Waterproof gloves recommendations?
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Liked 332 Times
Who makes a reasonably priced waterproof glove? Doesn’t need to be cycling specific (Giro, Pearl Izumi) As I’d probably use it for other activities. I’ve seen some 3mm neoprene gloves that look like a maybe on Amazon.
mind you I use Cobra Fist pogies in the winter, but a waterproof glove would work great for cold spring and fall wet rides.
thanks in advance.
thanks in advance.
Showers Pass makes waterproof clothing.
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Liked 1,055 Times
Check out Dakine. They have several choices of gloves and mitts with Gore-Tex removeable liners and poly shells.
anything with GoreTex has worked well for me (lots of brands use them). if you're near a Decathlon store they usually have good options (common in EU, not so much in US... not sure where your are)
Liked 2,496 Times
Waterproof gloves are pointless because your hands will get soaked with sweat. I find that gloves is one of those items that's just impossible to keep completely dry.
Likes For wolfchild:
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Liked 579 Times
My hands get drenched in neoprene gloves. I had a pair of Nashbar wool gloves that worked well. Kept hands warm and damp. They were over 35 years old. Now I have a pair of Pearl Izumi thin synthetic like polar tech gloves. They work well. Hands get damp but not soaked and stay relatively warm.
Bikes: Yes
Liked 1,680 Times
As others mention, don't use truly waterproof gloves as they'll just get soaked on the inside from sweat (as will all waterproof clothing). Both polyester pile and wool work well, although wool takes time to dry out.
FWIW: I've never found Gortex to be very good either. While it prevents rain from getting in, it also prevents sweat from getting out. It is good in cold/windy situations, but not in above-freezing temps.
Advanced Slacker
Liked 2,571 Times
I have used gore-tex gloves for high intensity activities like xc-skiing, snowshoeing, and biking. My hands do NOT get soaked from the inside. Same is true for me for gore-tex shoes.
Not everyone sweats the same.
On the other hand, there is no way I can exercise with a gore-tex jacket, shirt, or pants.
Likes For Kapusta:
Liked 332 Times
I'm quite familiar with Goretex as I have several hunting clothes with them and a jacket I use for cycling. It's expensive and I can attest to it's not so great breathability but it's better than other competitors. Pit or vent zips are pretty much a must with a Goretex jacket.
My hands tend not to sweat much. I do want a water barrier for my hands. I have wool stuff, which I like, but it's not a water barrier.
Liked 332 Times
Primarily I'm looking to keep my hands warm and isolated from cold rain and keep a good bar grip with waterproof gloves. If they get a little moist inside from perspiration that's a trade off I'm willing to make.
Clark W. Griswold
Liked 4,552 Times
Gloves with Outdry are the way to go. Do not waste time with other gloves trust me. Outdry means you have a glove that is dry from the outside rather than a DWR treatment on the outside and on the inside a waterproof liner. The problem with Gore-Tex and similar liner style gloves is when the DWR wears out of fails eventually you have water inside the glove it won't get your hand wet but it will get cold and then the glove is pretty worthless.
I believe Showers Pass makes some Outdry gloves. Mine are Capo Lombardias (or some slightly older variant) and are fantastic and I have an older set of Mountain Hardwear gloves which are similar that worked great but they could have been a touch larger for my hands (however that was not a fault of them I bought a slightly smaller size)
Liked 332 Times
I do have some nice winter Goretex gloves but they are heavy duty and not for biking. Cabelas brand, have had them ~15+ years and are old school Cabelas quality and too warm for Spring/fall use. I remember my wife balking at the $40 price tag back in the day! Got my monies worth there.
Liked 332 Times
And some just go for Aerostich motorcycle gloves.
https://www.aerostich.com/aerostich-...it-covers.html
