Suggestions for a CO2 cartridge pump?
Search showed only some old threads. I have a couple of inexpensive Decathlon ones, which do the job, but wanted something which would be able to release only part of the CO2, so that the cartridge could be saved for another use in case of another flat on the same ride. Anything that does that?
Advocatus Diaboli
Quoted: 4735 Post(s)
Liked 1,532 Times
Anyway, I use the simple and small PDW Shiny object which has a screw valve to start and stop inflation. Works well.
I haven't tested it for how long it holds the CO2 contents after installation though.
PDW Shiny Object
Likes For Sy Reene:
Non omnino gravis
Likes For DrIsotope:
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,836 Times
I use mini-pump for first 30psi, then CO2. I have blown new tubes trying to go from uninflated to 100psi in under a second.
'Saving' CO2 is a bad idea, IMO.
I use unthreaded cartridges and buy them by the box (24, I think) from sporting goods stores. No need for threaded setups unless you are a weight weenie or have no on-bike storage space
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
I use the Lenzyne Twin Speed, small and easy to use. In fact, had to use it on yesterday's group ride, quick and easy.
https://www.amazon.com/LEZYNE-Speed-...r=8-6-fkmrnull
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Lezyne Trigger Drive allows short or long bursts.
As a very practical matter the leftover Co2 can release when you don't expect it so don't carry it in your pocket. I had one go "Whooosh!" in my saddle bag as I finished up the ride.
Agree with the others about carrying both a pump and Co2.
Outdoor Gear Lab does great pump reviews: https://www.outdoorgearlab.com/topic...e-pump/ratings
The Lezyne Carbon Road Drive would match your Canyon nicely.
-Tim-
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
As above, don't worry about "saving" C02 as you use most of it and whatever is left is likely to leak out over the next few weeks anyway.
There are TONS of C02 inflation devices out there and already plenty of threads. My personal preference is one that can take UNTHREADED cartridges which can be bought much more cheaply than the threaded ones.
One final word: if you buy one, use it in your garage first so you are comfortable/familiar with how it works and the technique. All too often I have had a friend try C02 for their first time on the road for a flat and the failure rate is very high in that case.
Advocatus Diaboli
Liked 1,532 Times
+1
Likes For Sy Reene:
Quoted: 241 Post(s)
Liked 232 Times
I have several CO2 inflators for both threaded and unthreaded cartridges. I quit using the unthreaded after I had 2 incidents where the inflator wouldn't puncture the CO2 cartridge. I've never had that issue with the threaded styles.
My favorite inflator is the PDW Shiny Object. Light, well made, and rebuildable but it is a little expensive. A close second is the Planet Bike Red Zeppelin. These are cheap (we picked some up for a bike commuter seminar and gave them away along with a CO2 cartridge.) and really easy to use. I don't like that this one needs to be threaded onto the stem, but most people thought it made it easier to use. Both of these will save the "extra" CO2 - I had the PDW hold pressure for almost 2 months - but realistically a 20g cartridge is just enough to get a 25mm tire to proper riding pressure so there shouldn't be much left to save.
Quoted: 18415 Post(s)
Liked 15,553 Times
If you ride tubeless there may be times when the contents of the entire cartridge is not need in one shot. Nice to be able to save some in the event of another loss of pressure during the ride.
I have had several CO2 systems over the years. Never have I had one that does not let you control how much gas in released. They have all had some sort of thumb mechanism that you press and release. Currently using an older model from Genuine Innovations:
https://www.genuineinnovations.com/
I would definitely go threaded.
And practicing first is great advice. I too have seen first-time users fail on the road.
Quoted: 20810 Post(s)
Liked 9,456 Times
I was under the impression that CO2 and tubeless didn't play together well - is that fake news?
Non omnino gravis
I mean, I've only had to add air from a pump a handful of times, and several of those were because the idiot on the saddle forgot to check the sealant level, got a puncture, and the tire slow-leaked down.
My new favorite CO2 tool incorporates my other favorite for tubeless tires - Dynaplug. With this inflator, you can plug the tire and inflate it in one motion. Genius. It's also controllable in metering out the CO2. I don't think saving some of the CO2 is all that practical for more than about a half hour or so, but the ability to control it's inrush into the tube is a great deal though.
Dynaplug® Online Store | Dynaplug® Air Tubeless Bicycle Tire Repair Kit
Liked 15,553 Times
- Soli Deo Gloria -
Liked 736 Times
My guess is that inflating with the valve at the six o'clock position should be avoided.
I could be entirely wrong but that is what I seem to remember.
-Tim-
Likes For noodle soup:
Advocatus Diaboli
Liked 1,532 Times
Liked 15,553 Times
Advocatus Diaboli
Liked 1,532 Times
I have a threaded one, and I never really planned on reusing them, because I jsut wouldn't trust the seal for the length of time I go between flats.
BUT, one day after I had a flat, I put the CO2 and 'pump' back in my saddle bag with the CO2 still threaded on, and the valve closed. Months later...found it on there, unscrewed it just assuming it was empty - got a huge WHOOOOOOOSH of CO2 as I unthreaded it. Scared the hell out of me haha.
Thanks guys.
Not really from a POV of cost saving, but running TL, I have had occasion that the leak persists slowly, and I need to refill. I don't use a full cartridge for a fill, so, even though I carry 2, if I can save some it will be worth it. Just for that ride, till I get home.
I am looking at the Lezyne Control Drive.
Thought of getting that, as I love the Dynaplugs too, but I think that goes in too far for road tyres? I read that somewhere. Have you had occasion to use it?
Not sure what you're thinking exactly, as most CO2s have only about enough gas to inflate one tube, OTOH, there may be sense in using a CO2 in conjunction with a mini-hand pump.. Eg. use the pump for the first 40psi when it's still easy to pump, use a Co2 for the last half of the inflation and keep half of the Co2 for another top-off.
PDW Shiny Object
PDW Shiny Object
Quoted: 389 Post(s)
Liked 255 Times
Just found this on Amazon:
https://www.amazon.com/Portable-Infl.../dp/B071G62NDQ
I have something similar from Nashbar that I bought years ago which uses unthreaded cartridges, strangely, never needed to use it.... (yet).
