave the skewers in the same position and side so if it's not in that position something is wrong. Everytime you look down you know where the skewers should be.
I point mine backwards parallel to the road non drive side.
Quoted: 7 Post(s)
what's the best course of action now? when i retightened the QR it was quite hard to push the lever down. i assume it's probably locked in a bit too tight at the moment. i'm guessing it might make sense to loosen the lever and nut and retighten?
Quoted: 980 Post(s)
Liked 582 Times
Agreed, but the "open cam" variety will generally work well enough if they're properly closed. I bought a bike that came with Ultegra components but an option was titanium skewers that had the bike's brand etched on the levers. Yes, a silly thing. My point is that in 20 years a wheel has never come loose. And I still have the original skewers to admire, or use as I see fit!
Bikes: 2019 Trek Stash 7, 1994 Specialized Epic 1986 Diamondback Ascent 1996 Klein Pulse Comp, 2006 Specialized Sequoia Elite
Quoted: 418 Post(s)
Liked 523 Times
Maxle?
Does it happen to have a Maxle quick release? The rear Maxle on my new bike has loosened a couple of times during a ride. I caught it fairly quickly both times as the shifting gets slightly off. I did some research and it seems quite a few people have been having issues with Maxles. I plan to ask my bike shop if there are any solutions other than checking them before each ride.
(If it is a Maxle, I read there's a small Allen bolt you tighten to adjust the tension)
Quoted: 850 Post(s)
Liked 344 Times
Upgraded to Shimano 105 skewers. They don’t “snap” into place as nicely but I don’t have to maintain my f****** skewers.
OP, wanna post a pic of your skewer as it is on the wheel?
Quoted: 1074 Post(s)
Liked 295 Times
That’s the Kona Rove DL you’ve posted about earlier?
A quick pic search shows a disc brake bike with a regular q/r hub.
Due to the bike industries unfortunate decision to put the brake caliper on the rear of the fork, braking forces can push the axle downwards hard enough to overcome the force from the weight of the rider.
So unless you have your q/r on real tight, it will happily work itself loose by the repeated motion from braking.
You should be using a good-quality internal-cam q/r and close it HARD.
And check regularly.
Failure to do so may introduce you to the marginal joys of front wheel ejection.
Likes For dabac:
I had a Fulcrum skewer that gradually came loose on my mountain bike rear tire unless I tightened it really hard. If I tightened it with "normal" force, it started loosening. Usually it started creaking before nothing too serious happened.
In the end I replaced it with another skewer and problem went away.
Quoted: 2604 Post(s)
Liked 1,933 Times
Sounds like it's about right. You need to have an impression on your hand after you tighten the quick release. As long as you can get it flipped, it's not too tight.
Likes For pdlamb:
Quoted: 1034 Post(s)
Liked 1,290 Times
