Nishiki Serial Number Database
#101
Quoted: 4722 Post(s)
Liked 3,038 Times
thanks T-Mar for clearing that up for me. i like knowing a little history of the bike. i am still working on cleaning in up. i still need a new front tire and new tape for the handle bars. and i have to find a tool to take apart the bottom bracket. actually one to get the cranks off so i can lube the bottom bracket. no telling when or if it's ever been lubed since leaving Asia. but i ride it almost every day. the only complaint is i'm sure it's too big for me. when i stand over the top bar flat footed, well, it aint something i want to do more than 2 seconds. the seat is lowered as far as it will go. when i pedal my legs never get quite straight, and i dont think they should. and i wish i could raise the stem a bit. i'm not racing it i'm riding it. all that being said, i love this bike and love riding it. big change from my old mountain bike.
You should be able to adjust the height of the stem. At the top of the stem's elbow there will be a bolt, either a nexagonal recess (6mm most common) or a protruding hexagonal head (1/2" or 13mm most common). Loosen the bolt with the proper wrench. Pull up on the stem with a twisting motion, If it does not budge, loosen the bolt a bit further, so that it protrudes about 1/4" above the stem. Sharply wrap the end of the bolt with a rubber mallet. This will drive the bolt down and loosen the wedge at the end of the bolt. Now pull the stem out. About 2" from the bottom of the stem will be a set of hash lines. These are the minimum insertion marks and the stem should always be inserted far enough to hide these marks. Before you insert the stem, apply grease to prevent galvanic reaction of the aluminum with the steel dteering tube of the fork.
#102
Bikes: 2009 Surly Steamroller, 19?? Fuji ?, 19?? Univega Viva Sport, Marin/Xtracycle combo
here's two more nishiki's.
mine: 198? Tri A "Triathlon Series," bought as a frameset, finally finished putting it together on monday. i think the sante front derailer is original to the bike, but i'm not entirely sure. everything else is new or from the spare parts bin. 105 shifters are NOS. serial number WG 05531. i actually need to give it a good cleaning again.
my girlfriend's: 198? Olympic 12 single speed. don't know too much about this bike, since she bought it used and already converted, but she loves it and that's what's important. bars are getting swapped out for some mustache bars, san marco saddle going away in return for a brooks. dropouts stamped "suntour." downtube, just above the bottom bracket, has a "Japan" decal. bottom bracket shell is a bit rusty, so i couldn't make out the first two letters in the serial number, but it looks like KG 22227. sorry for the quick and dirty pictures. i can get more detailed shots if need be.
eidt: so it looks like my nishiki is a 1987 USA model, and the lady's bike is a 1977 USA model? does 1977 sound about right for that Olympic?
#103
Nishiki-Alan
I have a Nishiki frame that does not fit the serial number conventions.
It is an Alan Record Carbino badged as a Nishiki-Alan. The bottom bracket is an Alan casting, so I expect the serial number is an Alan number. The first line reads: 238662, and the second line reads: 3o6CX59. I believe the frame was marketed in 1986, so the '6' in the second set of numbers may be the year. The '59' is my frame size.
Do you know anything about this frame? Was it offered as a complete bike? I purchased mine as an NOS frame, from eBay, still in the original Derby shipping box. It is now built up with a mid to late '80s NOS Superbe Pro group.
I will appreciate anything you, or anyone else, can tell me about the frame.
#104
Liked 3,038 Times
As for the Olympic 12, I don't think it 1977/1978. Unfortunately, it has been changed so much that we can't use components for reference, However, the 1978 Olympic 12 had chrome fork tips. It also did not have bottle bosses, which yours appears to have. And is that a integral derailleur hanger on the rear dropout? If so, the 1978 literature shows the Olympic 12 with a claw mouted rear derailleur. Finally, the 1978 would typically have badges as opposed to decals on the head tube. Overall, I'd have to say that this model is more representative of the early 1980s. Might the serial number be KCxxxxxx?
