Tire Swapping limit ?
I want to swap my mountain bike tyres from a slick tire to a knobbly version, but i will probably want to switch back again. Can I swap clincher tires many times? say for example once per month. I am too thrifty to buy another set of wheels.
Yes, as long as you don't damage the tire. It may get messy if you run tubeless.
Likes For katsup:
Quoted: 1364 Post(s)
Liked 1,677 Times
roth rothar I commute in Colorado where goathead thorns are prevalent. Before getting tire liners I was patching flats about once a week (now it's about once a year...if that) That's a lot of on/off and the tires, always inexpensive ones, didn't suffer. This was true for my 26-incher and then my 700C bike.
For the last five years I have mounted, unmounted and remounted snow tires on my 26-incher for snow season in the spring and fall with no problems.
However, I just bought a set of used rims at the bike co-op this summer...$40 for the pair. With some practice and adjusting the wheel-swap now takes just under 5 minutes including the brake adjustment, instead of the 30-45 minutes to swap tires.
If you can find cheap wheels in your budget, it may be worth it, provided the wheels are in decent shape and compatable with your derailier and chain.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
If I find myself swapping tires more than a few times a year, that leads to a second wheel-set, and a second wheel-set always grows into a new bike.
But as far as the tires go... no problems if you want to change them each month. Or several times a month, for that matter
Likes For Kapusta:
This is a good question. The answer is, whatever you are willing to do. With practice you can change tires without using any tools other than your fingers (find youtube videos to show you how.) Not using tools will mean you don't accidentally damage anything when you perform swaps, and so you can swap indefinitely or as long as your fingers hold out. Tubes might be better for this than using a tubeless setup, because every time you change tubeless tires you should add sealant, which adds up after a while. Be sure the tubes you're using match the tires you're using.
Likes For BlazingPedals:
Quoted: 2952 Post(s)
Liked 3,106 Times
You could do it every day if you had the patience.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
It’s easier to swap tires and tubes as a set. The partially inflated tubes makes the swap faster. A bike stand to keep the bike frame up is also a help. After the tires take a set well for most tires it is quicker. I wish for disc wheels set up the same. Next bike then.
Likes For biker128pedal:
Clark W. Griswold
Quoted: 4350 Post(s)
Liked 3,989 Times
You can do it 3 times a week except leap years you can do it 4 but if in Australia it is 2 in normal years but 6 in leap years provided you have consumed at least 1 case of Foster's. Now of course on Tuesdays in South Dakota, Vermont and some parts of central Florida you are required to get a permit to do it and in Wyoming it is not permitted at all on Sunday.
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
The spare tube I carry is puncture resistant so when i get a flat and install it, I remove it when I get home and put in a light weight tube. So for every flat the tire is removed and reinstalled twice and depending on my luck I might get 2-3 flats before the tire is worn past the wear indicator dots.
Advanced Slacker
Liked 2,537 Times
Likes For Kapusta:
