X-Shifter wireless electronic shifting
I have been using the X-Shifter system on our 1 X 10 etandem for going on 2 years now and I am extremely satisfied with the performance. If you are wanting to update to wireless electronic shifting and want to keep your 7, 8, 9 or 10 speed rear cassette or even 11 speed and your triple then you might want to check it out. It is simple to install and simple to adjust.
The X-Shifter consists of a servo that connects to the existing front and or rear derailleur along with a push button for the individual servos. I use 1 servo and 1 push button.
I was a Kickstarter supporter but never received a unit. Nice to hear that it works for you. I think I will keep money rather than spend it.
You might want to contact Pete at Sportcrafters he was able to fill my kickstarter order.
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
So we’re going to add a motor to pull the cable on a cable actuated derailleur? Seems to me this adds complexity, cost and weight with little benefit.
It shortens cable runs, so I guess that could make the shifting somewhat more crisp, but I doubt there’s a significant advantage over a well set up cable system with good quality cable housing.
You could get lost and die.
You could hit a tree and die.
The weight is negligible.
It permits wireless shifting without having to convert to 11 speed.
it is MUCH LESS EXPENSIVE than any other electronic shifting system on the market that I am aware of.
I have used almost every kind of mechanical shifter that has been available for the past 40 years and for my money this is an excellent option.
pan y agua
Liked 727 Times
As for cable runs, once you've installed the cable on a frame intially, I just don't find them to be a hassle.
More than half a pound if you go front and back, To me that's siginficant.
Ok but you don't get the advantages of a new 11 speed or 12 sped groupset, i.e. closer spacing, better shifting. It also begs the question of why if you have a bike with a group you like, and the cables already installed, is there any need to go wireless, particularly if it won't significantly improve the shifting
Why not wait until your mechanical groupset is worn out, and replace it with a modern integrated electric groupset
Sram and Shimano's modern electronic groups are designed from the ground up to be electronic, with a lot of thought and research going into how the entire groupset works together. For example the front shifting on Di2 is phenomenal, because of the total system, i..e how the chain rings are ramped and pinned, and computer logic controlling the front derailleuer to over shift, and then trim back, and that also takes account of the position of the rear derailleur.You're not going to get the performance of those systems by slapping a servo motor on an old, worn, cable actuated system.
Just adding the X shifter certainly doesn't give you the advantage of better chain rings optimized for electronic shifting.
And given that the X shifter is sold as 2 different units for front and back shifting, I doubt it takes into account the position of the rear derailleur when shifting the front.
So for $500 bucks and half a pound you get a motor to pull a cable for you, and you can say your system is electronic. I really don't see the need or the benefit.
Bikes: 2022 Calfee Tetra, 2023 Giant TCR
Quoted: 120 Post(s)
Again, I fail to see how this offers any performance advantage. It's still cable actuated, just with a motor pulling the cable. Other than gaining some small advantage from a shorter cable run, I just dont see how it will shift better than pulling the cable yourself.
Our Calfee is 9 years old, when I built it 3 X 10 speed was very common. I have 3 X HED 3 rear wheels that I use on the tandem and my Trek Speed concept. I have spare cassettes and spare 10 speed chains. I ma locked in to 10 speed. The 11/28 is perfect for the flatland of Illinois. I wanted wireless shifting and was not willing to convert to 11 speed.
so it was what I WANTED! I choose X-Shifter and it works for ME.
when I installed the mid drive PAS motor I went with a 1 X 10 setup (52 with an 11/28) I also have Magura Hydraulic rim brakes. Mechanical over hydraulic. Simple TRP brake levers activate the brakes.
with X-shifter I eliminated all of the shift cables especially the one that ran between the motor and the frame. I have the phone app that shows me what gear I am in and it even allows me to make shift adjustments on the fly if required.
for ME X-Shifter offered many advantages, one thing that he helped was an issue I was having with my wrists, it was a little uncomfortable shifting brifters.
it works great for me! I love it!
pan y agua
Liked 727 Times
It’s good it works for you. However, as a review with general application, I think the reasons it works for you are pretty specific. Most folks don’t have motors they need to route cables around.
As for hand issues, either Di2 or SRAM etap, particularly with auxiliary sprint buttons would appear to be even a better answer.
Also, Most 10 speed hubs can take 11 speed cassettes. All HED wheels from 2013 forward already accept 11 speed, and from 2007 forward they can be upgraded.
