Is this too low PSI?
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
I have a Poseidon Redwood (which I ride as a light MTB) with 30mm external/26mm internal tubeless ready 650B rims. With 2.6” tires I’m finding with my weight (155lbs) and bike weight (about 30 fully loaded) that 18psi rear and 12psi front gives the most comfort without bottoming out, no burping on turns or getting squirmy on my rides. This is while running the tires tubeless.
I think I have to get to 8psi before rolling resistance is affected and 7 ish psi before handling gets impaired with this setup.
with that in mind and 47psi max for these Panaracer tubeless ready tires, what are your thoughts on 18/12 R/F psi? Is it likely I’m in the “sweet spot” or too far from it?
I’m new to tubeless and just want to double check with more experienced riders
ty for your insight
ty for your insight
The bottom limit is probably when they burp or you get rim strike. That said optimum can be based on different ride criteria. Where I usually ride I can't get anywhere near that low without rim strike even with careful riding. There are lots of roots where I ride and I run a lot of air (30# F, 36# R) to avoid bottoming. I usually let the pressure drop quite a bit before pumping and find that I just adjust by picking my lines more carefully. When I air up I quickly notice that my speed for my morning loop is immediately substantially faster. I don't think it has anything to do with rolling resistance, but I subconsciously take slower lines to avoid bottoming out and having rim strike.
Given that, I can get a slower more comfy ride on softer tires or ride faster and get jolted and rattled and blast over the sharp edged stuff. That may not be the typical choices, but that is what I have found on the trails I ride with the setup I use. Personal preference could make someone choose either.
There are other trails that I sometimes ride that I prefer the lower pressure for and don't think I take a speed hit for the lower pressure. I don't ride there often enough to have real data though.
Bottom line... As long as you aren't getting pinch flats or burps choose a pressure that gives the ride characteristics you like, but lower isn't always better.
Likes For staehpj1:
Quoted: 345 Post(s)
Liked 237 Times
in reading your post I realize I don’t ride very fast through the rough stuff. In fact I ride the brakes lightly the whole way downhill on the rough as it would just be too much for me. I’m not trying to win any speed records but just have fun while being safe.
Expired Member
Quoted: 3683 Post(s)
Liked 5,451 Times
Quoted: 345 Post(s)
Liked 237 Times
Something you didn't like about the answers when you posted this before? same same
if I could go back, I would have only posted the question here
Likes For Symox:
Quoted: 345 Post(s)
Liked 237 Times
Update
I’m finding 14/12 R/F psi to work well on local mountain trails. Silca calculator predicts 13/12.5 for my setup on rough gravel and 18.5/18 for tarmac
i definitely prefer the low psi for trails. Way more comfy and great climbing traction. I’m a convert of tubeless for mtb!
