I want to build a vintage-style CX bike - suggestions please!
Old 07-23-19, 12:50 PM
ddeand
ddeand's Avatar
Quoted: 206 Post(s)
Liked 102 Times in 46 Posts
While riding my Cannondale CAADX today, I kinda decided that maybe I'd like to sell it, take the proceeds, and build up a nice, older CX-style bike - probably pre-1990 style. The Cannondale is a very nice bike, and it fits me quite well, but I'm finding that I like riding my 1980 Miyata Pro a bit more. I think I'd like to build a steel framed bike that can handle the gravel roads that I often ride. Since I'm not competing or going terribly fast, I think I can get by just fine without the disc brakes. Off the top of my head, here's what I'd like/need to replace the CAADX:
  • 58cm frame (although an actual CX frame would likely be 56cm for me) - doesn't have to be a CX frame, but it needs to be sturdy
  • Lightweight, but fairly robust (the CAADX weighs about 21 lbs - I'd shoot for 22 lbs)
  • Strong enough for a 215 lb rider
  • Capable of being adapted to 1x8 or 1x9 drivetrain
  • Capable of handling 32x700c tires
  • Definitely a mash-up of old and new parts (e.g., brifters and hubs)
So, where should I begin with a frame (that's my biggest concern)? Component suggestions? Wheel suggestions? I've gone through the CX build section of the Forum and have gotten a few ideas, but since I'm starting out tabula rasa, I thought I'd see what some of you might suggest. All suggestions are appreciated!
Some days, it's not even worth gnawing through the restraints.
ddeand is offline
Old 07-23-19, 12:56 PM
bikemig
bikemig's Avatar
Quoted: 5885 Post(s)
Liked 3,468 Times in 2,078 Posts
I'm a big fan of 70s era racing bikes. The prices tend to be good for a full Reynolds 531 frame or a full chrome moly frame. They came with long reach brakes and most can handle 32c tires. You will want to spread them to 126 mm in the rear. I'm busy building up an early 70s Fuji Finest with 700 x 32c tires. Heck there's room for 35c tires and quite possibly larger as well.
https://www.bikeforums.net/classic-v...ld-thread.html
I'm building this 3 x 7 friction but it would be easy to do with 2 x 7 with brifters and indexing as well.
Back in the 70s racing bikes tended to come with center pull brakes and they were designed for bad roads. Those are very versatile bikes.
bikemig is offline
Likes For bikemig:
Old 07-23-19, 01:05 PM
Bandera
Quoted: 1112 Post(s)
Liked 180 Times in 119 Posts
When I was racing 'Cross the Italian Alan frames, sold under several marques, were state of the art.
Very light & easy to shoulder/run with, compliant and nimble handling w/ good mud clearance they raced very well.
That being said the >40YO aluminum "screw & glue" construction has always had problems w/ lugs cracking, finding one in good nick today might take some doing but they were the Real Deal BITD.
This will be true on any old 'Cross bike, it's a high wear & tear sport w/ crashes SOP in training and racing, at least the wrecks are in "soft-ish" dirt & mud.
-Bandera
Bandera is offline
Likes For Bandera:
Old 07-23-19, 01:07 PM
Reynolds 531
Bikes: a few that I can't recall
Quoted: 342 Post(s)
Liked 299 Times in 146 Posts
plus bar end shifters. I dont like 1x on gravel / cross bikes. It is just so nice to "dump" the front chain from 48 to 36 or whatever, instead of click-click-click-click-click-click up the freewheel when you come to surprising hill.
Reynolds 531 is offline
Likes For Reynolds 531:
Old 07-23-19, 02:17 PM
Hudson308
Mr. Anachronism
Hudson308's Avatar
Quoted: 526 Post(s)
Liked 256 Times in 165 Posts
I would suggest an early 90's hybrid... lugged if you can find it. Butted chrome moly, plenty of 700C tire clearance, cantilever brakes. Trek Multitrack, Raleigh Detour, Schwinn Sierra or Criss Cross, Specialized Crossroads, or one of the Marin models. Adaptable to just about any parts group you wanna throw at it. If you're worried about any lack of respect, strip it and paint it with something wild enough that no one can figure out what it is.
