Need Suggestions for Pannier Racks for Road Bike
Good news is that the frame is steel but no braze-ons at all.
I found these three on Amazon...
I can see already that the cheapest one will wiggle from side to side. The other 2 look good but I'd like to find a cheaper alternative since I'll have to also.buy panniers as well. Any suggestions?
Bikes: 2017 Co-op ADV 1.1; ~1991 Novara Arriba; 1990 Fuji Palisade; mid-90's Moots Tandem; 1985 Performance Superbe
Quoted: 390 Post(s)
Liked 572 Times
I know I could not install a rack like “Universal” on my road bike due to lack of both braze-on and threads at rear dropout.
I have used a product similar to “ThreeH” for a light load on top, but I can’t hang a pannier since there is no lateral support.
The “ROCKBROS” might overcome that problem but I don’t have any direct experience with that configuration.
Quoted: 2604 Post(s)
Liked 1,933 Times
I may get flamed for being non-responsive, but here goes anyway. Pay up front and get some good racks and good panniers. The racks don't have to be Tubus, but don't be afraid to spend some money to get good bracing (with p-clamps since you don't have braze-ons). I've been commuting for most of the last 15 years with Ortlieb panniers. Amortized over that time, the cost per year isn't too bad. If you're worried about cost, figure out what you're paying for gas and parking. I've cut my gas cost by 2/3 bike commuting (one fill-up per month instead of three), and that savings adds up pretty fast.
Your second rack (seat post mount) may be OK with a rack-top bag, but, depending on streets and traffic, you may have problems with bag sway. I've had good luck with one that looks like your first option, although I don't know anything about the materials or metallurgy of that rack. I'd feel more confident buying a rack from REI with its return policy than from Amazon.
Likes For pdlamb:
I can get this one for $20. Hard to pass up. I'm going to ride t the sellers house and put it on then and there. So if there is missing hardware or it doesn't fit I won't be out money
Cantilever believer
Quoted: 536 Post(s)
Liked 1,839 Times
Seatpost-clamp beam racks don't typically work with panniers for two reasons: there's nothing to stop the pannier from swinging into the rear wheel, and if the pannier uses a lower hook to stay on the rack there's nothing for it to hook onto. They also generally weigh a metric ton, relatively speaking. But they're good for racktop bags on rear-suspension bikes, as I have on my GT.
You say your frame has no "braze-ons"; e.g. eyelets for rack mounting. I presume this means none on the seatstays or the dropouts. As for the dropouts, Blackburn made a adapter to use the center cutout in most older road bike dropouts into an eyelet - an eBay search should readily turn some up. Mounting to the seatstays simply uses P-clamps as other have mentioned.
Quoted: 358 Post(s)
Liked 136 Times
I think your heading down the right path but you have to be looking at a better rack. The weight of a pannier and it bouncing around (With a load.) can and will wreck havoc with it. If money is tight, go to E-bay for a good deal on top rated racks and panniers.
Quoted: 540 Post(s)
Liked 416 Times
A pannier rack is NEVER supposed to mount on a seatpost and dropouts at the same time.
It's one or the other.
Your LBS will have proper name brand racks and will help you choose the one that fits the bike's geometry.
I have an Axiom DLX that does 50kg.
Wow. You seem to feel strongly about this. Why can't a luggage rack mount to a seat post and dropouts?
Quoted: 540 Post(s)
Liked 416 Times
Because it's just gripped onto the seatpost by tension.
Bikes with rear suspensions can only use pannier racks that grip onto seatposts, nowhere else, and thus, are made for extremely light loads. Any trauma to this kind of rack usually just safely twists it out of position, no harm here.
However, I've seen the haphazard chinese rack that clamps to both the seatpost and fastens the axle... on a rear suspension bike. The rider has essentially turned their rear suspension bike into a hardtail at the mercy of the haphazard rack to hold up, plus the rider is given false confidence to carry a heavier load that will succumb to catastrophic failure. Pull a stunt like this in the automotive world and you can expect lawsuits to follow.
For the bikes that don't have any bosses for the front of the pannier racks, there are seatpost clamps that add bosses for rack to properly fasten to.
Go visit your LBS and see if they'll sell you any haphazard racks. I know Axiom, Thule, Filzer don't make any for these explained reasons.
I appreciate the advice, but the seatpost end has a clamp on it. And you know this is for a road bike, right? No rear suspension.
FWIW, In my limited experience, a seatpost rack raises the weight of the load you're putting on it (compared to a "normal" rack) and noticeably changes the handling of the bike. It's a viable solution, but when I tried a seatpost rack, I hated it.
I have the one with the little mud fender on my ebike. Slight rattle or rough stuff ( curbs, light gravel) but otherwise I like it for the price. Got some cheap panniers from Public which are good enough for a grocery run.
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,530 Times
It's a 1982 (I think) Medici Pro Strada. Basically an old steel road bike. Not sure but I think the bars are too narrow for a front basket.
I still don't understand what is mechanically wrong with the rack that mounts to seat post and seat stays
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
It's definitely a racing/training bike. A nice example. The people who made it so long ago did not intend for racks and panniers. You are supposed to use a saddlebag. The more expensive it was, the thinner the tubing for the stays. So people are worrying on your behalf those will be crushed or bent or just scratched or otherwise assaulted. Or that by clamping something to them you will somehow spoil the ride by reinforcing things that are supposed to be springy.
I've had a couple of old steel road bikes with a top bag on the rear, and they would get head shake / tank slapping if I sat up straight riding hands off, especially at higher speed.
Although not everyone will agree, I say backpack.
Genesis 49:16-17
Genesis 49:16-17
Ok. Sounds good. I really just wanted something I could put on for light grocery shopping (bread at the bread store, tomatoes at the farmers market). I can probably just pull that off with the backpack I have. There are messenger bags for sale near me but I'm not convinced of the advantages.
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
Does your fork by any chance include low rider mounts? If so, you might be better off with the load low and in the front.
Liked 3,443 Times
How about something like this?
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times
The best quality one is the Rock Bros, they claim it can hold 110 pounds securely.
The others on your list are poorly made ones, they may claim X amount of weight, but like generic headlights that claim 20,000 lumens when the reality is they only do 200 lumens, these generic racks will be the same sort of thing.
Likes For rekmeyata:
FWIW...thought I'd follow up. Found a Topeak Gtx(?) Bag and accompanying rack for $40! Quite a deal. Went straight to Home Depot for P clamps for $2.
Pros...Very slick. Very easy on and off for the bags.
P clamps...worked well but a little fiddly to get on. Definitely tighten a little bit at a time. And use nylon nuts!
Cons..As mentioned on here before. The bags definitely rattle when on the bike but I think it's a fair trade off.
Quoted: 431 Post(s)
Liked 460 Times
Glad you found something that worked.
I recently played around with my road bike. Not sure if it would have made an impact on your decision.
Axiom Streamliner rear rack, mounted to the rear brake bolt and rear QR.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,220 Times
Stuart Black
Stuart Black
