Hydration Practices and Techniques
#51
just another gosling
Quoted: 3886 Post(s)
Liked 1,938 Times
Will do. I want to be sure I read it correctly. I think I found it a couple of weeks ago. Unfortunately I was using Firefox, which I have set to privacy mode by default, so it deletes my history, etc., whenever I finish a browser session.
If I'm recalling correctly it also theorized that pickle juice may work, but not for the reasons attributed to it. People who claim miraculous results from pickle juice say it works almost immediately. That would seem to exclude electrolyte balance as a factor. So that shoots down my theory that it's just the brine and vinegar. So the theory seems to be it has some effect on the nervous system.
But I may be conflating two or more different studies. So I'll try to backtrack and bookmark those studies if I can find 'em again.
I carry my pickle juice in 6 oz. Hammer flasks, and use my own pickle juice or buy in bulk.
Here's a pretty good article about the causes of muscle cramps and the relief from same: https://runnersconnect.net/pickle-juice-muscle-cramps/
You can also take pickle juice prophetically. Gives some advance protection, but not sure why.
Results matter
Results matter
#52
Bikes: Shmikes
Quoted: 10165 Post(s)
Liked 5,856 Times
It works because of the taste. Mustard and the original mint-flavored 500mg Tums work the same way. Other Tums don't have the exact right taste and don't work. But that's why it works immediately, easily within 2 minutes. Some riders carry fast food mustard packets instead of pickle juice. Works. You can now buy small bottles of pickle juice in bike shops. There's also a commercial variant called HotShots, which is also a taste-based variant of pickle juice. Also works.
The taste-shock thing is a fascinating idea. The brainstem, where a whole fish brain still functions in us, is full of funny, atavistic, crosstalk between basic systems, like maybe acid detection and motor control.
#53
Quoted: 3241 Post(s)
Liked 2,512 Times
Mustard has tumeric in it. Tumeric does something in the fight against cramps.
#54
Non omnino gravis
Heat training. Go out in the hottest part of the day, every time. There's a silly thread on BF somewhere about ride early, beat the heat. Heat training is the best training you can do, even for when it's cool. But that's what one does. One has to acclimate to heat, just like acclimating to altitude. That's a good simile. Your body changes. We're very, very adaptable creatures. Drink plenty while you're out, it's not torture, just get your body to practice doing the right thing. And look up "heat shock proteins." You can also sauna 5 days/week and get a similar effect. That's the Finnish secret.
#55
Bikes: 2020 Trek Emonda SL6, 90's Vintage EL-OS Steel Bianchi with 2014 Campy Chorus Upgrade
Quoted: 452 Post(s)
Liked 162 Times
...to a point. It is currently 109Ί outside, with a nosebleed-inducing 6% humidity. We're in an Extreme Heat Advisory until 9pm tomorrow. I would not recommend to anyone that they should go ride right now. There's nothing to acclimate to out there. You have to severely moderate your intensity, 50oz of water won't last an hour (might not last half an hour) and with such a low RH, there's no real way to gauge how much you're sweating because it's evaporating so quickly. Riding outside of where I'm sitting at this moment, at anything beyond a soft pedal, is physically dangerous.
What do I not understand here. BTW, in the context of me (OP) and this thread 50 oz. of water per hour is not all that much.
dave
#56
Non omnino gravis
Basically, you just won't feel very hot. The evaporative cooling effect is working as well as it possibly can-- and without noticing any changes, you can blow your electrolyte balance and overheat your core pretty quickly. This I know from unfortunate experience.
The mention of 50oz of water is because of what I call "unsustainable cycling." Even severely moderated, water requirements for this heat will exceed 2 bottles per hour. So what do you do? To prove you're a hardman, do you stop at a convenience store every 45 minutes to fill up with water? Do you just ride laps around the house so you can refill as often as is needed? Any day where 2 bottles won't last an hour, it's just not worth riding. There are no awards, no bonus points for it. It's suffering for the sake of suffering.
Bottom line, if you're cycling for recreation, there is absolutely zero reason to be out there when it's 109Ί. Two years ago the Redlands Bicycle Classic was unseasonably hot for the first 2 days of the competition-- so much so that attrition due to heat-related illnesses took out about 20% of both the men's and women's fields, and temps were only in the mid-90s. So the following year they moved the event two months earlier in the year... and the TT got snowed out.
#57
Liked 1,938 Times
Ever take sauna? I've done in 100°C.
Start small and pay attention.
Results matter
Results matter
#58
Bikes: Shmikes
Liked 5,856 Times
#59
Quoted: 452 Post(s)
Liked 162 Times
dave
#60
Bikes: Shmikes
Liked 5,856 Times
Good question. No idea. If natural selection optimized us, it should be a wash, no?
#61
Liked 1,938 Times
LOL. It was fine in Preview mode . . .
Results matter
Results matter
#62
Bikes: 1979 Raleigh Team 753
Quoted: 3374 Post(s)
Liked 371 Times
#63
Liked 371 Times
I've said this. You don't have to drink it. You have to have it. But pours over you it can do a lot of thing faster than your body can.
#64
Quoted: 18883 Post(s)
Liked 10,646 Times
Is this only true in low humidity environments? I've suspected the bold text for years based on my own experience. Never in as much humidity as an east coast summer.
#65
Quoted: 452 Post(s)
Liked 162 Times
1) I was not uncomfortable even if the temp was 100 degrees
2) I was not wet with sweat
3) I went through water like crazy.
And I wondered if I actually drank more water under those conditions than I would have back east doing the same thing (dripping wet).
dave
#66
Non omnino gravis
As someone who has spent his entire life in the same inland desert, and is 100% heat-acclimated, I stand by what I said before: unless someone is paying you to pin on a number, there's no reason to ride in extreme heat. There's no reward.
Two weeks ago, I set out to do 166 miles, knowing full well that I would spent at least part of that in temperatures above 100Ί. And I did. I drank over 9 liters in 9 hours, spent 3 hours above 105Ί (peaking at 117Ί) and cut the day short at 140 miles.
I felt fine enough, I paced it well, I dressed appropriately... but it took about 4 days to properly recover. I gained no weight, so I sweat out at least 9kg of water, and it never dripped down my face once.
The only reason the extreme heat didn't win that day is because I absolutely know how to pace, and what to look for body-wise. But it was dumb. I shouldn't have done it at all.
Ride early or late. That's what I mostly do. I try. Sometimes, going against my best interests is just what I do.
#67
Quoted: 452 Post(s)
Liked 162 Times
dave
#68
Bikes: Shmikes
Liked 5,856 Times
I think the data supporting this mechanism come from laboratory studies, but the implication is that the sweat rate will be lower for a given core temp in a humid environment that allows the skin to remain wet and higher in a dry one.
#69
Liked 1,938 Times
Best to get on with the heat training. Some of the weight that one loses riding is the unbound water from glycogen stores. As long as you don't lose more than 2% of your body weight, your performance shouldn't suffer.
On rides like this, I use the "I have to pee every 3 hours" rule. If I get into a rest stop 3 hours or so after the last one and can't pee, I sit in the shade, drink water and take Endurolytes until I do pee. Then I refill and head out. I think I come out on it, time-wise.
Results matter
Results matter
#70
Quoted: 452 Post(s)
Liked 162 Times
It's good that there are so many water stops. I use a Camelbak for stuff like that because it's so much easier to drink from it, thus I do so more frequently. I fill mine, then stop less frequently. I climb a little more slowly while it's full, but save much more time with fewer stops.
dave
#71
Liked 2,512 Times
The marathon training team has scales on the long weekend run. The newbies have to weigh before and after the run. If the runner is losing more than 2lbs, they get a talking to from a coach about taking in more liquid. We have SAGs every 3-4 miles with water and Power/Gatorade. It does you no good if you are not taking enough in.
#72
Liked 10,646 Times
Seattle occasionally gets up to about 105, usually a few days at a time, a free times per summer. (I don't know if we've cracked 90 this year.) Several things have to come together for this. It's always very dry, it starts with a shift in the wind bringing desert air, and the wind always stops before it gets really hot. When you're used to 70s, that kind of heat is stifling. I've noticed it feels better on the bike, until a red light, because it's the only breeze available. Probably different where you live, but up here on those uncommonly hot days, the breeze you get from riding is the reward.
#73
Liked 10,646 Times
#74
Quoted: 4559 Post(s)
Liked 2,802 Times
But I've had a respiratory virus for a week and took only a couple of morning rides. Had to bail out early on a ride Saturday morning, couldn't seem to clear my lungs. Tried again Monday morning but wimped out after 23 miles.
I was worried about losing my heat adaptation, since it's a fickle thing that needs to be refreshed regularly. So I've been soaking in a hot bathtub of Epsom salts for an hour or so, hot enough to be uncomfortable without skin damage. When I finally stand up it sure feels like the onset of heat exhaustion. But it's good for what ails me.
#75
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,057 Times
There used to be a cycling myth that doing long rides on hot days with no water would "toughen you up". The "no water" part is definitely BS, but as long as you stay hydrated, riding in the heat really can "toughen you up", in lots of ways. And heat is something that, the more you avoid it, the lower your resistance to it becomes. I really need to face it head-on, in order to learn to deal with it on the bike. And the adjustment to heat is a profound one, that happens at the cellular level. There are probably a lot of health benefits too, but the phenomenon is still being studied in humans.
At the practical level, if deliberately subjecting yourself to hot weather rides helps you adjust to the heat better, even on days when you don't ride, why not? Anything that makes a ride more difficult improves the training benefits obtained, heat is just one more stresser, like pulling a 40 lb weight behind your bike. It WILL make you stronger over time as you work to overcome it.
Unless you give up riding completely during hot weather, I think it's to a rider's benefit to adjust to it, and deliberately exposing one's self to the worst of it, is the best way I know to achieve that goal, plus other health benefits still being studied.
