ISO and for trade thread part 5
#1526
Industry guy
Sorry, didn't mean to offend.
as this was supposed to be replied in a private message.
#1527
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
#1528
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
For a co-worker's bike: I have a Shimano SL-BS50 for the LH (front, triple) but
need a RH 7SP barcon unit (Ultegra or lower level is OK).
If she'd get comfortable with fiction shifting this would be a simple deal, but...
I could also make a Rivendell bar-end "pod" for the RH side work (with a shift lever that I am pretty certain to have somewhere already) so that's "plan B" (or maybe plan A-2)
I have a ton of parts for trade, just send me a list!
#1530
Bikes: 1970 Schwinn Continental, 1972 Schwinn Sports Tourer, 1981 Schwinn Paramount, 2011 Polygon Helios 700, 2015 Giant Defy Advanced Pro 0
Quoted: 36 Post(s)
Anyone interested in swapping their SR chainrings for my NR? My NR are 144bcd in 49t and 42t. I’m after a small and a big SR, but not that fussy on actual teeth.
Happy to add other odds and ends if you don’t think it’s a fair swap (have mismatched Campy headset, BB, seatpost etc parts that need a home, for example).
#1532
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
Also, I was looking for a trade, not a sale.
My Bikes
My Bikes
Likes For Andy_K:
#1533
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,529 Times
Well, I reached N, for about a minute; it was nice.
ISO a1995ish Trek 520, size 17"/48cm, preferably in that awesome dark forest green. 520's (of any era) are hard to find, small sizes are mythical. Still, can't hurt to ask.
EDIT: Okay; after further research, a mid-to-late '90s Trek MultiTrack 790 would possibly be better. The big difference between the two at the time was the MultiTrack takes wider tires. Yes please. Willing to pay.
EDIT AGAIN: eBay FTW! Got myself a '95 750 for $126!
ISO a
#1534
Bikes: Bianchi San Jose - Di2 Alfine, 1985 Eddy Merckx Corsa Extra, 1984? Miyata TerraRunner, 1986? Miyata 1000, 1988? Fuji Opus III, Nishiki International
Quoted: 49 Post(s)
Liked 8 Times
https://www.ebay.com/itm/Trek-520-vi...EAAOSw-RFcb54c
Just came up on my routine search. Definitely not in the best shape. But a fun project.
#1535
Happy banana slug
Liked 1,529 Times
Blue, 48.x cm/19"
#1536
Quoted: 36 Post(s)
#1537
Liked 4,395 Times
#1538
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
@cudak888
I think that's knurled, unless there's some depth limit where it's called cross-hatch.
#1539
Liked 4,395 Times
@cudak888
-Kurt
#1540
The dropped
Liked 1,014 Times
Yes
Edit:
With the benefit of a larger monitor and picture, the pinarello headset you shared does not have the pattern cut or rolled into it. My guess (and it's a guess until I have the benefit of a headset production specialist to educate me) is that the design is part of the die used to forge the cups. Verdict: NOT KNURLED.
Edit:
#1541
Want to trade: a 700 fender set( alloy fenders only) for a 650b set. No hardware needed.
Thought I would check before I do something crazy...
#1542
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
#1543
Liked 4,395 Times
I have these Dura-Ace EX chainrings (on this crankset). I want to trade the rings *only* for the earlier first-gen Dura-Ace/600 style rings (would consider black/drilled too). Teeth aren’t perfect, but I don’t expect perfection in return either.
These are the rings I want:
or
or
#1544
Quoted: 7348 Post(s)
Liked 2,470 Times
Isn't the circumference the same for 700c and 650b? That's the point of 650b conversions.
#1546
multimodal commuter
Liked 574 Times
The thing is, if you make them wider, you reduce the radius.
Your fenders have a rolled edge, right? So measure the space between the two rolled edges, and cut yourself a little stick of wood (like a pencil stub or something like that size) a little longer than that that measurement. So if the fender measures 42 mm, cut the wood to 45 mm.
Use a twisting motion to jam it between the rolled edges at one end of a fender, then slide the the stick along between the rolled edges all the way to the other end of the fender, pressing the rolled edges apart as you go. Make a couple passes, it should get easier the second pass. Your fender will now fit a smaller wheel.
You may have to repeat that process with successively longer pieces of wood before you get to the right size. Whole process should take just a couple minutes. Don't overdo, if you go too far,undoing this isn't so easy.
Edit, lest I go off topic:
ISO old 36h track bike hubs. This is for a bike from the 40's or early 50's. American or English stuff (Bayliss Wiley, BHC, Philips, etc), would be great, but I'd consider French, Italian, German, whatever.
#1547
Liked 4,395 Times
The ideal headset would be similar to the Pinarello headset, but with Bottecchia lettering (I believe the same model of headset was rolled with whatever name a manufacturer wanted on it), but since that's next to impossible, any period-looking headset with the right vibe would do.
-Kurt
#1549
Keener splendor
I might have the old style rings. If I haven't checked by Wednesday, send me a pm.
#1550
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
A set of milled and drilled Rino rings would look pretty good in a pinch.
