What's your gear ratio?
Quoted: 15 Post(s)
So I tried searching and couldn't find a thread where people just post their choice of gear ratio(s for multiple bikes). No arguing about it just your ratio and why you chose it for where/how you live/ride.
Mine is currently a 53-19. Because I got used to living in flatter places than I currently do.
Quoted: 1332 Post(s)
Liked 398 Times
For fixed road riding, I'm usually on 48-17. I can push it up hills pretty well and maintain decent speed at a comfortable cadence on flats. Longer/steeper climbs make me want a lower gear, but I've still been able to get up some good ones on it (though they hurt like a mother****er). And I have a 15 on the other side for track sessions.
I live in Florida, so 99% of my riding is flat. I'm also just coming back to cycling after a few years off, so my legs and overall fitness aren't great. I run 48x18, or 70", which feels just right. Fast-ish group rides are a bit spinny, but getting over the one short climb I do regularly encounter isn't too bad even when I'm tired and facing a headwind. I can see myself going to 48x17 or 48x16 soon, though.
Bikes: 2015 Aventon Diamond
Quoted: 151 Post(s)
I live in FL too and there isn't much elevation. The hills I do ride typically are short and can be pushed up at a relatively quick pace. I ride 48x15 (84gi) most of the time, but sometimes want a bit more spin so I swap to 48x17 (74gi)
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
71" (45/16) in spring/summer/fall, 59" (42/18) in winter, although I'm thinking of dropping to 56" (42/19) next winter.
Bikes: State 4130 Matte Black 6, Artic White Wabi Classic
Quoted: 20 Post(s)
Was running 46/16, but with the winds we get here in the Columbia River Gorge I went with 46/17. Very happy so far.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
48x16 offers a pretty good challenge on the open road.
Sometimes a 15 tooth sprocket goes on for long, flat rides on the rail trail.
46x16 for pretty much everything, I have a 17 I used to swap in but figured there was really no reason to.
Quoted: 1062 Post(s)
Liked 665 Times
46x19 on 27" wheels, or 65 gear inches. But I'm generally a slowpoke, and am happy to bring up the rear. I'm also in an upright riding position, so I have to live with the aerodynamic penalty.
Riding this ratio has actually been a bit of a challenge, and forces me to ride faster in order to get into a decent cadence. When it gets too easy, I'll find a bigger ring or get a hub that lets me change cogs.
Quoted: 15 Post(s)
So I just found a decent gear inch chart. I've apparently been riding a F*$&ing stupid ratio (the above stated 53-19) at 75 gear inches.
I also don't feel like as much of a weiner eyeing this 43 chainring anymore.
Bikes: Custom Mercier - Velo'v - Peugeot FG conversion
I took Sheldon Brown’s advice and went with 42x15 (75”). An excellent middle ground for speed and getting up hills.
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2640 Post(s)
Liked 3,153 Times
42/15 or 17 t road
51/15 track
51/15 track
"Your beauty is an aeroplane;
46/19 (64" on 25c tires) with a lot of longer rolling hills of 5-8% grades and steeper, punchier climbs in the 10-12% range in my area and I'm currently sitting at 225lbs so I opted for a lower GI. Overall I'm able to make most hills in the area but quickly spin out on the flats so I take that as a much-needed recovery period until the next set of hills.
More seasoned SS roadies in the area have suggested 46/16 (76") so I'm gradually working that direction.
Quoted: 823 Post(s)
Liked 1,395 Times
45x17 on my Gitane TdF conversion, 42x16 on my purpose-built Mercian, both of which are roughly 70-in gears on 28 mm Panaracer Paselas. I mostly ride over rolling terrain in an area bounded by man-made lakes. I keep 45x19 or 42x18 (63-ish-inch) on the other side of the hubs, but it's been a while since I did any serious dirt road cycling.
Quoted: 15 Post(s)
I'm in a pretty hilly area and in the city i needed to be able to accelerate a bit quicker. So I dropped down to 68gi and it's been alot easier and quicker to get around. If I were on a fixed gear I would go a bit larger but for my commuter/grocery getter I like the downgrade.
got the climbing bug
Bikes: one for everything
Quoted: 632 Post(s)
Liked 913 Times
Fixed bike is stock 48/18 for now...
SS MTB 29er is 32/19, very hilly so spin out quick when it gets flat
Rule #10 // It never gets easier, you just go faster.
Bikes: Murphy (Marty)
Quoted: 11 Post(s)
50 x 16 on 700c tires. I live in NYC so its pretty flat. Also the setup is single speed, not fixed.
Riding by myself 70gi. Rolling hills and grades only 26-32 feet per mile of elevation unless I want to ride real hills and I would ride a geared bike for that. With a group I ride 75 gi and draft a lot. A really fast group on flats I've used 80 gi. But I like 70gi for general riding around. Problem here is wind not hills.
Jedi Master
I have 3 chainrings (44,45,46) and three cogs (16,17,18) which gives me ~65-75 GI with 1-2 inch steps. I start with 44/18 in the spring and work my way up as my fitness improves throughout the season.
Liked 2,568 Times
Quoted: 4806 Post(s)
Liked 3,932 Times
Ben
