A bit annoyed with how my LBS wrapped my wife’s bars…
Quoted: 28 Post(s)
Liked 33 Times
She doesn’t seem to care, but this feels sloppy. They didn’t even use a piece of the original tape to cover the shifter clamps. They used plain ole black cork.
Quoted: 10238 Post(s)
Liked 5,185 Times
Sometimes, you just have to do it yourself.
My wife wraps my bars, except when my LBS wraps my bars.
Likes For bampilot06:
Park Tools has an excellent video detailing how to wrap bars. Even I could follow it, and my results look pretty good, almost like I knew what I was doing.
should be more popular
Nothing beats doing it yourself if you want attention to detail.
That's a minor result as far as shop fiascos go.
Just redo it, I used that tape before and it will still stick just fine for a couple rewraps.
Likes For yaw:
Advocatus Diaboli
Quoted: 4737 Post(s)
Liked 1,533 Times
Did the tape either: A) not have enough length leftover to cut a piece off for the purpose of covering the clamps; or B) not actually supply the extra pieces for this purpose (some brands do not include these unfortunately)?
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
I'd be annoyed too. But like you, only a bit. And if your wife likes it, let sleeping dogs lie and just go for a ride with her.
Likes For Chuck M:
Bikes: 2002 Eddy Merckx Team SC Resto-Mod; 2019 Ibis Hakka MX; 2017 Spot Brand Ajax Belt Drive
Quoted: 169 Post(s)
Liked 192 Times
They should 100% redo that for you. I can't believe a "pro" would wrap bars like that.
Likes For mattcalifornia:
Quoted: 768 Post(s)
Liked 1,744 Times
Supercaz is hard to wrap as it does not stretch like some tapes do so you can get this bulging or lipping if you don't get it right as you come into the hoods. This was probably the best way to eliminate this. I will admit my taping skills lack on occasion, but I tend to use tape that has some stretch which gives me some relief around the hoods.
It's not completely horrible, but it could have been better.
Brian | 2023 Trek Domane SLR 7 AXS | 2023 Trek CheckPoint SL 7 AXS | 2016 Trek Emonda ALR | 2022 Trek FX Sport 5
Likes For jaxgtr:
Expired Member
Quoted: 3674 Post(s)
Liked 5,438 Times
What's wrong with the wrap?
Likes For shelbyfv:
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
If you wanna be super picky, you gotta do it yourself. Shops are apparently charging $20 labor to wrap bars, and I know no shop would want to pay me even min wage to spend an hour wrapping bars as anally retentive as I do.
It's like riding a bicycle
Likes For urbanknight:
Likes For yaw:
Quoted: 1088 Post(s)
Liked 1,026 Times
Done right, you don't need the strip to fill in, everything is just covered by the way its wrapped and the hoods. Personally although I wouldn't have considered the job good enough for my results, I probably wouldn't have noticed is someone else did it and I wouldn't care enough to make any form of stink about it unless the wife really disliked it. Since she doesn't care I wouldn't waste the energy to get worked up over it, it'll get changed sooner or later. I've also found supercaz tape to be harder to use, wouldn't be surprised if a newer tech struggled with using it, was as hard to stretch and lay down as old cork, just a lot less fragile, and hard to get perfect without a lot of experience.
Quoted: 169 Post(s)
Liked 192 Times
Hmmm. The last time I had the Velofix mechanic over to work on my bikes, he saw my new box of tape in the garage and asked if he could re-wrap my bars for me just because he loved doing it. I was going to do it myself, but I figured he could save me some time and aggravation. He did it for free and much better than I would have. I wrapped my gravel bars soon after. It came out pretty well -- but not as perfect as the Velofix guy.
Liked 2,979 Times
Pulled it off & found no strip at the brifter clamp. Both sides were like that.
I wrapped the initial problem side nice & tight. I'll need to redo the other side over again. Should have bought two packages.
-Oh Hey!
-Oh Hey!
Quoted: 2333 Post(s)
Liked 2,097 Times
If I posted a pic of my bars, 911 would blow up.
Likes For GhostRider62:
Likes For Bald Paul:
I don't know.
Quoted: 317 Post(s)
Liked 853 Times
well, they did use good tape anyway. I like that brand.
Quoted: 242 Post(s)
Liked 455 Times
Supacaz doesn't include the usual "strip" of tape used to cover the shifter clamp. I too keep spare pieces of varied tape for such needs but usually cut a short strip off my Supacaz to cover the clamp.
I do notice there is quite a bit of overlap of the tape. I usually go for the mid point or just a bit over depending on the size of the bars.
I find no real fault though I prefer to cut a short strip off rather than use a different tape.
Best to learn how to do it yourself but then you open yourself to complaint and mockery if you don't do it to everyone's expectations if you show the results.
Clark W. Griswold
Quoted: 4358 Post(s)
Liked 3,996 Times
I wouldn't worry about that it is the nature of the Supercaz tape so they did something to make it work. It is barely noticeable and not noticeable when your hand is there or while riding.
Sunshine
Quoted: 10965 Post(s)
Liked 7,492 Times
Unfortunate that bar tape which costs $25-50 depending on model and retailer cant manage to include a couple of 2" strips of tape to use under the shifters.
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
I hate imperfections in bar wrap; it's one of my pet peeves. I spend way too much time working to get it perfect when I do this job myself. I have a compelling need--almost an obsession--to get it as perfect as possible.
Liked 2,979 Times
Likes For ralphs:
Quoted: 3956 Post(s)
Liked 7,304 Times
I think that mechanic used to work as a cook at one of our local restaurants, where peas were piled randomly on the plate and French fries were never aligned with each other. It really annoyed me.
Quoted: 28 Post(s)
Liked 33 Times
Thanks for the inputs! I'll likely just leave it as is. I just learned something new about this shop. The shop that services my bike would never have wrapped this way, but it's about high time I give it a go.
My wife's bike also has some secondary brake levers on the bars just to the left and right of the stem. I had asked them to remove these when they were re-cabling the bike. They put this information in the work order notes, but then when I picked up the bike they didn't do it. My combined ire of them wrapping the bars this way and then not executing on the details of the work order brought me on here to vent.
