Haven’t biked in years, starting over. Why’s everyone riding on less psi now?
#51
Quoted: 18883 Post(s)
Liked 10,646 Times
Can someone explain how low front tire pressure changes handling around the corners and such?
I am on the lower end of the pressure guides due to the rough roads surface where I live. No way I can ride more than an hour if I pump the tires up to 110. Seems like there's a bit of a speed comfort trade-off in lower PSIs.
Likes For Seattle Forrest:
#52
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
According to this Quora post a knife cuts as it "...separates material apart is by breaking weak intermolecular bonds that hold a substance together. Pushing down with a sharp edge forces material on either side of the blade outwards, ergo forcing the molecules apart."
My intuition is you'd want to increase the area of contact with the tire and the road using a lower psi which is kind of the opposite of a sharp knife. Maybe I'm wrong, maybe we are talking about the same things. I'm just trying to understand.
#54
Liked 2,563 Times
Hey, at least my 12-year old brain had no trouble with hedonist's analogy!
#55
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Higher pressure causes the tire to not deform and lose contact with the ground when there are irregularities in the pavement. So any little rough spot can cause your tire to skip/slide and you can go down.
That sweet spot between maintaining maximum grip while not deforming to the point of raising the rolling resistance is what most shoot for.
Likes For rubiksoval:
#56
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
Agreed on pressure. OP you should start at like 90 or 95 and drop from there over a few rides. You'll know when you're too low.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
#57
I eat carbide.
Liked 1,306 Times
I started the wheel company 11 years ago officially. About 6 years ago the existing bike shop that I was "renting space" from to establish some of the more discerning distributor accounts had the owner get to the point where he wanted to retire and he sold the shop to me and I moved in.
He rides daily still and occasionally he will stop in and say hey and we will talk. In between ordering the odd 20 year old Campy part to fix his worn out stuff we will get to talking a little about tech changes. I guess I intuitively knew a lot had changed in those years but I never really put it all together.
Anyway one time he was like telling a story and I suggested, "Oh you should probably lower your pressure a bit. Most of us that have been riding forever tend to be running a little high on pressure."
"Really? what do you recommend for me?"
"95-ish. Just below 100 as a start."
His eyes got big and he was like "WTF?! I ride 120! We used to just go as high as we could. The higher and the narrower the better."
"Yeah, well the fatter and lower is apparently better now."
"Is everyone going a lot faster now?"
"Nope."
"Surprise."
Same guy that used to say, "I love selling spoke wrenches. I make money when I sell the wrench and I make money when they have to come back later because they messed up their wheel."
"Nope."
"Surprise."
Likes For Psimet2001:
#58
Bikes: 87 Bianchi X4, 95 Bianchi Ti Mega Tube, 06 Alan Carbon Cross X33, Gold plated Columbus AIR Guerciotti, 74 Galmozzi Super Competizione, 52 Bianchi Paris Roubaix.
Quoted: 259 Post(s)
Liked 539 Times
They've bought into the Kool Aide.
#59
Bikes: SL8 Pro, TCR beater
Quoted: 981 Post(s)
Liked 583 Times
6'1'' and 185lbs (84kg) here and I am running 85PSI in my 25mms tubeless tires (mounted on 17mm internal width rims). I was running 100psi on my previous tubed setup. I could probably go even lower, but I am comfortable at that pressure.
They tend to lose 5-10PSI after 50-60kms and my butt is happy with that during long rides!
#60
Bikes: Shmikes
Quoted: 10152 Post(s)
Liked 5,843 Times
Data point: 141 lbs; 25 mm; 70 F, 75 R. Much higher and the bike feels unstable descending fast on rough pavement, of which there is a lot where I live. Haven’t gone lower.
#61
Quoted: 7649 Post(s)
Liked 3,465 Times
But they are traveling the same distance in the same time in far greater comfort .......
That's hilarious .... after the sting fades .....
#62
Liked 10,646 Times
I think everybody got the analogy about the dull knife, but it sounds off, so I can't blame anyone for checking to see if it's really analogous. And it turns out it's not, kind of like how there are a lot of ways the brain isn't like a computer.
#63
Liked 10,646 Times
Now I'm getting ads for knives.
#64
Pointy Helmet Tribe
Bikes: R5, Allez Sprint, Shiv
Quoted: 519 Post(s)
Liked 627 Times
So after a few months of drinking the kool aid and riding at 80.85, i pumped my tires back up to 95/100 for the past couple of rides - and it has felt faster (given the wind and wattage). Was it a controlled test? No. But that loop is my main training route and I have a pretty good idea of what kind of speeds I do at different wattages and under various wind conditions, and this does feel faster. Admittedly, this is on very good quality tarmac, though.
#65
Quoted: 338 Post(s)
Liked 408 Times
It depends a lot on the road. I'm 72kg and ride on 23F / 25R GP5000s (which are a hair smaller than their older tires, or as they say - more true to size), latex inner tubes and a set of LB wheels with 17,9mm internal width. For reasonably nice to good roads, I go with about 100 to 110 psi, both front and rear, 110 actually seems optimal for going faster on good roads, and research seems to suggest so. At 110 psi, I do have to be a bit more careful cornering on uneven / broken up roads, though, because the bike bounces up and down on them a bit, but, conversely, the handling is great on smooth roads. If I go over a series of big speed bumps near my house at full speed at 110 psi, my bidons fly out, though. Going a bit lower, 100 psi is a nice compromise if I'm going to go over mixed quality roads and still goes fast and handles nicely - perhaps it's a bit less ideal if I have to climb something really steep when I stand on the pedals, where the rear tire doesn't feel all that solid because a lot of weight gets shifted on the rear.
For bad to broken up roads, less. I have a collection of local backroad training climbs some ten minutes of riding away from where I live, and here I tend to use less pressure still, around 90 psi typically. I've ridden with as little as 80 psi on the worst of them where the roads are a collection of patches and potholes and it really takes the bite out of them, but below some 95 psi the tires have a bit of give when you put your weight on them - it can be a bit disconcerting while cornering, and standing on the pedals the rear feels mushy and somehow draggy. Not ideal for going fast on a nice road.
When you consider that in the old days they rode 23s on narrower rims (which reduce overall tire width and air volume, needing more pressure to compensate, since a larger volume tire is a stiffer spring at the same pressure), maybe the 120 psi pressure they used then wasn't actually far off from ideal when the roads are good.
Likes For Branko D:
#66
Quoted: 4245 Post(s)
Liked 1,350 Times
The pressure to use depends on the load (how heavy you and the bikes are) and the wide the tires are.
People used to use just 120 because that was the number printed on the tire (as the maximum) and shops were abme to tell everybody one thing. It was just easy.
Many people were also using narrower tires. But, they’d use less with wider tires.
#68
Pointy Helmet Tribe
Quoted: 519 Post(s)
Liked 627 Times
I know you are being flippant, but in the interest of clarifying my earlier post: I do understand the distinction between something "feeling" faster and actually being faster (and that often, wheels that feel faster are actually not so). In this case, I dont mean "feel" as in "sensations". I meant that based on my expectations of speed given power and wind (which, I readily admit, is not at all scientifically valid or precise).
#69
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,860 Times
"Nope."
"Surprise."
"Nope."
"Surprise."
#70
Liked 11,860 Times
I actually AM faster since lowering the pressure in my tires. I keep scoring PRs on Strava segments I've ridden dozens to >100 times. OTOH, I lost 25 lbd and am riding a whole lot more, so as a card-carrying Scientist*, I can't really say the lower pressures made me faster.
*(Well, it USED TO say "Scientist" on my cards, till I got promoted)
#71
Quoted: 550 Post(s)
Liked 325 Times
Likes For Drew Eckhardt:
#72
Quoted: 892 Post(s)
Liked 2,053 Times
Likes For downtube42:
#73
Liked 11,860 Times
No, because they don't actually KNOW the things they think they know. They just BELIEVE them.
Likes For genejockey:
#74
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
#75
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
Likes For znomit:
