Great P-Handle Hex Wrench Set size 2-10
I'm looking for a better set of p handle wrenches than park tools ball ITEM # PH-1.2
Looking for something better than the plastic handles, anyone know another manufacturer/model. Nothing against these or park tool I'm just concerned looking at these plastic handles.
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
These are better - you'll need both:
Long end
https://www.walmart.com/ip/ate-pro-u...-set/371202160
Short end
https://www.newegg.com/p/308-005X-00...9SIA0SD8RB9038
Long end
Short end
Quoted: 2026 Post(s)
Liked 1,096 Times
Worse yet, that $660 hex set is in SAE sizes so, after paying that absurd price, you will find they don't fit your bike's bolts.
Quoted: 1303 Post(s)
Liked 1,911 Times
skullhead,
Try the Silca web site, or even look to Lowe's, Home Depot, for the set you need. Smiles
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Harbor freight has a Metric/ASE set
https://www.harborfreight.com/hand-t...-pc-63167.html
PRODUCT OVERVIEW
The ball end on these hex keys make it easy to reach hex fasteners from an angle. Each wrench in this hex set includes long (ball point) and short (standard hex key) to handle a variety of jobs.- Sizes: SAE: 1/16 in., 5/64 in., 3/32 in., 1/8 in., 5/32 in., 3/16 in., 7/32 in., 5/16 in., 3/8 in.
- Metric: 1.5mm, 2mm, 2.5mm, 3mm, 4mm, 5mm, 6mm, 8mm, 10mm
- Chrome vanadium construction
- Offset PVC grips for high torque
- Includes sturdy steel display stand
PRODUCT OVERVIEW
Quoted: 2604 Post(s)
Liked 1,933 Times
Just MHO, but I'd rather have Park quality than Harbor Freight. And when I really need to lean on a wrench to deal with a corroded fastener, my delicate, white collar hands surely do appreciate the plastic handle!
Half way there
Quoted: 986 Post(s)
Liked 880 Times
I have a set of the Harbor Freight ones at home, but use the Park ones when I volunteer at the bike coop. No difference in performance as far as I can determine. Both fit socket heads tightly and seem to be tempered properly. Sixty bucks extra for blue handles?
Quoted: 1572 Post(s)
Liked 643 Times
If I wanted to improve the Park Tool wrench set, I'd color code the handles. Then I'd add a set of combination end wrenches in the same colors.
Quoted: 836 Post(s)
Liked 1,061 Times
Quoted: 336 Post(s)
Liked 309 Times
Are you looking specifically for a p-handle? Every set I have ever seen has a plastic handle.
Do you want a set of t-handles? Sliding T? I have a full set of Beta sliding t-handles and they are great, but you have to pay the price (they are an Italian brand).
https://www.amazon.com/Beta-951-S6-T...dp/B00FI17CS4/
Anything from Bondhus, Beta, Wera, or Wiha will be better than Park or Harbor Freight. I am pretty sure that the Silca set is rebranded Beta.
I have two sets of these Craftsman metric wrenches. The 7 piece set ranges from 2.5 to 10mm. The older set is probably 10 years old, made in USA and has seen heavy use. Still going strong, with very little wear on the tips. The newer set is going on 3 years with occasional use as a backup. Made in China, and it shows. 5 and 6mm short tips both have significant wear and are starting to loose their ability to torque properly on anything but clean, deep socket heads. Too bad.
your ticket is at will call
I've had numerous sets of low/mid level, big box store, hex-wrenches and they are all pretty much the same...junk. The tolerances aren't tight enough, and they end up deforming the bolts.
I'm using Wera now, https://www.kctoolco.com/wera-073593...-key-clip-set/ and they are fantastic. While I do (slightly) miss T-handles, the quality more than makes up for it. And the color-coded sleeves makes them easy to identify
I then have Wera hex-sockets that I can use on my torque wrench, or to throw on a separate T-handle, if needed.
