Spokes creaking?
Spokes creaking?
I have a mountain bike with 26 Fulcrum Red Power XL wheels. Since I had a kid, sometimes I attach a kid seat to the bike and go on some easy paths at relatively low speed. I also use this bike to get my son back from the school twice a week. I've been doing this without problems for 1.5 years. I weight 74kg and my son weights 16kg.
Today, however on a 9km ride I did with him, I noticed rhythmic creaking on the rear wheel. Especially when climbing, but also when coasting downhill.
I supposed the spokes would be loose, but it's not the case. Is it possible that the rims can't withstand so much load? They're 24 spokes with a 2:1 lace pattern and never given me any problem. I have always been very carful when carrying my son and always go really slowly over bumps (not only for the wheels, but also to avoid him hitting the rear of the saddle).
Is it possible that the wheels can't withstand occasional use with a child seat?
The wheels are designed in a way that the spokes don't touch each other when they cross. So that's out of the question too.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Stuart Black
Old School When It Wasnt Ancient bikepacking
Stuart Black
Quoted: 4208 Post(s)
Liked 3,875 Times
Placing a small drop of thin lube on each spoke nipple/rim hole contact will eliminate that potential source, at least for a little while.
I somewhat disagree with Stuart though. The wheel described is way wrong for the use the bike is seeing and baby seats add a lot of load and leverage. Too few spokes IMO. Perhaps that 1.5 years of trouble few use was the wheel's "lifespan" in this application. Andy
AndrewRStewart
AndrewRStewart
I thought slowly and carefully riding with him wouldn't be worse than riding hard alone. Maybe I was wrong.
I have inspected the rim and hubs and couldn't find any crack. So I'm not sure what else to do...
Really Old Senior Member
Pluck the spokes.
They should all have the same tone per side.
Quoted: 1324 Post(s)
Liked 927 Times
Yes. I understand the wheel is not ideal for this application, but it's an old mtb and I couldn't justify buying a new bike or rim just for carrying my son. I plan on replacing the whole bike when my son grows and I have time to ride again anyway. I wouldn't have mounted the seat on a bike I loved.
If you don't want to spring for a new wheel with more spokes then I suggest you check out a bicycle co-op near you to see if they have one. You might also try a local bicycle shop to see if they have a slightly used wheel that someone has upgraded from.
Check your existing wheel very carefully for cracks and also check the sidewalls of the outside of the rim to make sure the rim isn't worn almost to the point of failure.
Cheers
If that wheel fails when your son is on the child seat what do you think will happen?
Cheers
Cheers
I've checked the rim and everything seems alright. This is what's driving me nuts. I'm thinking that maybe I'm going to fit a longer seatpost (otherwise I'm not going to fit on it) on my wife's bike and use that instead since it has 32 spokes wheels. Fitment won't be perfect even with a longer seatpost, but considering what I do when carrying my son, I don't think it will matter.
Liked 927 Times
How much does your son weigh?
Cheers
Cheers
Quoted: 18378 Post(s)
Liked 4,512 Times
Are the wheels reasonably true, and the tires without flat spots?
15 or 16kg. Not sure of the exact weight, but no more than 16 for sure.
Tires are new from a couple of months ago and have been ridden less than 200km. No flat spots. Wheels are perfectly true.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Liked 927 Times
Take the seat off the bike and ride it to see if the noise stops. It might be that your son moving in the seat a bit that's causing the creaking. I'd go over every nut and bolt on the child seat to be positive nothings come loose or cracked at a bolt hole.
Cheers
Cheers
Liked 2,568 Times
As soon as the kid is sleeping I'm going to disassemble the entire wheel just in case I'm missing something...
Liked 4,512 Times
It is not uncommon for some popping to occur after truing wheels. That will go away after a few rides. It can be minimized with stress relieving or unwinding spokes (unwinding is easier for flat spokes, but it has been suggested marking them before truing. You might be able to also unwind by feel.
I'm not sure if bad bearings will also give a crunchy sound?
I loosened the bearing preload adjuster and set it again. I have ridden the bike hard and there was no noise even when I tried jumping on the pedals.
I'll have to try again with the seat mounted and my son on it, but I think that the only thing that has changed is that he's probably heavier. Maybe this is the limit for 24 spoke wheels... I rarely use this bike now, since I don't have much time and mainly ride a road bike to commute once or twice a week, so I don't think that something has worn down or broken.
you should be able to find a used 32 or 36 hole 26in medium quality rear rim for not much money, and would take care of any concerns for pulling your son around, and the wheel will be much stronger than what you have.
Here in the city I live in in Canada, its not hard to find an "old" 26in wheel that would be in fine shape.
an option anyway.
re creaking--as mentioned, very carefully inspect all the child seat mounting brackets for hairline cracks etc, creaks are often a sign of metal stressing. I once had a car that made a creaking sound until one day the front wheel tie rod arm broke going maybe 40kph, wheel turned outwards and it was a sudden screeching stop....I say this given as a dad, I'd take a serious look at everything mounting wise.
good luck finding source.
could you ride past somone knowledgeable enough so that they could try to pinpoint where its coming from, or they ride beside you on a quiet street etc?
an option anyway.
Quoted: 25 Post(s)
The places to look when hunting (hairline) cracks are those where material is stressed most. Leverage effects. Mounts of longer parts that are loaded at the end farest away from the mounting point. The metal on those mount points undergoes an increased force due to the leverage.
One way to make hairline cracks manifest themselves is by pushing/pulling parts. Once I discovered a hairline crack due to a surface being wet. Hairline cracks swallow water when opening, and spill it out when closing (push, release), making them visible.
I'd say a mount place of that kid seat is the biggest suspect here. Check first the one(s) where the kids weight has the biggest leverage on. 16 kilo is quite a weight that sits on quite a distance from the rack.
As "safer" test you could fix a dead and concentrated similar weight (alike halter discs) in the seat, due to the mass concentration and low location leverage is least and no movement of the load. See if that makes a difference.