As you surmised. it was a 1986 model. It was available as a bare frame for $950 US, or built up with Dura-Ace ($2150) or Super record ($2550). The tubes were made by TVT. Weight for a 56cm frame was 3.10lbs and 1.15 lbs for the fork. It was fairly typical of era carbon frames, having a reputation for a very comfortable ride but being a bit on the flexy side. Nishiki realized this and targeted it at the "smaller, lighter racer or serious endurance cyclist".
#105
You gonna eat that?
Enter and sign in, please....
Here's my Nishiki Olympic 12:
And here is its serial number:
The first picture was taken days before I wrecked it in February 08, bending the fork and buckling the down tube just behind the head tube.
But I thought I would share anyway. Using the decoder ring, I read KC21076 as the 21,076th unit built by Kawamura for the U.S. market in 1983. I think I bought it new in 1984 for about $250.
I stop for people / whose right of way I honor / but not for no one.
#106
Bikes: centurions (lemans and sports dlx both 1981)
1981 nishiki custom sport
paid $25 still working on it. don't know if i want to go with bull horns or put the original drops back on it. not real happy the bars from the mountain bike. actually less comfortable than the original drops. has one new rear tire and two new thorn proof inner tubes with slime. tires are 32-630. don't know what's original or an add-on after it left the factory.
#107
You gonna eat that?
Here is my later Derby-built Nishiki, from probably around 2000 or 2001 just before the brand died in the U.S. Serial number is R935040900.
If you're only looking for Kawamura-built Nishikis, my apologies.
#108
Cigartrader/guitarman
Bikes: Bottechia Professional 1968 / Nishiki Rivera Touring 1985 / Puegeot U-08 1969/1970
Here's some shots and info on a Riviera I just bought today 9/2/08 for $140.
Serial # KD14560 figure 1984.
Set it up to ride and it felt great, comfortable over bumps, good speeds 12 speeds, about 22lbs. Just says Rivera no GT and has power shifters. Will go nice with my other bike and old Bottechia campy.
https://www.cigarbest.com/sales/nishiki1.jpg
https://www.cigarbest.com/sales/nishiki2.jpg
https://www.cigarbest.com/sales/nishiki3.jpg
https://www.cigarbest.com/sales/nishiki4.jpg
Oh Hi, new to this forum but ride every day. I'm known as guitarman on video electronics forums like avscience.
Glad to join in here and thanks for all the info.
Tom/guitarman
Tom/guitarman
#109
Liked 3,038 Times
I picked up a chain skipping problem on this bike with the smallest sprocket. Is there an adjustment on the suntour to tighten the tension? It looks like there might be, there's a cover over the spring with a screw on it. It looks like maybe you and spin it to tighten the chain up.
1. Ensure the derailleur's outward travel screw is properly set so that the jockey pulley is lined up with the cog.
2. Ensure it is not a stiff chain link. Mariginally stiff links will be noticeable on the smallest cog because the chain wraps tighter around it. Put the bicycle in a stand and pedal slowly. Place a mark on the skipping link. If it always skips on the same link, grab the chain on both sides of the offending link and flex the chain lateraly to loosen the link.
3. Ensure it not a damaged or worn cog. Lots of owners were intimidated by derailleurs, but wanted to own one to be in fashion. They would ride the bicycle without changing gears, usually in the small cog. Consequently this cog received all the wear. When a new chain is installed it works properly on the other, unworn cogs, but skips on the worn, small cog. If it skips on the small cog in both the large and small chainrings, it is not chain tension.
4. I haven't taken apart a SunTour derailleur of that era to determine if the cage tension can be adjusted. It can be done with their earlier derailleurs. However, it is far easier and faster to remove links from the chain than to disassemble and reassemble a derailleur.
FYI, I don't know if I mentioned this before but your Riviera is actaully a 1985 model that was built in 1984.
#110
Looking at cog as the wheel is spinning I see it wobbling. Took the wheel off and it's a little on the loose side. Can't seem to tighten it and I'm not sure if it's the inner ring that spins tight counter clock wise or this larger outer ring on the last cog that doesn't seem to budge. This bike wasn't used much the break pads are original with no wear, the cog looks new also.