Hudson308 is offline
Likes For Hudson308:
Old 07-23-19, 03:15 PM
SamSpade1941
SamSpade1941's Avatar
Quoted: 490 Post(s)
Liked 68 Times in 54 Posts
These days the trend seems to be going 1x , but I agree with you I like having double up front .
SamSpade1941 is offline
Likes For SamSpade1941:
Old 07-23-19, 03:40 PM
Andy_K
Andy_K's Avatar
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,862 Times in 1,439 Posts
Which of these criteria does your Miyata not meet? I'm not trying to be snide, just trying to get a sense of what you mean by the subjective traits like "robust".
I'll admit that I am a little bit skeptical about this project. I'm a big fan of vintage bikes, and vintage bikes with fat tires and modern components in particular. Even so, I've got a Kona Jake the Snake which isn't in any real danger of losing its place in my stable because for some uses it's just better. Casual riding on standard gravel roads isn't necessarily one of those uses though, so I'm not going to tell you that your idea definitely does not have merit. So I'll accept the premise and share my thoughts.
I am of the opinion that nearly any steel frame is robust enough for gravel and strong enough for a 215 pound rider, especially if you're not going fast. Some of the super light (i.e. thin) tubing might be at risk, but just barely if at all. I also think nearly any vintage frame can be made to work well with a modern drive train. Finally, most decent steel frames will build up to something in the 22-23 pound range, depending much more on your component choices than the frame itself for where it falls in that range. So for me the requirements you list boil down to a 58 cm steel frame that can take 700x32c tires.
If you can find a bike that will take 700x35 tires that would expand your gravel tire options quite a bit, but I'm not sure how many vintage road frames will do that. I'd also suggest that you consider water bottle bosses, because clamp-on solutions are ugly and on gravel can be a bad solution. I like fender too.
A lot of vintage frames will fit the bill, especially if you're OK with 700x32 as a limit. Nearly any touring bike will do, but they might not ride the way you'd like. Bikes that are actually built for fully loaded touring tend to feel sluggish in my experience. I'd suggest that what you're looking for is a sport touring bike. Here are two from my stable for inspiration, but there are a lot of other options.
1982 Specialized Sequoia
1982 Trek 614
(Note: I had to use a clamp on solution to get a second water bottle on the Trek.)
My Bikes
Andy_K is offline
Likes For Andy_K:
Old 07-23-19, 03:42 PM
Andy_K
Andy_K's Avatar
Bikes: Yes
Double? Double!?!? Why on earth would you limit yourself to two chainrings when you could have three just as easily?
My Bikes
Andy_K is offline
Likes For Andy_K:
Old 07-23-19, 03:47 PM
ddeand
ddeand's Avatar
Quoted: 206 Post(s)
Heh, heh. At my age, I generally don’t do routes where there are many surprises. I just spent a few days riding my son-in-law’s 1x bike, and I liked it a lot. My gravel riding will be relatively conventional, so I should be able to get a setup that can handle that.
ddeand is offline
Old 07-23-19, 04:08 PM
ddeand
ddeand's Avatar
Quoted: 206 Post(s)
The Miyata Pro pretty much covers all the bases, but it sure works well as my main road bike. I’m not sure I want to put bigger tires on it, though. It has a Tange Champion frame, so it is pretty robust. I am also working on building up a 1974 Raleigh International - would that frame be a viable candidate for my project? I have the frame but not the fork, so there is some latitude for how I can complete that. If the Raleigh International frame is a possibility, that might simplify the project. Possible?
ddeand is offline
Old 07-23-19, 04:18 PM
Andy_K
Andy_K's Avatar
Bikes: Yes
A 1974 Raleigh International is definitely a candidate. By 1974 they didn't have as much tire clearance as the earlier Internationals, but you could probably get 700x32s in there without fenders. I happen to have a '74 International. Here it is with 700x28 (closer to 30 on these rims) with fenders:
You would have the issue of needing clamp-ons for water bottles, but if that isn't a problem for you this could work.
