Specialized Roll 2.0 vs 3.0
I have been looking at bikes and I think I have it down to the specialized Roll. It's main use will be neighborhood riding and keeping up with the kids. I live in a VERY flat area, even if we went on a trail it would be kid friendly and very flat.
Is there any reason to go with the 3.0 over the 2.0 for this use? I am not sure if the spring suspension seat is worth it. I do like that the rear free hub could take a larger cassette if I wanted to on the 3.0 but I am not sure if I would ever need to upgrade this bike. I do kind of like the Red but I am OK with the gray or black.
I also have a local dealer (that I do not like) that has all their Trek 20% off because Trek dropped them... they are that bad. I really like the new Trek dealer and unfortunately they dropped Specialized to bring in Trek. The Verve is very similar but I think I like the Roll better and they are 25% off direct from Specialized right now.
I guess my biggest question is are the upgrade worth $225? My wife is getting a Roll 2.0 because she wants the teal color, so that made her decision really easy. I bet I would be getting a 3.0 if the teal was available in the 3.0 and not the 2.0
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,001 Times
Yes the 3.0 is well worth it. The upgrade in shifting while still very low end is a big step up from 7 speed as it is Advent and works a lot better than most modern 8 speed stuff. Plus way better braking in hydraulic brakes vs. no name mechanicals. The seatpost is not worth anything and I would replace that with a Kinekt or just a standard post.
I wouldn't recommend the Verve it uses much narrower tires and that isn't great.
Likes For kcinnick:
Clark W. Griswold
Liked 4,001 Times
Did you get your bikes yet? Thoughts ?
Hey kcinnick - did your bikes arrive? How do you like it? My wife is getting the Roll and we have the exact same dilemma that you had. Any thoughts/suggestions not that you've tried both??
Thanks,
sk.
Thanks,
sk.
I like the 3 better but I don't really need any of the features of the 3... It does shift a little less noisily, stops a little better, the seat might as well be a solid post. I don't regret either bike.
Hi kcinnick, almost a year later I came across your post while searching for feedback about the 2.0 vs 3.0. I’ve narrowed it down to those two and I have a specific question. Now that you have ridden your bikes for a year I’m curious if you still think the 3.0 is better? My specific question is, does the 3.0 handle hills any better than the 2.0?
Clark W. Griswold
Liked 4,001 Times
When you start hitting Tourney level (including the M26 and similar from others) components run don't walk to the next bike. Unless you are riding once in a blue moon because that is the only time you can actually ride I wouldn't put any money towards something that scraps the underside of the barrel. Luckily though Specialized has a sale on some stuff and for $50 more you can get a 3.0. They used to have a nicer roll back in the day but it is has slowly declined in component quality now that they have the more desirable Como which is electric and way initially the same geometry and comfortable ride as the Roll and is still upright and comfortable and might be the same geo-wise but I haven't actually compared and much prefer the old one in many ways.
Likes For Pattimom74:
Likes For hokiefyd:
Right now Specialized has the Roll 3.0 on sale for $549.99. The Roll 2.0 is still priced at $700. I am not sure how long the sale is going to last.
Specialized Roll 2.0 Low Entry
I ended up buying the Roll 2.0 on impulse because of the available colors. I am now regretting it since the 3.0 price has been reduced pretty drastically. Anybody have any advice on whether I should buy the 3.0 and try to sell the 2.0?
Clark W. Griswold
Liked 4,001 Times
Yes the 3.0 is better. In lower initial cost bikes getting the top of that range is important as they usually don't top out very high. The less you spend initially the more you spend long term. The costs gets removed somewhere and with is generally not being sensible to change the frame and fork (though Jamis does it) the shifting and braking suffer more. 7 speed came out in the mid to late 80s and 8 speed came out in the late 80s early 90s it is 2024 and we are in the 12-13 speed era so those lower tier groupsets aren't going to be great unless a modern purpose built set like Advent then you get something a little more decent.
Likes For veganbikes:
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
If the 2.0 is working for you, I don't think I'd look at changing, especially if you like the color. You can upgrade to hydraulic brakes for fewer than 50 dollars. You can also upgrade to a modern Shimano Cues 10-speed drivetrain for about 100 bucks (Aliexpress prices). For $150, you can have some pretty decent components on your 2.0 and be set for a long time. You'd likely lose more than $150 in a trade...buying a 3.0 and trying to sell your 2.0.
This recent video from Seth at Berm Peak features these parts swaps and might give you some ideas:
Just some food for thought...
Bikes: Specialized Tarmac probably 2018. Kona ***** Tonk 2015. and a coaster to ride to tennis courts.
Can't help but wonder why...I also have a local dealer (that I do not like)
why didn't you like? indifference? too agressive?
Hey OP,
I just bought my wife a Roll 3.0 low entry. It's on sale for $550 on the Specialized website
She normally asks for nothing. When we went to the bike store, she tried the Roll 2.0 and remarked "I like that bike."
Then, she stared at the Maroon Roll 3.0 and the price tag of $1200 at the LBS.
My wife usually asks for nothing, so I'm thrilled to find the bike she likes at a cheaper price than the 2.0
Hope that helps.
Hope that helps.
