Tubeless pressure?
Tubeless pressure?
The PSI on the sidewalls says 60-80, but that's with tubes. I'm a fatty so I want to keep the pressure up a little so I don't wreck the rims. Is it OK to run 60PSI? What is the lowest that you guys would recommend for my 240# weight?
2023 Salsa Journeyer
2023 Rad Rover 6
1980ish Raleigh Marathon (Vintage Steel)
2006 Trek 820 (Captain Amazing) RIP
2010 Specialized Tricross (Back in Black)
2008 Specialized Roubaix RIP
"I'm built like a marine mammal. I love the cold! "-Cosmoline
"MTBing is cheap compared to any motorsport I've done. It's very expensive compared to jogging."-ColinL
Rides:2023 Salsa Journeyer
2023 Rad Rover 6
Thread Killer
Quoted: 3148 Post(s)
Liked 1,714 Times
What size wheell and what size tire? Can’t say anything without that info.
Likes For chaadster:
700x38ish
2023 Rad Rover 6
2023 Rad Rover 6
Habitual User
Quoted: 4957 Post(s)
Liked 8,099 Times
Thread Killer
Liked 1,714 Times
I’m the same weight, maybe 5lbs more, and on my 700x35 I run 50-52/53-55psi f/r.
I’d definitely 2nd the suggestion to hit up a calculator, specifically the Silca online calculator, and start with those recommended pressures. Off the top of my head I’d guess you could easily start at 47/50 f/r, but playing with the road surface and bike settings on the Silca site would be better than benchmarking off my peculiarities.
https://silca.cc/pages/sppc-form
Quoted: 1401 Post(s)
Liked 1,886 Times
38mm tires @ 60 psi sounds good for 240 lb rider - tubed
tubeless ? I dunno (should have paid attention to ‘tubeless’ before post ughhh)
check the rear tire (sidewall) as you ride - there might still be a fair amount of deflection (even at 55-60 psi) ?
Sunshine
Quoted: 10969 Post(s)
Liked 7,495 Times
That Silca calculator claims the OP should be at 42.5f/44.5r for psi, yet I am 20# lighter and the Silca calculator claims I should be at 42f/43.5r.
- There is 0 chance that I ever care so much about PSI that I sit there and set it to .5 increments.
- There is 0 chance that my high quality pump is accurate to .5psi.
- The Silca calculator claims I should run my 43mm tires at 34f/35.5r, yet that makes for a ride that feels vague and sluggish. It simply isnt fun with tire psi that low. So I run it 10psi higher- 43ish f and 45r. The ride is still plenty soft on gravel for comfort while not feeling wobbly and vague due to lower than preferred psi.
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,472 Times
it's the ish width. 40ish sounds right it just sat a while since I used it and wanted to get a rough ides. It was fine. Thanks guys!!
2023 Rad Rover 6
2023 Rad Rover 6
Randomhead
Liked 3,699 Times
I run my 38mm tire at 40 psi. Seems fine. I'm not quite as heavy as OP though.
Quoted: 314 Post(s)
Liked 683 Times
This tyre pressure calculator will give you a good starting guide - https://silca.cc/en-au/pages/sppc-form
