Longer ISO/Italian Bottom Bracket?
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 983 Post(s)
Liked 632 Times
Months after: crank-retightening-retightening
...and using a Token brand Italian thread bottom bracket (yeah, via Amazon), 70mm shell and 111mm spindle length (just rechecked), and the Avocet cranks. Worked but squeaked.
I finally got a set of Campy cranks through a forum member. Great! I just went to install. No go. I knew the Avocets were not drawing all the way in, leaving a lot of space where the tip of the spindle was nowhere near flush with the crank arm's surface; therefore, it would draw up a bit more.
Well, just press-fitting by hand, there's perhaps 1mm clearance to the (42T) inner chainring, and clearly it will touch if I even try to tighten the mounting bolt. That's before chainline alignment checking.
So, longer spindle. I've been looking on-line looking for one. Ouch! Token's website shows two, regular or Ti, #'s TK8675TBT and TK8695TBT respectively, 115mm. Cannot find anything English-language to pick one up. Searching further afield, willing to change brands, still coming up (ahem) short. Must be ISO, must be Italian BB threads, I like the sealed bearings and I have the multi-spline Shimano-esque installation tool now. Velo-Orange only has JIS taper. Someone mentioned Origin8 but on-line I only see JIS taper too so that's out.
Gee whiz, someone must be running Campy cranks in an Italian frame and need a bottom bracket. What am I missing?
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Quoted: 1136 Post(s)
Liked 650 Times
Here's a Centaur bb on ebay that seems to match your needs. These look to be symmetrical spindles, if that's ok.
EDIT: You might be running into issues with your current 111mm because the Campy crank needs an asymmetric BB. Just a thought.
Quoted: 983 Post(s)
Liked 632 Times
While thinking it over, I recalled I had some BB spacers. Made by/for Wheels Manufacturing, sold through Velo Orange; I have one 0.7mm and one 1.8mm. Never used because, "not for Italian" which is larger diameter, slightly. I am pondering trying to Dremel-out the inside diameter on both by 1mm, that might buy me space. Furthermore, I see some place called MTB Tools that sells Italian spacers in varying thicknesses in case (a) I cannot modify these, and/or (b) I need more/different spacing to get the chainline correct. BTW, only about 3mm clearance even with the Avocets. Plenty of room on the non-Drive side.
Quoted: 237 Post(s)
Liked 83 Times
I think the Origin8 and Token are from the same factory anyways, so it's really just an availability thing. The 115mm were meant for ergopower square taper triples for seat tubes 32mm or more, or something like that, so not terribly common, and if you do pick up a Campy BB, you'll need the campy BB/cassette tool, which interestingly can also double as a freewheel tool. For some reason Shimano felt like making separate standards for all of these.
Quoted: 2338 Post(s)
Liked 2,822 Times
What year cranks are you talking?
Avocet were made by Ofmega and depending on age could be their own spindle taper see https://www.sheldonbrown.com/bbtaper.html (this also talks about JIS/ISO)
very little details as to what exactly "old" means.
84is it seems ofmega was ISO, but like campy it was not a symmetrical spindle.
I had a hard time getting an 84 ofmega crank to work with a miche ISO bb....just not long enough spindle...getting no chainstay clearance. ..and finally found an actual ofmega ball and cone BB to use
so bottom line...it is IME not a black and white thing
Quoted: 786 Post(s)
Liked 520 Times
Phil Wood would be a good option. And I do have an Italian post-CPSC Record BB if you want to go cup and cone.
-J
-J
Quoted: 983 Post(s)
Liked 632 Times
And thus seems a bit extreme.
The campy are Record/SR, not certain of year. My earlier topics describe my travails with the Avocet cranks, thus they are being replaced, and planning on keeping the Token BB but let's see.
Thanks; if the spacers don't work, it's an option.
Quoted: 983 Post(s)
Liked 632 Times
Well, today I have the new cranks on -- about ready for a test ride. I took those two spacer/washers, (0.7mm & 1.8mm), and laboriously opened them up to barely fit on an Italian bottom bracket under the fixed cup. The hardest part was holding them in a gloved hand, I could not get them stable in a vice. I now have about 3mm clearance between the teeth of the inner chainring and the chain stay. Checking chainline with thread, outer ring aligned with 4th cog (of 6). non-drive side arm comes crest to the chain stay then the drive side, by a whisper.
HOWEVER -- ran into a surprise. The "Token" brand sealed bottom bracket I installed not all that many miles ago seems really gritty. Being sealed and new, shouldn't it be butter-smooth? Not as noticeable once the crank arms are on, instead of just turning the spindle with my fingers, but the extra friction must be affecting performance. I still want to replace it but ISO Italian bottom brackets seem to be thin on the ground -- if anyone knows sources, I am interested.
Thanks, and I'll consider that.
Also, I see a wee bit of runout on what appears to be only the outer chainring (have not put a dial indicator on it yet; not sure how to attach to a bicycle!) Any idea on what to do about it? Or live with it? I guess if I don't run into grinding against the FD cage, it's a non-issue. Probably 1mm... who knows, maybe less.
aged to perfection
Quoted: 837 Post(s)
Liked 1,258 Times
A little bit of runout on the rings can be resolved with some judicious bending using you B. F. Screwdriver.
if it's way off (more than say 5 mm) then determine the cause. Are the cranks on straight ? Does the pedal spindle seem eccentric ?
There are a lot of problems with cheap bottom brackets. Many are Nt Wrth Sht. Phil is expensive and determining the correct length / offset is a bit of a fine art, but they last essentially forever and are a top quality part.
Mark Petry
Bainbridge Island, WA USA
Mark Petry
Liked 2,822 Times
snip
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
Quoted: 983 Post(s)
Liked 632 Times
Well, I just changed the BB again. Thanks to member John Irvine (who had earlier supplied the cranks) I got a nice old Campy ball-n-cone bottom bracket. Correct spindle length, so my laboriously altered under-cup washers are now superfluous. It looks like I don't even have to readjust the FD. Thinking I took about 7-10 tries before satisfied with the correct setting on the adjustable cup, but I'll consider that time well spent. Pretty smooth. I discovered that a "generic" plastic BB sleeve might come up a bit short on an Italian BB shell, so I fabricated a "spacer" (which I inserted tediously with tweezers and a toothpick, then slid in the bearings and spindle and screwed on the adjustable cup... just as I noticed the plastic sleeve still sitting on the table ).
Oddly, where I stated the riding season on sealed-bearing BB and hubs, now "retrograde" and all those are now ball-n-cone.
Anyone know how to open up a sealed BB without expensive tools? The Token brand unit that I took out feels really nasty, I wonder if there is any lube inside... manufacturing error? I'd like a look inside.
I did spend some time on the Phil Wood website, and I was tempted; but the full set-up including tool gets close to what I paid for the frame.
squirtdad
Classic & Vintage
4
09-09-12 01:28 PM
thirdgenbird
Classic & Vintage
21
02-15-12 06:30 PM
