The New Mercier Kilo TT Pictures Thread (2011 & 2012)
#2676
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
It will work fine as long as the stem has the proper dimension for fitting to the steerer tube.
Steerer tubes are typically 1 1/8” or 1” diameter.
Looks like your bike has a 1” (25.4 mm) steerer tube. You can also use stems for the common steerer size of 1 1/8” (28.8mm) if you get the proper shims.
Otto
#2677
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
I was able to find a 26 mm bullhorn handlebar online but couldn't find any 26 mm short stems, only 25.4mm. From my understanding and what I read online, it's a bad idea to install bigger handlebars even by .6 mm into smaller stem. If I were to just get a 25.4mm stem then I could get handlebars that fit ( found a bunch of 25.4 stems and handlebars online ).
Would a 25.4 stem even fit on my bike which originally came with a 26 stem?
#2678
Dave
#2679
Purchased wrong stem
btw could someone recommend good quality straps for my pedals. I ordered one already but after yesterday’s ride the threads were already falling apart.
#2680
Are you looking for single or double straps? MKS Fit-a Spirits, Toshi, and Cinelli make nice and durable laminated leather straps that I've tried. The All City ones I've tried are nice and durable as well if somewhat less blingy and it's worth noting they are slightly thicker so a bit tougher to thread through some pedals, I've had to shave the tips down with a knife and pull them through with pliers. I don't recommend the Soma straps however, they've gotten soft on me and I've broken them before, I'm not sure if they are laminated which may be the reason why?
#2681
Bikes: Custom State Bike, Mercier Kilo TT Stripper, Leader 721
I used a hacksaw and shortened the stock bars. Quick and easy.
Likes For Scrodzilla:
#2683
Regarding tire and tube sizes. Currently the bike has the Kenda Koncept Lite 700x23c with 700x18/23c tubes. The other day I rode over some glass and punctured the tire. Tube had to replaced, the tire was ok. My friend had a spare tube and we got it installed but it was a size 28 but we still managed to get it in and no problems.
Now I'm looking to order new tubes and I found a bunch online. What size range should I be looking at?
Did end up ordering 700x25/32c but cancelled the order a moment ago thinking that it would be too big for the 700x23c tires.
The bikes rim and tire specs as follows:
Rims: 36H Aluminum Aero Section Track DoubleWall
Tires: Kenda 700x23c high pressure road (please maintain at least 100psi)
What tube sizes should I be looking for? I know 700 but as far as width goes : 20-25, 25-32, etc..
#2684
Veteran Racer
Liked 764 Times
fordfasterr
Track Cycling: Velodrome Racing and Training Area
0
05-03-11 01:51 PM
