Bianchi Strada - saved from the garbage
Quoted: 243 Post(s)
Liked 172 Times
The guy who sold me the bike found it in the garbage. Should be a early 90's model, I believe.
The frame looks nice,. I want to rebuilt it. What group was original on the bike?
What should I use?
I have Shimano 600 and Suntour Le Pree?
What should I use?
1992 Torelli Nitro Express; 1972 Claud Butler.
Quoted: 4722 Post(s)
Liked 3,036 Times
Based on the rectangular CdM decal, it should be a 1987 model, but the serial number will tell us for sure. This was Bianchi's entry level model with a plain gauge CrMo main triangle mated to hi-tensile forks and stay. Note the stamped dropouts and down tube cable stop for stem shifters.
Equipping with Lepree or 600 would be overdressing the frame. Original specs included Shimano Tourney derailleurs and Chang Star brakes with safety levers. Those are the original Sugino VP cranks. The frame is designed for 27" wheels but you may be able to fit 700C depending on the reach of the available brakeset. Reasonable grade aluminum components should build up to about a 26 lb bicycle if you use 700C.
My decision to use 600 versus Lepree would probably depend on whether it's going to be a keeper or flipper and which generation of 600 you have. I'd take LePree over any of the pre-index versions of 600, if it's a keeper, but it may all come down to which derailleur has a claw to allow frame mounting.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
THe Strada was pretty bottom of the barrel. A shop I worked at found a bunch of them from ~1988 still in boxes in the early 2000s and we sold them for $100 each, and I thought at the time that was about right.
Bikes: Fuji Classic (Track), Peugeot U-08, Bianchi Strada turned Fixie
Quoted: 13 Post(s)
Liked 9 Times
Did you happen to change the bottom bracket? I've come across the same frame but my BB isn't in the best of conditions, would a 68mm English threaded BB work well?
Quoted: 1324 Post(s)
Liked 927 Times
Resurrections a 4 years old thread. OP has most likely moved on with the build.
Cheers
Cheers
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
Yes that is an Asian contract frame and should be English thread.
Sugar "Kane" Kowalczyk
rideandgoseek
Classic & Vintage
11
06-29-16 10:47 AM
TugaDude
5
05-24-11 12:08 AM
