Top tube dent repairable?
ambulatory senior
Quoted: 1956 Post(s)
Liked 3,662 Times
This is a 72 paramount frameset. Just wondering if there is any way to ameliorate this dent. I dont have the bike yet.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
He'll ask for pix and dimensions (or just send them with the email). He was confident he could remove the dent from my Voyageur SP. It still makes me sick to think of that dent.
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
Yes, with the correct "re-forming blocks", greased up, clamped in a well-anchored vise and then plenty of elbow-grease applied. But you will lose some paint. Another approach (may work fine since a dent in that location usually is strictly cosmetic and will not affect frame alignment or performance): just remove the paint in and around the dent, fill with your choice filler (I like epoxy putty, sand down until perfect and touch up/blend paint, or cover with a painted band, bar or graphic...a matter of personal choice and style.
Likes For unworthy1:
ambulatory senior
Liked 3,662 Times
Thanks guys. Looks like the paint sucks there anyway.
Likes For Chuckk:
Quoted: 350 Post(s)
Liked 276 Times
I’ve wondered if a stud welder and dent puller (think auto body shop) would work?
Likes For Chuckk:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,803 Times
I have aluminum frame blocks to use for this. A hardwood block cut through with a Forstner bit then cut in half would do the trick as well. It won't completly remove the dent, but will minimize it, make the tubing round first, then fill what rolling the dent won't.
Likes For gugie:
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Repairable? Certainly.
Worth the cost and bother? That's up to you.
Likes For JohnDThompson:
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
I've rolled the dents with aluminum frame blocks on a couple frames now, with mostly satisfactory results. The dent won't go away completely, but with a little JB weld as filler carefully feathered, it disappears under powdercoat.
Likes For Hudson308:
Quoted: 569 Post(s)
Liked 589 Times
I have seen and now own a head tube rolled by Andy Gilmour and then brazed to fill and it is perfect, not cheap but for many frames in my opinion they are worth it, beyond $ and ¢.
Likes For easyupbug:
Liked 5,803 Times
If the frame were going to be repainted anyway, fixing the dent is a no-brainer. If not, it's an expensive cosmetic fix. If you're handy with an aerosol spray can, you could do this as a DIY project.
I fill dents when the frame is getting other work - repairs, 650b conversions, etc. If you're powder coating, I use silver or brass to fill the dent on the recommendation from Groody Brothers. They've found that sometimes epoxy based filler outgasses when you're heating up the frame to powder coat temperatures.
- Roll out the dent as best possible - see the link Chuckk posted above. As noted before, you can make frame blocks out of hardwood and a forstner bit. It won't be quite as good as aluminum frame blocks, but it's a zero cost option for people with a few woodworking tools.
- Sand inside the dent and around it to bare metal.
- Fill with JB weld, or some other epoxy based filler. Let it harden per instructions (typically a day), carefully file then sand down flush.
- Generously sand around the damage
- Primer
- Paint
Likes For gugie:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
Keeping something like a '72 Paramount as a beater can be a good thing...
Likes For SurferRosa:
ambulatory senior
Liked 3,662 Times
You guys are inspiring. When i pick it up i will post more pics. I want to set this up as my around town bike. It is coming with honjo fenders and an old schwinn saddle bag. Nitto north road style bars as well as the original seatpost, crank and a brooks.
Currently set up as a three speed
Serial no.
Bag
Serial no.
Bag
ambulatory senior
Liked 3,662 Times
ambulatory senior
Liked 3,662 Times
- Primer
- Paint
Likes For daviddavieboy:
Groupetto Dragon-Ass
Quoted: 415 Post(s)
Liked 787 Times
Doesn't have to be powder coat, paint works just fine. If the rest of the paint job is acceptable, you can even paint just the tube between the lug edges.
A buddy did that to a Schwinn which we rolled that somebody had wacked along the top tube five or six times.
Testors orange spray matched exactly, and you can't tell that it ever looked like a zipper.
framebuilder
A wood block is one of the basic tools every frame builder needs to own. It is how you hold a frame while working on it in a vise. In the picture on the left is the 1" wood block I use when a frame building class student is holding something to be brazed. Often their beginning torch handling skills lets the flame wander way off target and the wood block can suffer. The next block is for them when they are filing. Old broken-in blocks have just the right amount of stickiness to hold a position but still able to move without changing the vise clamp pressure. The 3rd from the left is my personal one I usually put away when students come so it doesn't get more damaged. The aluminum one I bought from Paragon Machine Works.
If I am taking out a dent, I start with the wood blocks that are a bit more forgiving. After that I use the aluminum one to get it as round as possible and finally I add some silver that isn't designed for strength but will fit a dent nicely. I got it from Cycle Design. When I was learning to build frames in England many years ago we often got frames in for repair and repainting and it was common we would fill dents with brass (actually bronze but in the States we call is brass).
Likes For Doug Fattic:
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
If you're doing a restoration on a premium or historically significant frame (like a Paramount), then by all means have a frame builder fill the rolled remains of the dent with silver or brass. It's the best way to fill a dent in bike frame tubing, period. That's what I did with my '29 Cyrus-Great Western.
However if you're working on a budget to get a decent classic frame presentable again, you can indeed use JB Weld under powdercoat (or paint). It holds a static charge like metal, and holds up just fine to the 400 deg. F used for most powdercoating.
I've done a couple of frames this way with very nice results. More importantly, my powdercoat guy has done dozens. He's also filled sizeable dents in motorcycle tanks this way as well. I don't know what type of epoxies Groody Bros. has had trouble with, but I haven't seen any.
Liked 5,803 Times
I don't choose to disagree with you lightly, Gugie. You're a world-class craftsman in my book, and you're one of the few guys who are actually doing this stuff.
Liked 5,803 Times
Likes For gugie:
ambulatory senior
Liked 3,662 Times
I'll order some blocks and get it in a little better shape than it is now. Ty everyone!
