#2601
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times
I'm sure you've read up on all the techniques, but here are a couple things I find useful (in addition the the usual steps of stretching them, etc):
- A bit of inflation (just enough to help it hold its shape) while gluing helps. I put in some air, then stand the now hula hoop on my workbench and let it lean against the wall behind.
- Paste flux brushes are your good friend.
- Rotate as you go so you're always applying glue to the part of the hula hoop near the workbench.
- Disposable gloves are your best friend.
- Cover the base tape completely, but no further out.
- A crappy apron is your BFF.
- Once fully glued, I find someplace to balance the hula hoop on its valve stem so the glued tape doesn't touch anything else (well, as little else as possible.
#2602
Quoted: 1608 Post(s)
Liked 2,216 Times
@Lascauxcaveman - If you haven't already researched how to apply, you might check this out:
Dave Moulton's Blog - Dave Moulton's Bike Blog - Tubulars: Part*I
#2603
Quoted: 1627 Post(s)
Liked 630 Times
@SJX426 Thanks! I already had that one bookmarked and will review it before going forward. Got one stretching on a rim right now.
@smontanaro, Yep, I've read up on the process and it seems pretty straightforward. And I've worked with contact cement in various forms lots of times, so I think I actually get the basic idea; its just a matter of prepping and execution now. Gonna head across the street to the LBS to see if they've got the glue...
#2605
52psi
Quoted: 790 Post(s)
Liked 802 Times
Paramount decals! Olympic panel and 531, direct from Waterford.
I can't repaint any time soon, but I'm sure gonna have the proper livery on the existing blue in the meantime!
#2606
Aspiring curmudgeon
Bikes: Guerciotti, Serotta, Gaulzetti
Quoted: 111 Post(s)
Liked 26 Times
A great long sleaze jersey to match the Guerc. Thanks @HenryIII
"Party on comrades" -- Lenin, probably
#2607
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
A NOS pair of GP4 rims, thanks to BG. I have work to do...
Real cyclists use toe clips.
jimmuller
jimmuller
#2608
Bikes: 2015 Trek Domane 4.3, 1989 Schwinn Circuit, 2010 Yeti ASR 5, '80 Vitus 979 (being refurb'd)
Quoted: 11 Post(s)
Garmin Forerunner 610 kit
Decided to upgrade from my 305 for a little more compact design, better heart rate strap, and wireless connectivity. I have Edge 500 for bike, this is mainly for hiking and working out. It's a factory refurb, but I've had good luck with refurb'ed products in the past. We'll see how it works out.
#2609
Bikes: Condor, Cinelli SC, MKM Metcalfe, Peugeot AE08, Bianchi, Cougar, Miyata, Harry Hall, Holdsworth Special, Raleigh Int'l, Le Croco, Bob Jackson, Zeus
Quoted: 114 Post(s)
Liked 102 Times
ok, so not everything came today, but over the last while I received good stuff from @sloar (Zeus cranks, RD, FD, shifters), @sonatageek (very dark brown Brooks saddle and a Cuyahoga Valley National Park visitor map - nice touch), @mrv (tricolour hub), @Ed. (shoes) and @Crankaddict (universal levers). Jersey from the bay - Verzelli is an LBS in Toulon, France. Don't know what USTT is but I like the blue and the Peugeot-like checkerboard pattern.
Thanks to all.
Brad
Thanks to all.
Brad
Better bike .. Better life!
#2610
Quoted: 2588 Post(s)
Liked 4,824 Times
I bought a grab bag of Campy parts several months ago with two NR RD's without the upper pivot bolts. I have been hunting for replacements and thought of asking @Drillium Dude if he had any. He said he just put some in the BOC. One had a bent back strap and the bolt could not be pulled and I should contact @photogravity. I did, but he had just shipped the box off to @crank_addict. So I set a note to him and he said yeah, I will send it to you. It came yesterday. Thanks to all three of you for your support!
[IMG]WP_20150316_001[1] by superissimo_83, on Flickr[/IMG]
So I thought what the heck, lets straighten this thing or break it.
