Important cycling clothing question..
Something that I’ve been pondering for a while now is the question ...
Why don’t cycling shorts have a fly? I have several pair of liner shorts designed to be worn with pants or shorts in lieu of regular underwear and none of them regardless of brand have a fly..
I’ve been giving this a good deal of thought and can’t come to a good rationale why a manufacturer wouldn’t include one for men’s liner shorts ...
clearly this is a problem in need of a solution
Quoted: 2588 Post(s)
Liked 4,823 Times
Running shorts don't have a fly - they are expected to be pulled down a bit (perhaps after untying the drawstring if so equipped) so you can do your business. Same with cycling shorts, although it's a bit more difficult with bib versions.
DD
DD
Quoted: 1372 Post(s)
Liked 1,749 Times
A fly? What for? Just slip the little fella out of the shorts leg of choice, and geterdone. This works well when riding, for those too lazy to dismount to weewee. Not sure that this works as well for the opposite sex.
Quoted: 4559 Post(s)
Liked 2,802 Times
Some pads in cycling shorts cover well above the pubic bone. A fly or zipper would need to go through the pad. An expensive tailoring solution to a practically non-existent problem with shorts, which are easy to pull down.
Bibs are a hassle. I have only one set and don't often wear them. Too much trouble to untangle for a quick rural roadside urination when necessity strikes. I occasionally wear bibs on routes with ready access to toilets. But not often.
I suspect the preferences for bibs over shorts are influenced by body types. Folks who find themselves tugging at shorts constantly to hitch up the waist or pull down the hems prefer bibs. But snug fitting shorts fit me well enough that I don't need the suspenders to keep 'em in place.
I do have a set of Aero Tech Pro shorts in medium that now fit me loosely after losing 25 lbs since buying 'em, but I can still wear those as liners with baggy shorts or jeans for longer casual rides on my hybrid. But by themselves they sag too much and look even more geeky than good fitting shorts.
A fly or zipper would probably affect compression too. I like 'em very snug and supportive. Seems to help reduce fatigue in my thighs and lower back. There's a fine line between snug and cutting off the circulation, though.
That's why lycra stretches. Anyway, the answer is chafing. Some of us can still ride back flat to the wind if we choose. You really don't want a zipper chafing on your junk.
FYI Kucharik will put a fly flap into your shorts if you so desire. And of course MTB shorts generally have a regular fly.
For a liner, you might try hiker's type synthetic boxer briefs instead. That's what I wear if i ride in normal shorts. Cheaper than specialized liners and work fine.
Quoted: 2337 Post(s)
Liked 2,813 Times
because it takes away from thinking needed for super bright (or ugly as the significant other says) designs like you can get from aerotech
Quoted: 2952 Post(s)
Liked 3,106 Times
There's no way I'd want a zipper down there when I'm on a bike. Even with bibs, it takes no effort to pull them down far enough.
Quoted: 3011 Post(s)
Liked 3,788 Times
Am I the only one rocking crotchless bibs?
Likes For iab:
Liked 2,802 Times
Likes For canklecat:
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
Now I have this mental picture that just won't go away....................dammit for reading down this far
And thanks to the next guy that bought up Borat, urghhhhh.............
Bill
Bill
Semper Fi, USMC, 1975-1977
Likes For qcpmsame:
Likes For TenGrainBread:
Likes For RobbieTunes:
Veteran, Pacifist
Quoted: 3897 Post(s)
Liked 4,829 Times
I just make sure my cycling shoes have holes in the bottom for drainage/run-off.
And I don't wear tall socks.
Liked 2,802 Times
A fly would just add a potential source of chafing, and for no benefit; having an elastic band for waste retention makes a fly redundant.
Likes For HTupolev:
Liked 2,802 Times
Liked 2,802 Times
Quoted: 4792 Post(s)
Liked 3,918 Times
Bibs? Clip-on suspenders work really well (and quickly stretch out that objectionable waist elastic).
Holes in the soles of shoes - yeah. First race - pouring rain for 105 miles. Peloton jokes was on the flavors of various tires. Peloton woes - to those whose shoes didn't have holes and whose feet were awash for 4 1/2 hours. Those of use with the holes never thought about our feet.
Ben
Ben
Likes For Last ride 76:
Semper Fi
Liked 358 Times
I see what you did there........
Perhaps these are all Freudian slips, although a slip would bunch up and chafe, unless its worn on the outside.
And, that opens a totally new line of thoughts, either the shorts or when outdoors.
Bill
Bill
Old fart
Quoted: 3583 Post(s)
Liked 3,395 Times
Likes For JohnDThompson:
Old fart
Liked 3,395 Times
Semper Fi
Liked 358 Times
Bill