My Bikes
Andy_K is offline
Likes For Andy_K:
Old 07-23-19, 04:32 PM
Bandera
My '74 Internat'l was the 1st bike that I raced 'Cross on and was in the pits as a back-up after getting a proper 'Cross race bike.
It's been down more lousy back-roads in the last 45 years than any machine I've owned.
Just last weekend I cut through the unpaved back lot and service road of the local farmer's mkt to avoid the entrance traffic, that would be Gravel Shopping I guess.
A highly versatile design like many British club rider's machines of the era.
-Bandera
Bandera is offline
Likes For Bandera:
Old 07-23-19, 04:35 PM
clubman
Phyllo-buster
clubman's Avatar
Quoted: 2295 Post(s)
Liked 2,041 Times in 1,250 Posts
I just picked up a cheap Crossroads and I'm pretty delighted with it's stance and manners. I don't think it will ever meet the OP's 22 lb criteria though. I'll let you know.
clubman is offline
Likes For clubman:
Old 07-23-19, 04:37 PM
ddeand
ddeand's Avatar
Quoted: 206 Post(s)
Beautiful Int’l, Andy K! I was going to build the Raleigh as a road bike, but maybe I’ll get some 32s and slap them on a set of 7-speed wheels I have to see if they will fit. If I can use the Raleigh, that will allow me to spend a bit more on components. If the wheels and tires fit OK, I’ll build it as a 2x7 with bar end shifters. So I guess it might all boil down to tire clearance, the appropriate brakes, freewheel size, and chainring size. Maybe for the water bottle holders I’ll just use one of those beer can helmets with tubes running to my mouth. Hmmmm . . .
ddeand is offline
Old 07-23-19, 04:50 PM
coolkat
Cyclist
Bikes: '84 Univega Specialissima, Rawland Stag, '87 Rocky Mountain Blizzard
Quoted: 81 Post(s)
Liked 22 Times in 14 Posts
I got rid of my CAADX (well, crashed it) and replaced it with a Surly Cross Check. Surprisingly nice smooth ride, insane tire clearance, used ones are dirt cheap, and the geo is way better than a 90s hybrid. Just wasn't worth it to me to track down a vintage cyclocross bike that would only fit 33s and would probably cost more or the same as the $200 i paid for frameset + wheels.
coolkat is offline
Likes For coolkat:
Old 07-23-19, 05:09 PM
TiHabanero
Quoted: 1739 Post(s)
Liked 1,369 Times in 718 Posts
Miyata 610, 615, 1000. They will do the job quite nicely. I have an 85 1000 running 38mm tires and fenders and run it on gravel and two track all the time.
TiHabanero is offline
Likes For TiHabanero:
Old 07-24-19, 12:13 AM
SurferRosa
señor miembro
SurferRosa's Avatar
Bikes: '70s - '80s Campagnolo
Quoted: 3854 Post(s)
Liked 6,448 Times in 3,188 Posts
Saw one of these on craigs not long ago for $400ish. The paint wasn't as nice, but it looked pretty rad.
SurferRosa is offline
Likes For SurferRosa:
Old 07-24-19, 12:33 AM
guidogad
Quoted: 11 Post(s)
Liked 6 Times in 6 Posts
If your riding is relatively 'tame' any old bike will do if you can get cx tyres in. That, however, might be harder to find than you think. From the early/mid 70s tyre clearances got smaller.
I've got about 25 road bikes between 1978 and 1989 and only one of them can be fitted with cx tyres. It's a 1983 Kuwahara built bike that is pretty much in road set-up (downtube 2x6 indexed) with cx tyres and does a splendid job.