[IMG]WP_20150316_003 by superissimo_83, on Flickr[/IMG]
[IMG]WP_20150316_004 by superissimo_83, on Flickr[/IMG]
[IMG]WP_20150316_005 by superissimo_83, on Flickr[/IMG]
[IMG]WP_20150316_006 by superissimo_83, on Flickr[/IMG]
Well, I was a bit surprised to find that this material had some spring to it, hence the secondary operation.
The bolt was pressed out using deep sockets from a 1/4" and 1/2" drive. Dont' know if it is good enough yet, need to test it on one of the "good" RD's. Thought you might be interested. I think the body is in decent condition for use if the bore the bolt goes in is not oval.
Glad you could get the bolt out, too. I've gotta know: what seemed to be keeping it stuck in the body? For the life of me I just couldn't figure that one out.
Awesome that we got the part to the right person with a bit of coordination. I love it when it all works out
DD
#2612
Liked 2,216 Times
@Drillium Dude - I thought what the heck. If it breaks it breaks, if not, it would be a good body!
I haven't fully analyzed the bolt issue. but I have a suspicion that it was really torqued onto the drop out hanger and the edge was deformed, flared out slightly around the edge. I will take pictures if I can get a good one to show what I mean. The solutions is problematic, if this is the case. The bolt may not be usable. Stay tuned.
And Dave, my name is Patirck!
#2613
Liked 2,216 Times
@Drillium Dude - I took measurements, tried a picture but it really couldn't show the features well.
If you recall, the bolt has two bearing surfaces, one at the head and the other next to the threads. The larger surface is by the head and measured 11.44mm dia. The smaller surface (width) measured 11.44 toward the head end and 11.55 next to the thread. So the part is damaged with the edge "mushroomed with a nominal diameter 0.11mm larger in diameter. This would account for the bolt not coming out of the bore. I used a drift punch to remove it which may have shaved the bore out to the larger diameter. When I get to it, I will put a known good bolt in to see how much damage was done to the bore.
[IMG]P1020800 by superissimo_83, on Flickr[/IMG]
#2614
Liked 4,824 Times
Patrick: interesting; I wonder how that happened? Maybe it was compressed against the dropout derailleur hanger ear in the accident that deformed the back plate on the body of the derailleur itself. As good a guess as any, I suppose.
At least you were able to save the body for re-use. Good deal
DD
DD
#2615
Quoted: 3015 Post(s)
Liked 3,804 Times
Regina Chain by iabisdb, on Flickr
FB Crank 01 by iabisdb, on Flickr
FB Crank 02 by iabisdb, on Flickr
#2616
Bikes: 1985 Eddy Merckx Corsa Extra, 1978 Schwinn Super Letour 12.2, Schwinn Paramount PDG 50, 1992 Schwinn Paramount PDG 3, Sears ToteCycle in the works
Liked 645 Times
No, these tracks were made by Imperial storm troopers. Jawas always walk single file to hide their numbers.
Uncle Owen, this R2 unit's got a bad motivator.
jimmuller
jimmuller
#2619
Bikes: 1989 Tommasini Super Prestige, 1985 Chris Kvale, 1977 Colnago Super, 1992 Serotta Colorado, 1984 Schwinn Cimarron
Quoted: 189 Post(s)
Liked 40 Times
Last few days.
(Can't complain about the quality for a new jersey for $18 to the door...)
#2620
Quoted: 821 Post(s)
Liked 255 Times
Challange Strada Biancas on sale at Velomine.
Also picked up a very slightly used set of Compass Chinook Pass locally. Wouldn't fit his frameset.
#2623
Quoted: 189 Post(s)
Liked 40 Times
Now... To get rid of this new batch of snow...
#2624
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
Ooh nooo! You just made a Death NR derailleur out of it!
Just kidding. The bend wasn't that bad to be worried about the repair....... but it should not take any more bending, especially the other way or the AL crack gods might pay you a visit....
#2625
Quoted: 821 Post(s)
Liked 255 Times
Pinched a nerve a week ago so I can't ride anyway.
Good news is I finally received the soccer schedule so we can set some ride dates.
