Fast switching between slicks and stubs on my MTB
So I've recently started using my MTB to commute to work. Traditionally my bike saw mostly trail use with occasional road use during family rides so the need for different tires wasn't warranted. But now I'm logging around 100mi a week commuting to work with occasional trail use and would like to switch to street tires. This seems simple enough but i still want my trail tires quickly available especially because my commute starts at a state park with some nice trails.
I was wondering if anyone has experience running two sets of quick release wheels (one with road tires, the other with trail tires). I would need the same size cassette on both the rear tires. My biggest concern would be the high/low stop points and the shift points on the rear derailleur. Are bike wheels generally manufactured to a tight enough tolerance that i could simple pull one set off and put the other set on and not have any issues? Or would i need to buy two new sets of wheels to make sure they match (my current set are 20 years old)?
Prefers Cicero
Any problem with having two bikes? A new commuter bike would quickly pay for itself in the gas costs or transit fare you are saving by commuting, and might give you a more comfortable ride, and you could carry your gear on a rack to avoid backpack-induced back sweat. You could also get fenders to extend your commuting into light rain. When I was working full time I rode 140 days a year and took public transit the other days for about $5/day. That's $700/year in savings by riding - enough to get a good second hand commuter bike two or three time a year if I wanted to!
20+mph Commuter
Bikes: Surly LHT, Surly Lowside, a folding bike, and a beater.
Quoted: 1434 Post(s)
Liked 331 Times
There are unlimited choices in tires with raised slick centers. Pump them up firm - you have a "road" bike. Bleed some air out so the tire flattens out a bit to engage the knobbys - you have a "mountain" bike. There are so many choices that I even hesitate to offer examples.
This is one of the cheaper models: https://www.biketiresdirect.com/prod...s-26-inch-tire
You can find this style of tire in every conceivable configuration. More knobs, fewer knobs with more slick, very skinny center ridge as compared to my link, etc. Two tires in one! This is my suggestion.
Quoted: 1074 Post(s)
Liked 295 Times
My "nice" MTB has three sets. Dry, muddy, icy.
The wheelsets for the MTB is more of a mixed bag.
One even has reground cones.
Two of them have been matched by adding shims under the locknut on one wheel.
The latest pair to be integrated was a tad wider, there, I've settled for a twist on the barrel adjuster instead of reshimming the others.
Virgo
Friendship is Magic
Bikes: old ones
Quoted: 26413 Post(s)
Liked 10,379 Times
...what the others have said already. In general, you almost always end up having to make some small tweaks unless the wheels, rims, and cassette are identical. If nothing else, you usually need to adjust the rear derailleur to get it to properly index, because it won't sit in the same position unless the hubs are really close.
But there's no reason you can't have two identical stets of wheels. Racers do this wheel switching all the time and seem to come out of it OK.
Quoted: 76 Post(s)
Liked 76 Times
i find that i don't really need a knobby tire for dirt/gravel/off road, as long as the tire is high enough volume. i'm currently using these $30 eastern tires on my 26er everywhere drop bar mountain bike thing and they kill it on asphalt, single track, gravel, dirt, everything i've tried so far. even on loose, steep climbs they have plenty of traction.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
I agree with this:
