Fenders beyond commuting.
#51
There was a time when I didn't use fenders. But over time, I figured out that fenders work well on my commuting bike. Then I figured out that they are good on touring bikes for those rainy days, even for the bikes that are used on week-long supported tours. Fenders can make a damp day much more pleasant. Now there are only two bikes that don't have fenders. One is a "go fast" bike for the club day rides. The other is my 1981 Centurion Pro Tour, just because it is a re-creation of my original Pro Tour that didn't have fenders.
A friend who lives in the Pacific North West explained the difference between "me" fenders and "we" fenders. "Me" fenders keep the rider clean and <sometimes> dry. "We" fenders keep the spray off the rider behind me as well. I like Planet Bike Cascadia fenders.
#52
Quoted: 2603 Post(s)
Liked 1,926 Times
Just a note on VO metal fenders:
They are a major pain to install. I bought a pair to replace an 18 year old SKS plastic fender that had cracked. After about 6 hours over two days, the rear fender is on -- the old front fender is slightly cracked, but not falling off. It takes two or three people to do it right: remove wheel, mount fender, mark, reinstall wheel, re-mark, remove wheel, unmount fender, cut fender stays (long), remount fender, install wheel, adjust chain line, check fender mark, remove wheel, unmount fender, drill, install fender, cross fingers, reinstall wheel, remove wheel, cut fender stays to final length, reinstall wheel, done.
I should have bought a new SKS set. Put the fenders on, cut the fender stays to length, file the stay ends, done. And you saved five hours for a nice long bike ride!
#53
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,528 Times
#54
#55
Title-less
Well the fenders arrived, finally got to see them in person. I was not a huge fan of the set up process. I returned the fenders and found some Portland design works fenders on sale for $15 more. I set them up last night, they will need a small amount of tweaking (lol). I adjusted my rack and for the most part got the fenders installed. Test ride to work today. It is on a cross check so I wonder how bad my toe overlap will be. I appreciate all the support and input! I’ll keep you guys posted hopefully a pic soon!
Likes For tweekfreekdX:
#56
Liked 1,926 Times
I was reading old thread which some people said that some plastic fenders can get kicked into the tire (toe-overlap) and sucked into the fork, thereby lock up the front wheel and send the rider over the h'bar.
It is probably more of an issue on knobby mtb tires.
But I wouldn't rule it out for roadbikes with treads.
Likes For pdlamb:
#57
Cycleway town
I've never had problems with fenders, in use or fitting. Four of my bikes have them. I've done thousands of miles. Currently using 3.5ins wide stainless cruiser fenders on a full suspension bike, i run it down flights of stairs and through the woods.
My only dislike is the racket they make on wet gravel, but it beats having my face pebble-dashed.
#58
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
I find fenders can be both functional and quite handsome
Likes For SalsaShark:
#59
Fenders are a must in the NW!
Fenders are a must as I live in the NW. We get lots and lots of rain here. I do have a sporty bike without them but it is only ridden in nice mid summer days. I really think they look okay as most cyclists here have them.
#60
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
Your floor and rug look immaculate. You must wash and dry your tires before bringing the bikes in!
This sounds quite interesting. Can you post a photo or two please? Thanks!
One of my best bikes is a custom road fix gear with a very long dropout. The rear fender is cut at the brake bridge. The rear piece got modified further. I cut the fender sides in two places, straightened it out a bit, then fiberglassed the inside to maintain that new shape and increase stiffness. Now I can slide that rear wheel anywhere and never contact the fender. I can ride that Portland hills now using both a 23 tooth cog to go up and a 12 to come down and never mess with the fender. (SKS silver. Not a bad match for a ti frame.)
Ben
Ben
#62
born again cyclist
Many bikes look good without fenders.
Many bikes look good with fenders.
Generally speaking, I lean more towards the stripped-down, lean and mean aesthetic for bicycles. However, in the world of bike commuting, I am a 100% "form follows function" kinda guy.
The practical utility of fenders for me as an all-weather bike commuter in Chicago FAR outweighs any aesthetic misgivings I might have for them.
#63
Quoted: 8 Post(s)
i have them on my mtn bike converted commuter and think they look fine on top of doing a job. i just put a cf fork on my cross bike and my old fender won't fit.
i think the right fender on a bike can look good, and some such as hammered ss, or wood look classy on steel. ymmv
#64
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
I like hammered aluminum vo.
