Gp4000sii... Nla?
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Gp4000sii... Nla?
So I had to replace my rear tire due to a cut in the sidewall. I always keep a spare but now i'm looking to buy another spare and all i see are the GP5000, no one lists the GP4000SII, are then NLA?
If so is there any issue with running a 4000 and 5000? And if none, which should be on the back if that matters?
Likes For GlennR:
Quoted: 871 Post(s)
Liked 726 Times
GP5K has lower Crr but some have said it wears faster than the 4Kiis. I would run it on the rear if you want to optimize for speed over longevity. It also inflates on modern rims truer than the GP4K, so you should consider sizing up if you used to run 25 or 28 and want the same profile.
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
As long as you don't post a photo here showing your mismatched tyres you're good. Some of your riding buddies might not want to hang with you but it's times like these you find out who your real friends are.
Likes For znomit:
On Your Left
Liked 2,433 Times
My "real" friends don't ride.
So are GP4000's NLA?
It's just that i've been real happy with them over the past 5 years.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
GP5000 replaced GP4000. I’ve ran a mix while my last GP4000 wore out. On the true size. The first few GP5000s I bought were oversized. The 23mm was just under 27mm. The 25mm was just under 28mm. This was on 19mm inside with rims. The 23mm tire I bought last spring are 25.5mm.
On Your Left
Liked 2,433 Times
Well.. I would hope a 25mm is not too big size a 28mm will not clear the front fork.... 2015 Emonda SLR.
Should Be More Popular
Quoted: 22589 Post(s)
Liked 8,924 Times
Quoted: 551 Post(s)
Liked 722 Times
I have a pile of 28mm 4000s in the shed that I won't use now that 32mm 5000s are out,. Whats the going rate?
Liked 8,924 Times
Since you can get the 5000 on sale for $35-40 if you shop around, I would say that’s the likely best you could expect.
Forum Moderator
Quoted: 3089 Post(s)
Liked 6,590 Times
I've recently been in a couple of my LBS and each had one GP4000SII in stock. And they were still asking around $75 each for them.
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
Likes For Bah Humbug:
