Max Heart Rate
Bikes: Salsa Beargrease XX1, Trek Eqnuinox 9.9 SSL, Trek Madone 6.9 ,Trek District Carbon, Trek Boone7, Trek Fuel EX9.0,Trek Fuel 9.5, Trek Rumblefish Pro, Trek Remedy 9.9, Trek Equinox7, Trek District Belt
Quoted: 578 Post(s)
Liked 82 Times
Max Heart Rate
Can someone tell me why that even at the point of totally exausted, I am NOT ABLE to get my heart rate above 147 BPM..? I cant try any harder and know most people are up 175 to over 200 BPM...
Trek Fuel EX9.0 Trek Fuel EX9.5 Trek Equinox 9.9SSL TTX Trek Madone 6.9 Pro Red Project One, Trek Boone 7, Trek Rumblefish Pro, Trek Remedy 9.9, Trek Carbon District
Bikes: SWorks Stumpy, Haibike Xduro RX, Crave SS
Quoted: 514 Post(s)
Liked 12 Times
This is something, at your tender age, that you should check out with your doc. I occasionally do HIIT workouts and have no trouble getting into the 170s, other than the suffering part of it. But, I know others that struggle to get up into that zone, even though they too are hitting that high suffering experience.
Quoted: 10 Post(s)
Everyone is different... those Max HR calculators are just simply estimates of what a typical persons Max might be... How long have you been working out? When i started last Fall, i simply couldn't push my HR above 140! Looking back at my records from when i started i would have swore my Max HR was around 138! Now, 10 months later I'm actually hitting 160! I had no idea that my Max HR would actually increase like that!
Quoted: 578 Post(s)
Liked 82 Times
Quoted: 10 Post(s)
I have been riding hard for over 6 years and weigh in at 148 lbs. I mean i really haul the mail at 62 years old. I do not have no max chart or nothing, i just monitor over 1500 bike rides and not a single ride is over 147 BPM. I am in exellent condtion and also run about 30 miles per week. There is nothing wrong with me i surely dont think..
Quoted: 1069 Post(s)
Liked 788 Times
Quoted: 10 Post(s)
I guess I'm assuming you've really tried to hit your Max HR? I mean pushed yourself to the max, so to speak?
A more important number than your Max HR is your HR Recovery Rate. Might want to read up on that.
Quoted: 578 Post(s)
Liked 82 Times
I honestly dont know if i can push myself any harder without blowing up or i am just a wuss.. one or the other.. I am not trying to compare myself with any others but just currious as to why is all...
Quoted: 514 Post(s)
Liked 12 Times
Assuming you do not have any medical issues, maybe you should try pushing harder some time. Find a nice, long, and steep hill (a couple of miles), and stand up and pedal until you cannot pedal any more, don't stop, but keep going seated, stand up and pedal again within 30 seconds until you cannot do it any longer, repeat this about 5 times. If you puke, then you know you got there. If any doubts, please see your doc first. Otherwise, this will answer your question!
Bikes: 2021 Trek Checkpoint SL (GRX Di2), 2020 Domane SLR 9 (very green), 2016 Trek Emonda SL, 2009 Bianchi 928, 1972 Atala Record Pro
Quoted: 85 Post(s)
Liked 143 Times
At 58, I top out at 160 based on testing. I pretty much turned myself inside out, and thought the number would be much higher. Nevertheless, the output I was producing for vo2 max and ftp watts/kg were more than satisfactory.
A month or so back I was riding with a friend back in the Midwest. He's a lifetime Nordic ski racer and biker, and in great shape at 59. We both weigh about 160 at 6' tall.
On one bluff climb he was calling out his HR numbers as we pulled away from the group. When he hit 170, and was getting near the edge, we turned around and cycled back to the group. Based on my level, or lack of pain, I doubt I was over 150 at the time.
I'm no scientist, but if I had to guess, I'd say you have large lung capacity relative to your weight and a very efficient engine.
Quoted: 1186 Post(s)
Liked 289 Times
It's also possible you don't ride in a way that elicits your maxHR. I might see my max about once a year and I would normally need someone else around for motivation.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Could be natural variation, being not too far off the median. If your resting heart rate is also low it might be enlarged heart, aka "athlete's heart". The latter is generally benign or even beneficial, but sometimes symptomatic. You can't tell which unless there are clinical symptoms, or with medical tests.
I've always been more to the hummingbird heart end of the spectrum and have felt some envy of athletes with slower heart rates. But objectively, if the heart is healthy it makes no difference.
Bikes: Scott CR1 Comp
Quoted: 9 Post(s)
I used to be able to hit 220 no problem but my Doc did not think that was a good thing. Check with your Doc and see what he says I was told by a couple of different medical pros that how soon the heart slowed down to normal resting heartbeat after max effort was an important measure.
Quoted: 578 Post(s)
Liked 82 Times
More important than heart rate is cardiac output which is the rate multiplied by stroke volume. You may have a higher than average stroke volume.
Living 'n Dying in ¾-Time
Have you tried a different heart rate monitor? They ain't all the same.
You wouldn't happen to be on beta blockers for something like high blood pressure? BBs can hold down the max heart rate.
As far as pushing harder, I did an unsupervised, unscientific, max effort stress test on myself and had a heart attack at around the 180 bpm mark. I was 46 YO at the time. I was racing my daughter up a very steep, long hill. I'd suggest getting a supervised stress test at your age. As you are a runner, you might actually enjoy it!
Quoted: 578 Post(s)
Liked 82 Times
I have a Garmin Edge 1000 and had no idea there was range choices but its odd the machine would would be set to 147..I have HRM's for my Edge and both give same type of readings over the last year i have had the 1000 Edge
Liked 289 Times
edit: I can only get my HR to max when sprinting all-out which means pulling up hard on the bars. With a single-speed flat bar bike the technique for getting maximum power and HR would be different and would require you to be able to maintain a very high cadence. Probably easier to do on a geared bike.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4393 Post(s)
Liked 3,016 Times
Trekmogul, I think there are some basic concepts that you are not getting. Your max HR is not changed by improving fitness - it is what it is, except that it diminishes with age. The general formula MHR=(220-Age) does not work for everybody, some are higher, some are lower, but yours is in the neighborhood of 150 or so - just a little lower than typical for your age. If you are otherwise happy with your fitness, then don't worry about it.
Saved by Grace
Bikes: Only one at a time; currently a 2012 Specialized Tricross Sport
FWIW, I reach and/or exceed my alleged rule-based max HR virtually every ride. The formulas are just a generic baseline. Mine should be 164 (220-56) but I can easily stay at or above that with little conscious effort. Crusing along at 16 MPH on flat ground, no wind, will average around 145-155 at least. Cresting a freeway overpass can reach 175 and I've briefly seen 185 in the few rides since I recently got the HR monitor. Those rides were at or below my typical exertion level of most previous rides over the past 5 years, so I want to observe my HR for a while. I've never had anything remotely like "chest pain", even in my moments of extreme exertion and resulting anerobic near-death experiences. However, it does somewhat clue me into why I apparently burn through nutrition faster than others.
I'm no athlete and I'm not in great shape, but my experience so far differs signficantly from the "rules". I'm now closely watching both the HR meter and the way I feel, and if there's anything questionable I'll talk to my doc immediately. But, so far in 5 years there's been no flag raised. So much for the rules.
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
I race. Most racers don't know their max heart rate and don't care either, because it's irrelevant to their training. What matters for racers is max sustainable heart rate. Mine is 163ish, which is the average heart rate for the last 20 minutes of a 20km time trial. The highest I've seen my heart rate in the last couple of years has been 174 bpm, and it's often in the upper 160s during intervals. Note that this pertains to me; other guys have higher or lower ranges.
Don't worry about your max heart rate. Just go ride your bike.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
Administrator
Liked 2,180 Times
It doesn't. Max is max. You just weren't hitting it previously.
Quoted: 514 Post(s)
Liked 12 Times
Also, due to a (found out after extensive testing) completely harmless electrical oddity that occurs on my heart readouts, I have gone through getting my heart rate up there for imaging, and it took stair step efforts to do so.
Plays in traffic
Bikes: 1996 Litespeed Classic, 2006 Trek Portland, 2013 Ribble Winter/Audax, 2016 Giant Talon 4
Quoted: 76 Post(s)
Liked 14 Times
Wear two HRM straps.
Oh wait. That works for spoke magnets. Never mind.
