2020 Trek Hybrids - Verve 3, FX 3, Dual Sport 3
Saw the 2020 Verve 3 and FX 3 at my LBS tonight. Both look real nice (Verve for more comfort and FX for more performance). Didn't see a DS, but per the Trek site, they all have similar components across this "3" series. Keep itching for a reason to replace my 2015 FX 7.2 rim brake bike still
Verve - Looks real comfortable, larger H5 45mm tires will help on packed gravel, but more upright and heavy bike
Dual Sport - Only real benefit is the front suspension that can be locked out. Probably last on my list of these three.
FX - Noticeably lighter, but stiffer. Has carbon fork though and is most similar to my current FX (this has the disc brakes, some better components, and a bit lighter). I would move my 1-month old H5 38mm ultimate tires to the FX.
Bikes: 2000 Trek 720 Multitrack (plus)
Quoted: 48 Post(s)
I'd lean towards fx 3 coming from a fx 7.2. But first I'd consider upgrading the FX 7.2 drivetrain unless your dead set on disk brakes. Weight isn't that important and your could offset the steel fork weight with a hollowtech crank. Add a 9 speed rd/shifter/cassette and you might be happier with a custom fx 7.2.
I agree with Pjthomas. FX3 would probably be the better option. I think you would find the Verve lacking since you already have a 7.2.
Thanks for the comments. I never really thought about component upgrades on my current 2015 FX, but do mainly want to upgrade to disc brakes especially for when it's been rainy a bit or the packed gravel turns to wet dirt in a few spots.
My first instinct is that FX 3, but I just hope if I buy it I don't get buyers remorse since it should feel pretty similar to the current. My main likes about that Verve are the more comfortable ride (hopefully) and the much wider version of my current tires (the 2015 FX can't fit the 45mm wide H5 ultimates).
Quoted: 48 Post(s)
I am 63 and in great shape. Work out and have for 30 years or more : Pump iron etc.
I mention this because I'm not some old fart with back issues and aching joints or over weight .
The verve is every bit as nice as the FX3 :
Obviously it's JMO Based on riding both bikes 25 miles on flat concrete, black top and 1 mile of gravel.
If I keep the FX3 I plan on putting some verve options on it/. Although we did swap teh wheels and seat : The Verve just naturally sets more comfortably : The FX would only be superior on flat smooth concrete . And not that much because you feel the cracks where you don't with the verve tires
NO you won't I have the FX3 2020 and My Buddy Bought The Verve 3 2020 : Both awesome bikes No differences in parts : And the verve is every bit as fast , Corners better and is twice as comfortable : So much so I am debating selling My 10 day old FX3 and getting the Verve :
Also: the 45mm tires from the Verve 3 actually fit on the FX 3? I had reached out to Trek support online and they said the largest the FX 3 could take is a 38mm.
Rick53, have you been able to compare the two bikes on a more hilly ride? My wife and I considered the Verve when we purchased our DS3s but I was concerned the more relaxed seat tube angle would hurt hill climbing performance. I was unable to test ride a Verve on any kind of hill but I am very happy with my DS3.
I honestly thought his bigger tires would slow me down . They don't : IMO they are an advantage on every surface but smooth flat cement : LOL Something that you rarely find. Even if I keep the FX3 I am planning to install a Bigger tire. Maybe not all teh way to 45 . At least a 40 maybe a 42 .
My Friend lives right down the road 1/2 a mile exactly : Just an hour ago I road 14 MPH to his place RESTED 5 minutes: Hopped on his bike and went straight back to my house maintaining the same speed : The verve is easier to peddle .
Now that's on Black top country roads : I will try tomorrow to switch wheels again : Problem with that is I think Trek tests and designs these bikes to be the most proficient with the Tire they fit it with. Although MY FX3 seemed less bumpy with the larger tires : It almost seemed as though it was that much harder to peddle :
I need more riding to say for sure : I will say it was really hot the other day . MY Friend is 6' 266 lbs : I am almost 6 ft at 178 . We are both Fairly New to riding ; Especially over 20 miles : I can't say for sure , but had he let me use his bike teh whole way back I'd have been less tired. He definitely wanted his verve back. He said My FX-3 just seemed harder to ride . Maybe because he's big guy who knows
I say more later after I ride more
Bikes: More bikes than riders
Quoted: 1444 Post(s)
Liked 761 Times
You're enjoying the benefits of larger tires. They're real! I've converted my Giant Roam to 27.5" wheels, and am running 2" wide tires on them (they're labeled 47mm, but actually inflate to 50mm). They're basically slicks for the road (Vittoria Terreno Zero). I'm not suggesting that downsizing your wheels to upsize your tires is for everyone, but I'm loving it.
IMG_20190524_183639857 by jnjadcock, on Flickr
IMG_20190524_183704026 by jnjadcock, on Flickr
Likes For hokiefyd:
On a Hybrid that's not smart : On a Road bike I find it still possible : My guess is more weight over the Front Tire helps it balance better then a Hybrid. Which makes it climb better :
My Riding Friend is a Big Guy : His arms are the size of My calves. When it comes to climbing hills I do notice a slight advantage on the FX . Even though I'm sure he's stronger then I am. Keep in mind it's pretty minor .
Thanks for your detailed feedback in this and the other thread as well. Very interesting and helpful (though, now I'm leaning back to Verve . I am 45 and 6'2" 225 lb so probably on the heavier side for some cyclists. The bumpy parts of the paved paths as well as the packed gravel are where I'm thinking the Verve with the 45mm tires would excel. Always about that balance of comfort and performance for sure. I also suppose if I went Verve 3, I can keep my current FX 7.2 if going on a smooth paved ride and then have the Verve for the more adventure trails. Though realistically, I'd probably love whichever new bike I get and never ride the old one again.