Touring bikes are often a bit heavier and older bikes may limit your gear choices a little more w/o some intervention. I would also be a little reluctant to turn a beauty into a gravel grinder.
guidogad is offline
Likes For guidogad:
Old 07-24-19, 02:00 AM
tricky
Quoted: 634 Post(s)
Liked 444 Times in 298 Posts
Univega had a range of "via" hybrid bikes that would work for this. Despite having low rider mounts on the fork, I find them to be more lively than a touring bike. The version I rode was the Via Charisma. There are a few tiers above that model.
tricky is offline
Old 07-24-19, 03:48 AM
panzerwagon
Garage tetris expert
panzerwagon's Avatar
Bikes: A few. Ok, a lot
Quoted: 385 Post(s)
Liked 689 Times in 327 Posts
1992 Trek 790 Multitrack. Lugged, chromoly, 135mm rear dropout, 700c wheels, canti brakes, tyres as wide as you want... I’m sure other hybrids of that era will also suffice.
panzerwagon is offline
Likes For panzerwagon:
Old 07-24-19, 05:30 AM
nlerner
Quoted: 3800 Post(s)
Liked 6,614 Times in 2,592 Posts
Two words: 650b conversion.
nlerner is offline
Old 07-24-19, 05:59 AM
jcb3
jcb3's Avatar
Quoted: 140 Post(s)
Liked 13 Times in 12 Posts
+1 - and you can go in either direction, a 700c>>650 or 26erMTB>>650
I’ll put in a pitch for an early 70s Peugeot Px 10 as the base frame - plenty of room for 32s and fenders, really nice ride on the rough stuff. Cyclocross tubulars are a nice finishing touch and you can ride them with low pressure with no worries. Tubular wheelsets are dirt cheap these days.
I also converted a 26er late 1990s Nishiki to 650. Could fit 38mm tires and that was a great gravel ride. Just needed a new set of tektro cantilevers to make them work.
Ultimately I decided the Nishiki was too heavy and went to plastic, feasting off the 70-90% off last days of performance bike.
jcb3 is offline
Likes For jcb3:
Old 07-24-19, 06:24 AM
TenGrainBread
TenGrainBread's Avatar
Quoted: 1136 Post(s)
Liked 650 Times in 336 Posts
Sorry, but what's the point of a 26"->650b conversion? High quality slicks and knobbies are available for both so what's the point of spending a bunch of money on new wheels/brakes on this, just to get less tire clearance?
TenGrainBread is offline
Old 07-24-19, 06:41 AM
kunsunoke
spondylitis.org
kunsunoke's Avatar
Bikes: '84 Colnago Super; '90 Bridgestone MB-1; '81 Trek 930; '01 Cinelli Supercorsa; '62 Ideor Asso; '87 Tommasini Super Prestige; '13 Lynskey R2300; '84 Serotta Nova Special; '94 Litespeed Catalyst; etc.
Quoted: 121 Post(s)
Liked 97 Times in 63 Posts
The major issue will be tire clearance and brake reach. If you stick with steel there should be no issues with durability unless you bunny-hop or jump on a regular basis.
Framesets that will definitely work (based on personal experience):
- late 60s or early 70s Peugeot PX-10
- late 70s Trek Wisconsin 710/720
- 1960s Ideor Asso
- 1960s Carlton or Raleigh-Carlton
Michelin Mud2 tires should work well if you're expecting to use clincher rims.
kunsunoke is offline
Likes For kunsunoke:
Old 07-24-19, 07:17 AM
nlerner
Here's my gravel bike: '97 Lemond Buenos Aires with 650b x 38mm tires. I had to dimple the chainstays to get tire clearance, but that was easily done in my vise. Main frame is Reynolds 853 and overall weight is around 21 lbs. When I rode it on the 100k route of the D2R2, I used a crankset with 42/28t rings; otherwise, I run it with a compact double, Shimergo drivetrain (10-speed Campy Veloce brifters and 8-speed Shimano mechs w/ a long-cage RD and a 32t large cog on the rear).
nlerner is offline
Likes For nlerner:
