How to change a grip shifter - LBS or DIY?
Quoted: 80 Post(s)
Liked 39 Times
Well, I just learned how to replace the 3 chains on our DaVinci Grand Junction. In a separate thread, I asked whether there is a grip shifter that would be better than the SRAM Centera 9-Speed Twist shifter that needs replacing. No one has suggested a better grip shifter, and I think I want to stay with that type of shifter for now. So, the question is whether I should attempt to replace it myself or whether it is better to get a LBS to do it. I have a long enough shifter cable and I will order the shifter. If I attempt doing it myself, I will need a crimping tool and whatever those ends are that get crimped onto the ends of the cable. Can anyone suggest a tool for this?
How hard is it to replace the grip shifter? A LBS replaced it for me last time and the gear indicator did not work from the get go.
Thanks.
Thanks.
It's easier than working with chains. You don't need any special tools other than a good cable cutter.. The little cable ends that get crimped on, you can use a side cutter or even the inside cutting edge on any needlenose pliers will do the trick.
Just put one or two light crimps on it. Don't squeeze so hard that you cut through the cable end or cable.
Quoted: 2493 Post(s)
Liked 738 Times
