1X10 Sram or Shimano
Old 01-17-15, 07:20 AM
wvridgerider
Bikes: Gunnar Crosshairs, Surly Karate Monkey, Specialized Fuze, Bianchi Volpe, too many others and a lot of broken frame
Quoted: 35 Post(s)
Liked 70 Times in 21 Posts
So I did the 1X9 and really like it. I do need the Wolf tooth 40 in the rear though. So this is what I have and not sure which way to go. I have Sram XX shifter and rear derailure. I also just aquired LX shifters,XT rear and XT Cassette. Should I go Shimano or Sram? This should be a nice debate. The good thing about the Shimano is that I will not need to buy a new cassette. What do you think? I dont care about weight.
wvridgerider is offline
Old 01-17-15, 09:59 AM
Canker
Quoted: 330 Post(s)
Liked 209 Times in 133 Posts
Well first off a sram and shimano 10 speed cassettes are interchangeable so you can go either way without having to buy a new cassette. What isn't compatible is anything 9 speed with anything 10 speed. There is no good answer to the sram vs shimano debate.
Canker is offline
Old 01-18-15, 01:50 PM
DMC707
DMC707's Avatar
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times in 746 Posts
This
XX shifters are a bit higher end than LX shifters - i would use the better shifters, good shifters can make a lower tier rear derailleur seem like magic --- so i'd try the XX stuff with the XT cassette and the One Up or Wolf big cog ---- One up comes with a 16t cog too, take out the 15 and 17 and the replacement 16 strikes a nice balance
DMC707 is offline
Old 01-20-15, 07:03 PM
tk1971
tk1971's Avatar
Bikes: Nishiki Prestige, Reign, IH Warrior, Rockhopper, Brompton, Q-Bike, Forever, Free-Ride, Dahon, Merckx Premium, Litespeed Teramo, Raleigh MTi 1000, Motobecane Fly Ti, OnOne 456, Kona Unit, Transition TransAM
I used an XTR 10 spd shifter with an SLX shadow plus rear derailleur, XT 11-36 cassette and the One Up 42 / 16 combo. I use a Race Face Narrow Wide 30t in the front.
After the first ride on that lightweight bike, I found that I don't need the 42 and put back the XT cassette in the 11-36 configuration.
Instead, I converted my All-Mountain bike to a 1x10. I figure with the extra weight, the 42 would go nicely with it. BTW, I've also installed the RADR cage on the rear derailleur.
tk1971 is offline
Old 01-20-15, 07:11 PM
osco53
Old Fart In Training
osco53's Avatar
Quoted: 12 Post(s)
Liked 22 Times in 16 Posts
Nice looking scoots,
I got just too many wide open spaces with long climbs and long descents to go 1X
Had a 1x9 for a time, back on my 3X9 for good, I like to keep all my options open.
Funny things is, I only use about 8 gears overall but two are on that granny ring and two are on the big ring...
,,,,Plus my bike is a 30 pounder....
osco53 is offline
Old 01-21-15, 12:41 AM
Canker
Quoted: 330 Post(s)
I just went 1x9 on my surly rigid with a 30 tooth up from and a 12(or whatever)-36 cassette and also live in Wv. It isn't easy lol. I'm going to live with it for awhile but I have my eye open for cheap 10 speed parts so I can get one of the 40 or 42 tooth add on gears. Plus that 12-36 9 speed cassette is a boat anchor since they only make a low end part with that range in 9 speed.
Canker is offline
Old 05-17-15, 02:51 PM
wvridgerider
Quoted: 35 Post(s)
Update, switched to a 1X10 and it works good in the I ride. I am running a 30 up front with a Wolftooth 42 in the rear. I am surprised at how well the wolftooth cog shifts. If I were riding on the road or long fireroads I would not run the 1X10, I would stick with a 2X10.
Old 06-19-16, 10:32 AM
wvridgerider
Quoted: 35 Post(s)
Update Well I have been riding this setup for sometime now. I am still running the same chain, cassette, woltooth 42 and Race Face 30 on the front. I wish I would have kept track of how many rides I did on this but I know one thing, it works great and the chain is lasting a lot longer than any I have ridden in the past, No sure if it is due to the single chainring or something else. I know I will be redoing the drivetrain soon but everything is working good except one of the smaller cogs.
The only downfall with this setup is riding on a road. I will only use the two smallest cogs.
Old 06-19-16, 05:11 PM
osco53
osco53's Avatar
Quoted: 12 Post(s)
Well Things change,
I got Stronger and my bike got lighter,
Now I am a 1x11 fan running the Shimano M8000 system
32T Race Face Narrow Wide up front
11-42T out back
No more chain slapping a front cage or chain stay,, so quiet I even took off my Lizard Skin.
osco53 is offline
Old 06-19-16, 10:17 PM
Canker
Quoted: 330 Post(s)
Groupsets | Chain Reaction Cycles
Has the 11 speed XT groupset including crank for $299 or without the crank for $239 kind of hard to go wrong with that. For people that have a 10 speed setup already Sunrace has 11-40/42 10 speed cassette now for cheaper than you can buy just an add on cog and less clunky.
Canker is offline
Old 06-20-16, 07:07 AM
osco53
osco53's Avatar
Quoted: 12 Post(s)
My 11 spd 11-42 cassette fitted my 9 speed shimano hub
Cassette $135
Cassette Is just starting to show wear on the aluminum 42T cog,, still works like new, 8 months now, I ride 6 to 8 times a month.
Derailleur with the external user adjustable clutch $120
Shimano's baked on Teflon coated chain $38
Rarely needs cleaning, so quiet and smooth shifting, NOTHING sticks to it unless I Over Lube It.
Shifter $75 and has Indexing that's second to none,,,
Race Face Narrow Wide 32T chain ring,Hardend aluminum,,no wear yet,,Fitty bucks...
$418.00,
Less my Swamp Discount of 10% at my LBS,
$376.20 plus tax
OTD 402.53,,,,,,,,,,OTD (Out The Door)
8 Months,, only one adjustment of ONE single click on the cable at the shifter... Perfection~
The Lizard skin is gone, no need at all, this drive train is silent,,Love that aspect I do...
osco53 is offline
Old 06-20-16, 10:22 AM
stockae92
Quoted: 48 Post(s)
I have an old XTR M975 3X crank, I wonder if this chain ring would fit or do I need a different kit?
Shimano XTR 1x11sp Gear Kit Bundle | Chain Reaction Cycles
stockae92 is offline
Old 06-20-16, 01:25 PM
Canker
Quoted: 330 Post(s)
Looks like the XTR M975 uses the standard 104 BCD chainring so I don't see why not.
"Note: 32T 104mm BCD and all 94mm BCD have offset chainline. These have built in 2mm spacers and threads. (use min. 6mm long bolts)"
If they don't come with bolts you can probably just use your current granny ring's bolts, just measure them first to make sure they are long enough.
Canker is offline
Old 06-20-16, 07:44 PM
wvridgerider
Quoted: 35 Post(s)
I have been considering the Shimano 1X11 upgrade. Really a good value. I ride a Race Face 30T narrow wide, It works great for me in western West Virginia.
justfitme
Bicycle Mechanics
7
09-02-11 07:04 AM
Barrettscv
22
11-07-10 04:41 PM
Barrettscv
15
08-14-10 08:38 PM
notenoughdaylig
7
03-08-10 07:38 PM
maralv
Bicycle Mechanics
0
02-22-10 09:25 AM
