fork selection help (for a 1 3/8", 25cm head tube)
Bikes: (shortlist) Cyclops, Marinoni, Mariposa, Air Firday, Pocket Rocket Pro, NWT, SLX Fuso, Claude Pottie (France) x3, Masi Team 3v, Lemond Zurich, Bianchi OS
Quoted: 168 Post(s)
Liked 34 Times
I have to buy a fork to complete (or rather as the first building block for) a very nice Serotta steel and carbon frame.
But I am confounded by how long (and even how big a diameter)I need.
The head tube is 25cm long, 1 3/8" diameter. Period.
The seller says he was using a fork with a 30cm steering tube but that he found it a bit short and so used an adapter. I would like to avoid adapters.
But still, 5cm (2") clearance seems sufficient ... (hmm, maybe not, standard stem seems to be 4cm tall. )
so, how much clearance should I be looking for once the races are installed?
the longest I am seeing on a carbon fork is 30mm.
and what's the steering tube diameter required for a 1 3/8" headtube? I have to imagine it's 1 1/8" no?
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
I have to buy a fork to complete (or rather as the first building block) a very nice Serotta steel and carbon frame.
But I am confounded by how long (and even how big a diam) I need.
The head tube is 25cm long, 1 3/8" diameter/
the seller says he was using a 30cm but that he found it a bit short and so used an adapter. I would like to avoid adapters.
But still, 5cm (2") clearance seems sufficient ... hmm, standard stem seems to be 40mm tall.
and what's the steering tube diameter required for a 1 3/8" head tube? I have to imagine it's 1 1/8" no?
thanks
thanks
Quoted: 9 Post(s)
is the 1 3/8 measurement for the bare frame measurement? if the id of the head tube is 34mm then you need a standard 1 1/8 external cup headset. you can look up the stack height from the manufacturer.
Quoted: 168 Post(s)
Liked 34 Times
"Perhaps a proof read is in order?"
sorry, it's late.
But still, there's no excuse for bad writing.
sorry, it's late.
Quoted: 168 Post(s)
Liked 34 Times
what's the longest steerer tube typical on a fork? if not, how to adapt.
OK, revised question.
having done some research and math it seems that a HS usually has about a 4cm stack, a stem is about 4cm tall and on a 25cm headtube (= 33cm) I am going to need at least 25+4+4+spacers... ~= 35cm steering tube?
Does that even exist? I've not seen one in all my searching around. (30cm seems to be the max.)
If >30cm does not exist, how does one make a 30cm work on a large frame?
Quoted: 2026 Post(s)
Liked 1,096 Times
A 30 cm threaded fork will work since the steerer need to be only the length of the headtube plus the headset's stack height. Unfortunately 1-1/8" threaded forks, and quill stems, are quite rare. For a threadless set up, yes, a 30 cm steerer won't work on your bike and you need about 35 cm.
jeirvine
Classic and Vintage Sales
17
12-08-18 10:44 PM
Cyclist0084
107
04-01-16 06:07 AM
largefarva
47
03-01-16 08:58 AM
