Campy ten speed cassette on 11 speed wheel
Old 12-08-19, 07:53 AM
Thedavidimage
I am trying to install a veloce campagnolo ten speed cassette on a new fulcrum 5 wheel. The last cog barely fits on but the lockring does screw on. Is this normal? Is there something wrong? It doesnt seem like it is a secure fit. Not that i plan on spending much time on the last cog as an out of shape 63 yr old cyclist .
Thedavidimage is offline
Old 12-08-19, 10:47 AM
alcjphil
alcjphil's Avatar
Quoted: 1819 Post(s)
Liked 1,693 Times in 974 Posts
Campagnolo uses the same freehub body for 9,10,11, and 12 speed cassettes. Fulcrum is a wheel brand made by Campagnolo
alcjphil is offline
Old 12-08-19, 10:55 AM
DaveSSS
Bikes: Cinelli superstar disc, two Yoeleo R12
Quoted: 1097 Post(s)
Liked 559 Times in 446 Posts
As long as the splines engage, it sounds normal. The lock ring should have several turns of engagement. If not, then something might be wrong. As noted, 9-12 speed cassettes all fit on the same spline length.
DaveSSS is offline
Old 12-08-19, 03:48 PM
jadocs
jadocs's Avatar
Quoted: 942 Post(s)
Liked 527 Times in 349 Posts
No that does not sound right. Do you have too many spacers on there?
jadocs is offline
Old 12-09-19, 06:12 PM
zacster
Bikes: Kuota Kredo/Chorus, Trek 7000 commuter, Trek 8000 MTB and a few others
Quoted: 22 Post(s)
Liked 464 Times in 365 Posts
Put the lockring on and put the bike on a stand of some kind so you can spin and shift. Align the derailleur with the smallest cog on the last click and remove cable slack, and then see if it shifts up OK within reason, meaning it doesn't glaringly skip a gear or get stuck somewhere. Use the Park Tool method to align if you wish a full presentation of how to do this. If all works OK you should be OK as long as the lockring is engaged. If it looks OK then fine tune using the Park method.
zacster is offline