#65
Full fenders aren't just for sloppy rainy days, I recently put on fenders on a 20" mini velo that I keep at work for biking from our main building to a satellite building in the same office park. Right in front of our building is a permanent mucky puddle on the asphalt trail that I use to get to the other building that never dries out so I had to traverse it really slowly sans fender. Then I installed fenders. Now I just plow through the mucky puddle with reckless abandon without getting the bike or myself wet.
A set of full fenders are permanently affixed to my old 26" MTB commuter and I'll eventually install removable fenders when I remember to order them.
#66
Bikes: Working on replacing my stolen Soma Buena Vista Mixte
Quoted: 417 Post(s)
Liked 95 Times
#67
Happy banana slug
Liked 1,528 Times
+1 @jade408; just this morning I hit some small gravel that pinged off my front fender rather than my face.
Likes For Korina:
#68
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
To my eye a bike isn't complete without fenders, dynamo hub, lights, and a front rack. These things are always nice to have, and sometimes essential. I realize this is a function of the kind of riding I do. As for the aesthetics, once you get into that "bike must have fenders" mindset, you get to like the look.
As mentioned, they can be difficult to set up. More accurately, setting them up is a skill that one needs to acquire like any other. I'm sure that's a big part of why you don't see them much in a country where bikes are regarded as toys that only come out in nice weather.
Likes For rhm:
#69
Walk into a bike shop, or go on-line and look at new bikes, or observe all the bikes you see around the world on the streets, paths, in races, etc., and the overwhelming majority don't have fenders. There's your consensus.
I'm not saying fenders aren't a good product that serve their purpose well, all I did was express an opinion that they look goofy. No question, they are justifiably popular with daily commuters, and that they keep your bike and clothes cleaner (again, already stipulated).
Most bikes I see around town have proper dry rusty chains, thinning tires, and covered in dirt. It doesn't mean rusty chains are popular.
#70
Bikes: 2022 Priority Coast, 2022 Priority Current
Quoted: 175 Post(s)
Liked 137 Times
No, just use a rumba weekly. Not much rain here in the summer. I park my bikes outside for use and bring them in when I'm riding other bikes.
#72
Title-less
Fender update!
Exactly as you guys said, definitely beneficial and make the bike look complete. Here in Iowa we had some pretty heavy rains that flooded the creek and trail I commute on. Made it to work and home with a much cleaner bike. Probably my best purchase for the bike next to my saddle. I have also received quite a few compliments on the fenders from those who ride. Thanks again!
#73
Bikes: 2015 Salsa Fargo 3, 2000 Specialized Rockhopper
Quoted: 9 Post(s)
Liked 9 Times
Really appeciate fenders when riding through the homeless area or past the duck/goose ponds. You never know what that puddle contains.
Likes For Lug:
#74
Bikes: Several Road and Mtn Bikes
I am an old guy. Raced bikes in the mid to late 80's and just love bicycles. I moved to Beijing in 1995 and bought a bike for commuting 26km to the plant. The bike was beautiful in a very utilitarian way. My daughter went to college and she took my Beijing bike. It went everywhere around town and campus, hauling books, groceries, take out. She loved the fenders. She recently moved to Northern VA and used the bike to explore on weekends and after work, to shop and to exercise. Tonight she called and told me her bike was stolen. She is looking for a replacement and we discussed fenders, bell, rear rack etc. I can't wait to hear what she buys to replace the stolen bike. I recommended police auctions and then getting the bike set up at a LBS. Fenders are definitely the way to go in wet conditions where you want to arrive comfortable and dry.
I also had a bike poncho I bought in China that fastened to your hands and could button up the sides depending on how much rain and where the wind was coming from. I have never see one like it except in China. Pure genius.
Likes For Redman1959:
#75
Quoted: 626 Post(s)
Liked 701 Times
I got my recumbent when I was living in the Seattle area. Fenders there are a must, unless you really enjoy the spray in your face, feet, and up your back. It's worse on a recumbent, because the spray from the rear tire gets you in the back of the head instead of just your back.
Now, I have a velomobile for adverse weather, it's the ultimate all around fender.
