Titanium Brake Centerbolts
Quoted: 380 Post(s)
Liked 541 Times
Doesn't seem as tho such a thing exists for single pivots, but that make much sense to me. I mean, what with all the other/everything titanium, why not centerbolts. In the grand scheme of WeightWeenieDom that's quite a chunk of weight.
inquiring minds, etc
Charlie
Charlie
Quoted: 3464 Post(s)
Liked 2,831 Times
Lighter than a full ti pivot bolt.
Jim Merz has made full ti centerbolts, mostly or exclusively in the drop bolt style.
Quoted: 930 Post(s)
Liked 1,293 Times
There's a guy in southern California who makes titanium drop bolts for Campy brakes. I know because I have one. I don't know if he makes straight bolts. He's on eBay somewhere.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
To answer the "why not?" question, a bolt of the same radius, etc., made of titanium instead of steel will be significantly weaker. A brake bolt would be low on my list for such a substitution.
Likes For Cyclist0108:
Liked 2,831 Times
They do flex more.
long ago when I had a lathe I made one out of 6061 T6
rear only.
never broke
also made the eccentric cam part in aluminum
never bothered to weigh them but cool and no rust.
late Super Record pad holders were aluminum with steel studs- lighter, no rust.
hey, when one trains often along Pacific Coast Highway, no rust is appreciated.
rear only.
never broke
Quoted: 1641 Post(s)
Liked 831 Times
Are the Ti bolt threads cut or rolled?
Rolled threads will always be much more preferable, as it's less likely to crack......
I guess the real question is, can threads be rolled on to Ti bolts?
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Quoted: 4722 Post(s)
Liked 3,038 Times
Yes, you can roll threads into titanium. In fact, it is preferred due to the metal's high notch sensistivity.
Liked 3,038 Times
Here's the previously mentioned OMAS Ti brake bolt kit.
Likes For T-Mar:
aged to perfection
Quoted: 839 Post(s)
Liked 1,258 Times
it's Jim Merz, "PortlandJim" on ebay, and his stuff is top of the heap, really excellent.
right now he only offers Cinelli seat bolts, but other parts are available.
really top quality items.
/markp
/markp
Steel is real
Bikes: 40 - accumulated over 40 years
Quoted: 375 Post(s)
Liked 1,085 Times
By some deemed as unsafe but as with most things it depends on for what purpose. For a time trial bike where you might brake (more modulating speed than stopping) for a turn a couple of times...
Ergal and ti.
Ergal and ti.
Quoted: 581 Post(s)
Liked 921 Times
Absolutely not.
Any part or fastener that is restricted to the geometry of the original steel part should not be replaced with titanium UNLESS it is a very low-load and non safety-related part. Waterbottle bolts? Sure. Brake mounting bolts? No.
If the part and mating components could be redesigned to use a larger bolt or part then yes, but simply swapping in the weaker material with no other mods on a safety related part (to save single digit grams) is a bad idea.
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Jamis Citizen 1, Ellis-Briggs FAVORI, Rivendell Clem Smith Jr.
Quoted: 414 Post(s)
Liked 920 Times
Galli made a Criterium brake set with titanium center bolts in the late '70s/early 80s.
I like the drillium levers themselves, but lever effort is high, perhaps due to overly strong caliper springs?
Steel is real
Quoted: 375 Post(s)
Liked 1,085 Times
Absolutely not.
They even drilled the handlebars (can be seen in this picture if looking carefully).
I am not saying it is for everybody. I am saying it depends.
Likes For styggno1:
Quoted: 581 Post(s)
Liked 921 Times
styggno1 Thanks for that, but proof that is has been done is not proof that it was ever a good idea. Pros used to use cocaine and strychnine as PEDs, and those also are not a good idea if you value your physical well being.
Steel is real
Quoted: 375 Post(s)
Liked 1,085 Times
Quoted: 2588 Post(s)
Liked 4,824 Times
Absolutely not. Any part or fastener that is restricted to the geometry of the original steel part should not be replaced with titanium UNLESS it is a very low-load and non safety-related part. Waterbottle bolts? Sure. Brake mounting bolts? No.
2018:
The bike in question went through every kind of punishment imaginable; Cino 2014:
Braking is absolutely confidence-inspiring or I wouldn't continue to use them - as I fully intend to do.
DD
Likes For Drillium Dude:
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
I have titanium crank fixing bolts one one crank. They seem to work fine but I pretightened with steel ones first.
Likes For 52telecaster:
