How to get a flat tire
Bikes: 1969 Peugeot PX10, 1992 Della Santa, Linus Roadster 8, Biria 700C ST-8
Quoted: 794 Post(s)
Liked 508 Times
This morning I was out on one of my morning rides, later these days to avoid the MUP crowds. I stopped on the way back at Walden Park since I knew there would be a picknick table in the shade there. After making a couple phone calls then I took my bike down the the path to go. Right away I could feel a thump thump and stopped. 26"x1.5 Schalbe Marathon tires. So I got right off and went back to the table. (rule number 1) Have a nice place to work on the tire. I could have just walked home, maybe a half mile but I hadn't had a flat in about 3 years so I wanted to know if I could still do it.
Settled in at the table. Took my bag off the rack. Released the back v-brake. Flipped the bike over with the handlebar in the grass. Used my antique adjustable wrench to loosen the wheel. Used my handy piece of spoke to release the 8 speed cable from the Alfine hub. Yanked the wheel out of the dropouts, moved the chain out and took the wheel out.
Rested the wheel down next to the bench (see rule 1). This tire had been on there for a while so it was easy to remove. I first released all the air pressure and then ran my hands around the tire to unstick the tire from the rim. After that was pretty loose then made sure all the pressure was out and pealed off the tire with my hands.
I ran my fingers around the inside of the tire but didn't feel anything sticking out. Pumped up the tube and it wasn't holding any air. Gave up on that old tube and got out my spare. I decided the new tube was the way to go. Pumped it up a bit and then put it into the tire just to give it some shape.
Put the tire back on the rim, rice to have a tire that's run for a while. Used my hands to get the tire with tube nicely onto the rim. Pumped up the tire and made sure it was all around even. Put the wheel back into the dropouts and reconnected the shift cable. Not any issues there despite internet experts who pronounce that Alfine wheels are hard to change. Put the v-brake back.
Pumped up the tire until it felt pretty good. Got on and rode home. Just for fun I passed a couple people on the MUP. Some issues for the home shop of course. But happy to know I can take care of my self.
Likes For Joe Bikerider:
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,530 Times
Well done; mine have all been on the side of the highway.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Flats
The Iron and Canal trails have Goat Heads hiding just off the blacktop and waiting to grab you.
It's especially bad when the county brings in the weed whackers, those fling Goat Heads everywhere.
Glad you didn't need the Sag wagon.
Barry
Barry
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 250 Times
Another Northern CA rider checking in. I enjoy the goatheads in Napa Valley also. I carry two tubes now.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
I went tubeless. Goat-heads shmote heads, no more flats. 1300 miles and counting.
I did find a glass cut during my maintenance, but even that sealed and got me home.
Barry
Barry
Quoted: 426 Post(s)
Liked 274 Times
I am really started to think I should switch.
I probably would have quit riding if it wasn't for tubeless, just too many flats before.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Yes that magical!
I’ve actually pulled a goat head from the tire and just gone on my way, smiling.
The glass cut I patched on the inside. Not sure I needed to, but I wanted to try. That was more time than a regular flat.
I finally decided I didn’t like that cut on the front, so I switched them. Once again, more time than regular tubed.
In summary
I may not be much ahead in maintenance time spent, but I’m way ahead on inconvenience avoided while on a ride.
Plus all my maintenance has been performed at home and on my schedule.
Barry
In summary
Barry
So now that you've had a chance to investigate, what caused the flat?
Quoted: 327 Post(s)
Liked 250 Times
OK Whats with the tubeless tires and no flats ? I have never used tubeless but I might if they will reduce the high flat rate I have. I am using Gatorskins now and much better but they have a pretty harsh ride.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
And extremely well in my experience.
i’m riding 700x23 and very happy with them. I won’t go back to tubed.
Barry
Quoted: 327 Post(s)
Liked 250 Times
Thanks Barry for the info. I think I will try tubeless and see if they reduce the number of flats i get. I now use Gatorskins and I have fewer flats but still more than I would like. Our area has poorly maintained roads and it is a continual problem. I am getting pretty good at fixing the flats on the road now though
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
It's been about a year since my last on-road flat, caused by a sharp bit of rock embedded in the tire > punctured tube. No trouble replacing the tube and getting back to the ride. A picnic table would've been nice.
Bikes: 1984 Fuji Club, Suntour ARX; 2013 Lynskey Peloton, mostly 105 with Ultegra rear derailleur, Enve 2.0 fork; 2020 Masi Giramondo 700c, full Deore with TRP dual piston mech disk brakes
Quoted: 324 Post(s)
Liked 81 Times
tubeless and no flats?...pure BS, there are internet sites all over the web with people who had flats, which is why everyone recommends carrying a spare tube for tubeless tires, and some recommend carrying 2 tubes. No thank you, I don't want the headache or the expense! I carry spare tube with me now why in the hell would I want to do that with tubeless if supposedly their flat free! Because their NOT flat free. Besides, I haven't had a flat on my primitive tube tires in over 3 years either on my road, mtb, or my touring bike. I can guarantee you that if someone flatted their tubeless, and I flatted my tube tire, I would be up and running before the tubeless person is done.
You mean, you filled your tires with sealant, which seals the punctures automatically. Which is, of course, has absolutely nothing to do with tubeless. Anyone can use sealant, tubeless or not. Not everyone likes it, though.
Quoted: 630 Post(s)
Liked 369 Times
For me flats seem to come in clusters. Had two on consecutive days in March, the second one had me cursing and throwing tools on the ground! Not a good look... Riding here in NYC, it's almost always a pinch flat from a pothole or other road deformity i didn't see in time. The impact of your wheel hitting a hard edge with such violent force both sickens and infuriates the rider! You just coast along and wait for one of the tires to start going soft...
But it's always an impact, never a puncture it seems. Started using Ribmos w/ conventional tubes years ago, and now gatorskins since the last set of Ribmos wore out. Haven't had a puncture flat since.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
Rookies. Just don't check the tire air pressure and head out. Pinch flats with two holes.
Quoted: 324 Post(s)
Liked 81 Times
On my previous touring bike I went about 1,800 miles without a flat, on my current one I'm at 586 without a flat, on my regular road bike I'm at 2,200 and some odd miles without a flat; on my older road bike I'm at around 500 miles without a flat. Of course I'm not using Specialized Turbo Cotton racing tires either, but todays tube tires are far better at warding off flats then they were just 10 years ago. Of course on my old touring bike I was using Schwalbe Marathon Greenguard tires, on my current touring bike I'm using the factory stock Kenda Drumlin tires, not sure how good these tires will be but so far so good in the flat department but they're heavy as hell. On my regular road bike and my older one I use Specialized Roubaix tires, which I really like those tires. But I wore out a set of Vittoria Rubino Pro tires and never got a flat till the cord just started to peak through then had a flat, that was the tires before I got the Specialized tires, and that's the last flat I've had.
Sorry if it sounded like I was calling your experience BS, I was trying to refer to tubeless in general.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
I think you have it backwards. I was picking on you!
I know what I've recently experienced first hand, and I wanted relay it accurately in this thread.
That was my job... and a fine job I've done!
So no hurt feelings here
Barry