Deraill this!
Bikes: 18 Cdale Quick 1, 94 S-Works M2, 98 730 Multitrak, and a few others
Quoted: 143 Post(s)
Liked 421 Times
I have been following the Verve and FX bikes for 6 months now. I originally was planning on the FX2 for my wife and FX3 Disc for me but that direction has since changed. After landing a beautiful gently used 2018 Cannondale Quick 1 for myself from a friend, the focus has shifted for a new ride for my wife. After sitting on the FX and the Verve, she looking at the Verve. FWIW - she's 5'2"
While talking to the LBS yesterday, I learned the 2020 model year brought some changes to the Verve line. The Verve 3 component list has moved up along with the move to the 2x9 (Shimano MT210, 46/30 and Shimano HG200, 11-36, 9 speed). After living with 2x11 on the Quick1, I think there is much wisdom in the 2x setups. With the upgraded components I think the Verve 3 has much to offer over the Verve 2 or Verve 2 Disc. The great debate in our house is which one to get? End of year Verve 2 at substantial savings or 2020 Verve 3 which I think is a much nicer bike but sports a bigger price.
If she'll get the use Buy the 2020 If not 2019
Although as I said earlier : The 2020 Verve 3 and FX 3 Shift extremely Smooth and quick : And the 2 Piece Crank is a noticeable benefit climbing hills
Thanks again for the additional comments. Just makes my choice more back and forth
Bottom line, my plan would be either:
A.) Buy the 2020 FX3. Transfer my H5 Ultimate 38mm tires (bought new in early July) to it along with my current seat (that has a bit more support). Sell my 2015 FX 7.2 with old H2 tires that I still have and the original seat.
B.) Buy the 2020 Verve 3. Leave it as-is with respect to seat and tires and so on. KEEP the 2015 as a separate bike as a backup or if I know only a flat ride. Or sell anyway since I know whichever new bike I get will be the only one I ride.
Likes For stuman74:
As far as Seats go. I actually like the FX3 Seat comfort wise and the New Verve is the same design just bigger. With that Crotch cutout in the middle they are actually pretty comfortable. And I don't have any Butt Fat for cushion At least for me the padded seats, especially thru the nose area. Just don't cut it > With the narrow tongue of these New seats on either bike . I don't see a reason to change . If you did the first option and sold your Older FX . You probably could use teh tires off a New one to help sell it.
So if you want Give Me until Saturday and I'll let you know how much of a difference this made. Also with the Verve 3 just 1/2 miles away I'm going to do some tests using both bikes and My Wahoo. To see at the same speed how far it coasts . Also how many turns of the crank it takes to get to the same speed. etc. As well as Timing How quickly I get to the same speed : Although main interest is to see what roll out actually is with a larger tire. Based on My first experience I'd say just about ZERO:
I'll even PM you to make sure you see it, if you want .
After all not like those Bikes won't be available Monday, if you wait a few days : And if they are sold only takes a day or two to get one : So if you think that might help you out just let me know
Liked 761 Times
Beware: the H5 tires in 35mm are only about 30-31mm tall (as mounted on the rim) and have a pretty thick puncture protection layer, meaning they ride pretty firm. My 2015 Verve came with them (H5 in 700x35) and I found a lot more comfort by going with a larger tire, without thick puncture protection (Continental Speedride in 700x42). I'm not trying to discourage you, but you may find the 35mm H5 to be a pretty firm tire (without much improvement in ride quality).
Give me a Few days : The place where I bought the Bike has a set of H5 in size 35 . They just called me because they knew I was debating a tire change : Some guy bought them last week . Maybe used them a few times : Store says I can have them with the Inner tubes for $30.00 > They installed them and took them off. They tell me everything is as New : The Guy said he'd take Thirty Bucks and left them at the store : I also have a Ritchey Adjustable stem should be here today. So I am going too do those 2 upgrades and see before I sell and get a Verve 3 >
HOWEVER, I did just get back from an expensive lunch break....bought the FX 3 Came down to it being (hopefully) more similar to my current ride with some upgraded components and the brakes. The little test ride in the lot was fine, as I expected considering I was wearing work clothes, but jumped in the deep and and went for it. Hopefully I have time tonight to swap at least the tires and seat with my old FX and give it a roll before the sun goes down.
Likes For stuman74:
I have 2020 Trek Verve 2 XL , with 700x45 tires. Very stable on the road, really love it!!!
Deraill this!
Quoted: 143 Post(s)
Liked 421 Times
Another upgrade the Verve 3 received for 2020 is the 2x9 setup and the rim break option is gone.
(Crank - Shimano MT210, 46/30, chainguard, 170mm length and Cassette - Shimano HG200, 11-36, 9 speed)
over the 2019 3x9 setup
(Crank - Shimano Acera M371, 48/36/26 w/chainguard and Cassette - Shimano HG20, 11-32, 9 speed)
I find the 2x setup to offer more than enough gear choice.
FWIW - My wife just purchased a 2019 Verve 3 at the LBS. Very smooth bike that is easy to ride.
My 2020 Trek Verve 2 XL
2020 Trek Verve 2 XL on our lake
2020 Trek Verve 2 XL - getting ready for a riding
2020 Trek Verve 2 XL, 45mm tires
Likes For LeoGrand:
Quoted: 576 Post(s)
Liked 1,001 Times
