Need advice on fixing up a 1985 Fuji Del Rey :)
Bikes: see signature
Hey guys!
I picked up a 1985 Fuji Del Rey a few weeks ago in fair condition. I paid $100. I've been commuting on it for a couple weeks, and it works well. I've overhauled the wheel hubs and bottom bracket. Here is a link to some info about the bike (though mine has some differing features):
https://www.classicfuji.com/DelRey_1985_Page.htm
The color is the same as mine, though mine a a very minor dent in the downtube I'm sure is superficial. And of course mine has some paint scuffs/dings, which I'm debating on fixing with car filler paint or nail polish... anyway,
Here are some of the things I'm thinking about fixing up.
-new chain
-new 6-speed freewheel
-new crankset
(Current Sugino LP crankset makes the left pedal wobble; possibly bent crank. I tested out different pedals and fixed the bottom bracket play and it still feels wobbly, so I can't think of anything else but a bent crank arm or a nonperpendicular threading or something.
Also the triple rings bother me, but would I need a new front derailer to switch to a double? It has a 48-38-28, and I'd prefer something like a 52-3x with my 14-30 since 6-speed freewheels only get down to about 13/14-xx, unless I find some pricey NOS dura-ace or something...)
-new bar tape
-new rims
(Current rear rim has a slight vertical bump I can't seem to fix with my somewhat mediocre trueing skills. Also I'd prefer a rimset that comfortably accepts a more modern and skinnier 700x23-28 rather than the current 27x1+1/8.)
-new brake hoods for Dia Compe non-aero along with new brake cables and housing (color?? ...)
Any suggestions for any of the above topics or anything else would be a great!
Thanks,
-Nick
-new chain
-new crankset
-new bar tape
-new rims
Thanks,
-Nick
Quoted: 500 Post(s)
Liked 466 Times
Hey guys!
-new rims
Thanks,
-Nick
-new rims
Thanks,
-Nick
https://www.compasscycle.com/tires.html
Bikes: '73 falcon sr, '76 grand record, '84 davidson
Quoted: 59 Post(s)
Liked 22 Times
i'd use ...
- sun m13ii rims
- danscomp sapim db spokes
- 700x23c pasela tourguard wire bead
- sunrace 6, 14-28, in gold or silver finish.
- any period sugino double 52/42
- cheap suntour fd from the co-op or this forum.
- follow the catalog pic cues.
i like that silky, shiny off-white tape in the pic. can you get stuff like that anymore?
- sun m13ii rims
Still learning
The hoods are available anywhere on line for about $8.
Your FD can handle a double.
If the commute takes you on rough roads, I wouldn't get less than a 25c tire. Personally 28c is my preference.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
I usually get aerolevers instead of replacement hoods. You can find them on ebay for less than the price of hoods.
As always, I would recommend you pick up a set of used wheels. If you are resourceful, you can find nice used wheels for less than the price of new spokes.
+1 Your FD will be fine.
I'd need to see a pic of your bike to recommend bar tape and housing colors. I usually use a contrast color, and the bar tape would match the housing.
Hey thanks for all the suggestions!
I don't want to replace the brakes with aero versions because I like the black levers that it already has on it, and I also like the look of the brake housing "up in yo' face". Reminds me of Eddy Merckx... haha.
So my FD will be fine with any double chainring I put on it. No problem with chainline or anything?
The current Continental 1+1/8 is about 32mm according to Google Convert. But that width is driving me nuts. I can't even feel it when I don't take my butt off the seat to get up on the curb. I'm used to my Cervelo's nice 23mm 105psi ride where I feel the road. I can probably tolerate 28mm if it keeps the bike looking a little more time-period-appropriate, but I'm not much a fan of cooshiness in the tire area.
Speaking of cooshiness, I have some leftover cheap bar tape (China-eBay) I used for cushion on some heavy music equipment handles. Think I could wrap the tops and hood area with that before I wrap the rest in some nice Fizik tape to get some extra bar width and softness?
I can post up a photo later today of my bike. It looks pretty much the same as the one in the link but obviously in some used condition...
Thanks for all your suggestions!
-Nick
-Nick
Cane Creek makes some hoods that will fit on old non-aero Dia Compe levers (just Google "Cane Creek Dia Compe" and you'll find a ton of them). They're not absolutely perfect, and I find that sometimes you have to "adjust" them with a razor blade to get them to fit better, but they're typically only about $10 per pair. They make them in a brown which is a pretty poor replication of the old gum hoods, but the black ones look pretty nice.
Thrifty Bill
Liked 964 Times
You can get 27 inch tires as narrow as 1 inch. I had some Panaracers in 27 x 1 and I liked them.
Please don't confuse ebay "asking" prices with "selling" prices. Many sellers never get their ask price. some are far from it. Value is determined once an item actually SELLS. Its easy enough to check SOLD prices.
Hey Guys!
Bought some Sugino LP hubs to build up so I can continue commuting on it. They are both 36H. I want to do 3 cross rear and maybe 1 or 2 cross front. Yay or nay on that? Originally I wanted fewer spokes up front, but I'd rather keep it stock/original, so this is my alternative.
Thanks,
-Nick
Thanks,
-Nick
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
3x front and rear. No need to do anything silly or trendy...
I know there is no "reason" for it, I just want to try lacing a different pattern. Would there be anything BAD about lacing the front 1 or 2 cross?
Also I have found a Sugino square taper crankset from an old Allez 53/39 170mm. It is listed as being only for a 9 speed. Is there a difference? Can I still use it for my six speed?
Thanks again for all your help!
-Nick
-Nick
Nothing 'wrong' with a triple crankset. I have a Sakae 48/38/28 triple on my '75 Fuji right now, coupled with a SunTour 13-26 six-speed freewheel (although a 13-21 SunTour 6-spd was fine for the flat country around here) I'm using my bike's original 'double' Compe V front derailleur on the Sakae SX triple crank with no issues!
Hey Guys! My bike is coming together. New chain and freewheel are much smoother and quieter. Semi-double-wrapped bars look good and are comfortable. New silver housing and cables. And I'll probably keep the triple because it, well, works. I only have 2 more items to fix...
-new pedals
I hate the MKS pedals on there. Too skinny and feel...not flat. Considering the MKS touring, but need more options to look at. Also considering half toe clips for convenience. Any advice is helpful!
-new rims
I have a pair of original Suntour Le Pree hubs I want to lace up. They will be my first real wheelset I've made so I'm looking for a cheap 700c 36H rim I can fit 23-28mm tires onto. Looking for specific options please.
Thanks again!
-Nick
-new pedals
-new rims
Thanks again!
-Nick
The MKS Touring are pretty nice. I've got big flippers, and they're one of the few that I've come across that are comfortable (I use them with regular toe clips FWIW) and reasonably vintage looking.
Thrifty Bill
Liked 964 Times
Would look kind of weird on a road bike, but the VP bear traps are really nice. $20 shipped via ebay, in a myriad of colors. Very grippy!
PJD
Classic & Vintage
23
06-09-15 10:06 AM
Baytree
7
08-24-12 09:36 PM
