just joined new campy chain. made it too long. will I kill myself if...
Old 10-14-08, 08:02 PM
cuda2k
Unique Vintage Steel
cuda2k's Avatar
Bikes: Kirk Frameworks JKS-C, Serotta Nova, Gazelle AB-Frame, Fuji Team Issue, Surly Straggler
Quoted: 57 Post(s)
Liked 225 Times in 56 Posts
will I kill myself if...I remove the joining pin I just put in, take out a link, and put the pin back in. Or should I just be smart enough not to ride in the small/small combo till I get over to the LBS and fork over some cash for a new pin.
cuda2k is offline
Old 10-14-08, 08:08 PM
cascade168
Klaatu barada nikto
cascade168's Avatar
Not a good thing to reuse.
Do the smart thing and get a new pin. Better yet, get a Wipperman or SRAM master link and then you can shorten to your heart's content. And, you can easily fix your chain out on the road.
Although I'm guessing you're not using your Campy chain on a mountain bike, good advise for all mtb'ers is to always carry a spare master link and a spare RD hanger. Just a few grams of extra weight and those two small parts will save many, many rides.
cascade168 is offline
Old 10-14-08, 08:18 PM
cuda2k
cuda2k's Avatar
Quoted: 57 Post(s)
Nope, not a mtb. Just an 83 Gazelle Champion Mondial, 531c steel frame. Good advise on the master link and hanger. I started carrying a good chain tool after a number of chain mishaps (thankfully none being my chain) on club rides this year. Till I'm climbing the alps, I'll trade a few grams for being prepared.
cuda2k is offline
Old 10-14-08, 10:20 PM
UnsafeAlpine
Domestic Domestique
UnsafeAlpine's Avatar
Bikes: Brand New Old Catamount! Schwinn Homegrown, Specialized FSR, Salsa Vaya, Salsa Chile Con Crosso
Liked 6 Times in 6 Posts
yeah, het the master link or buy the $20 freakin' pin. Don't reuse the old one.
UnsafeAlpine is offline
Old 10-15-08, 07:35 AM
HillRider
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
AFAIK, Campy doesn't use a single replacement pin like Shimano but a short section of chain with pins at each end. I agree that a Wippermann Conex link is a better, cheaper and more versatile fix.
HillRider is offline
Old 10-15-08, 08:04 AM
carpediemracing
Bikes: Tsunami road bikes, Dolan DF4 track
Quoted: 385 Post(s)
Liked 180 Times in 102 Posts
Campy uses a single special pin to join the chain. You can push another pin out, but like Shimano you can't push one of the special pins (used to join the chain) out.
How "too long" is the chain? If it isn't hanging in the small-small, you're fine. It's actually how I cut my chains - longest possible that doesn't hang in the small-small. I use a 39x11 for reference although I sometimes have a 12, and my large ring/cog combos range from 53x23 to 53x25T and the chain is longer than it needs to be, so it has less friction.
If it's borderline you can use the A/B-screw on the rear derailleur to pull it back a bit - that will take up some slack, but at the price of sacrificing a touch off the shift speed.
If it hangs in the small small then I'd get a pin, take out a pair of links, and rejoin using the new pin. If you have access to a Campy chain tool (10s chains) then I'd try and use that, it's much more fool proof and much less stressful to use.
cdr
carpediemracing is offline