Thanks T
Thanks T
#111
Liked 3,038 Times
Cog wobble is normally associated with loose freewheel bearings, poor threading on the hub or freewheel body or loose or damaged cogs. If all the cogs appear to wobble, it is not the source of your problem. If only the small cog wobbles, it probably is the problem. if the cog is loose it sounds like it is missing a spacer or has the incorrect spcer. What is the make and model of the freewheel?
#112
The hub says sansai sealed system, all the sprockets did wobble together. I was able to tighten it better with the ring on the outside of the last sprocket. It's better but not perfect. I took some pictures of the suntour. Maybe if I remove the spacer that centers the Axel to the rear down tubes it might help. Not sure if it's needed anyway.
On the suntour it looks like the rounded gray colored item might be for adding tension.
https://www.cigarbest.com/sales/suntour1.jpg
https://www.cigarbest.com/sales/suntour2.jpg
https://www.cigarbest.com/sales/sugino1.jpg
Also it looks like I could ad a third sprocket to the sugino crank if there's room, it's al least drilled for it.
Edit:
Yey! success. Removing the spacer item that pushes the rear wheel forward fixed the skipping. Just that small amount more tension did it. If I need to install the spacer it looks like removing just one link in the chain would do it.
Edit:
#113
Death fork? Naaaah!!
This came through the store for work:
Serial #GC919442
Top
Serial #GC919442
Top
#114
Liked 3,038 Times
#115
Bikes: Nishiki Backroad;: fuji mountain bike
I have a Nishiki backroads and the serial number starts with a GZ......... I know that it is a gaint made but I have not seen any other post with that combo on this site or any other site, I would love to date it or be close to dating it got any Ideals
thanks
thanks
#116
Liked 3,038 Times
Circa 1992-1995, upper entry level ATB. Posting pics would allow us narrow it down. Baring that, your best bet would be to verify the two letter date codes on the back of the major components against the info on the components page of the Vintage-Trek website.
#117
here is the picture you ask for it is at this like https://www.msnusers.com/nishikibackr...hoto&PhotoID=1
#119
Liked 3,038 Times
Sorry, I goofed. When going back though my literature, I did not seethe Backroads listed in 1991, so I erronenously assumed it was no earlier than 1992. However, The ATB specs were not on the back cover with the rest, but on the inside of the back cover. Regardless, the chainstay mounted U-brake puts this very late 1980s. Based on the decals and color scheme, I would say a 1988 model. I believe that member Roccobike has a 1988 catalog, so if you PM him, he should be able to confirm.
BTW, future photos of bicycles should be taken from the drive side so that the crankset spider and derailleurs are plainly visible. This is a big aid in identifying models and years.
#120
T-Mar
I have been out making pictures of the Bike and have several pictures that might help
but I don't know how to put them on here any suggestions and I can pm you if you would like
let me know or you can pm me and I will send them to you or to Roccobike
thanks
tommy
thanks
tommy
#121
Liked 3,038 Times
You can post pics here by clicking on "Go Advanced" buttom under the reply box. This will open up another screen with a "Manage Attchments" button. Click on that and upload or link to a URL. Note that uploaded pics must be under 100k. Or just post on your MSNusers account.
I don't know if further pics will help much more, but they can't hurt. We should be able to eliminate 1987 and 1989 on the basis of the decal style and I don't think the U-brakes went beyond that period. The only possibility would be if the rear brake was actually a SunTour Roller-Cam as opposed to a Shimano U-brake. Then it could be a 1986.
#123
Bike Junkie
Location: South of Raleigh, North of New Hill, East of Harris Lake, NC
Bikes: Specialized Tarmac, Specialized Roubaix, Giant OCR-C, Specialized Stumpjumper FSR, Stumpjumper Comp, 88 & 92Nishiki Ariel, 87 Centurion Ironman, 92 Paramount, 84 Nishiki Medalist
Quoted: 68 Post(s)
Liked 37 Times
The Backroads was in the middle of the Nishiki line-up, 4th from the top of six. IMHO it was quite a bit nicer than the Pueblo, the next bike down which had a hi-ten frame and 15 speed. Hope that helps.
Roccobike BF Official Thread Terminator
#124
thanks for the info and the reply
that helps I have been trying to get information on the bike
#125
Late '80s 6 speed Exage comps w/Biopace, if that helps.
Top
