What did you just buy for your gravel bike?
Old 10-18-19, 04:35 PM
  #601
jeffreythree
Bikes: '90 Schwinn Traveler(retired), '61 Bottecchia, '86 RS Maxima, '17 Jamis Renegade Exile, '92 Trek 920
Quoted: 62 Post(s)
Liked 15 Times in 10 Posts
New brake day for my Jamis. Juin gt-p 4 piston cable actuated hydraulic brakes, since I did not want to change the whole groupset for hydraulic. Wow, they are on a whole new level from the stock Lyra. First time I can lock up the front tire on the hoods.
jeffreythree is offline
Likes For jeffreythree:
Old 10-21-19, 07:33 PM
  #602
RidingMatthew
Let's Ride!
RidingMatthew's Avatar
Quoted: 296 Post(s)
Liked 11 Times in 9 Posts
Originally Posted by SalsaShark View Post
Overhauled the Journeyman this week. Installed a new Shimano GRX FC-RX600 46/30t 172.5mm crank with BB-RS500 bottom bracket. Also put on the FD-RX400 GRX 10 speed front derailleur with a braze-on band adapter. Chain is a new KMC rustbuster 10 speed eco. All new cables and full housing run internally. Also overhauled the shift levers and wheel hubs for good measure. Still running the original 9 speed Sora STI levers and rear derailleur. Purchased the 650B wheelset and Panaracer 650x48 Graveking SK a few months back
Oh, and don't forget the Cinelli blue cork bar tape.
Ready for the winter!
do you like the GRX? i think that is what I am going to put on my Journeyman. it is time for an upgrade. I have been tempted to take it 10 speed too, but I am not sure I can.
"Work to eat. Eat to live. Live to bike. Bike to work." --Anonymous ||| "late & alive > early & dead." ~Steely Dan
RidingMatthew is offline
Likes For RidingMatthew:
Old 10-22-19, 07:33 AM
  #603
SalsaShark
SalsaShark's Avatar
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman
Quoted: 30 Post(s)
Liked 36 Times in 19 Posts
I did not change the rear drivetrain to GRX, only the front. The rear is the original 9-speed Sora derailleur and both STI levers are are the original Sora 9-speed levers. I changed out the crank to the GRX 10-speed along with the front derailleur and bottom bracket. This is my rain / winter commuter, and those threaded external Shimano bottom brackets are bombproof! The GRX chainline is also pushed out a couple of mm up front, putting the chainline in a more desirable position allowing for full usage of gearing (along with the slightly narrower 10 speed chain) without chain rubbing up front - this rubbing had always bothered me with the original crank and bb setup.
I am happy with the GRX, definitely. The build quality is sturdy, and a bit stiffer at the cranks than the original setup. I am sure the rest of the lineup is nice, but. I didn't see the need to drop a ton of extra cash "upgrading" other things on the bike that are perfectly adequate for me.
If you wanted to to put full 10 speed on your rig, it is perfectly feasible, and you would also need the new GRX STI levers as well as the rear derailleur. A new 10-speed cassette would be needed and would fit on your existing wheel freehub without issue.
SalsaShark is offline
Old 10-25-19, 12:46 PM
  #604
ab_antiquo
Quoted: 44 Post(s)
Liked 23 Times in 15 Posts
After a few years it was time to upgrade from my 44cm EA70 to something wider with more flare in the drops, but still straight in the hooks so my levers weren't pointing funny directions. My test ride makes me wish I had swapped sooner.
ab_antiquo is offline
Old 10-27-19, 09:50 PM
  #605
sicknsore
Quoted: 10 Post(s)
New Pedal Day
DMR V-Twin pedal for my Spez Diverge, quite weighty but they provide lots of customization in the forms of shims and pins to clipped your feet better on the pedal. I donít use them yet, found them easy enough to clipped and unclipped just without and the platform is comfortable enough for randonneuring.
DMR V-TWIN Pedal in Nickel
sicknsore is offline
Old 11-05-19, 07:42 PM
  #606
dwmckee
dwmckee's Avatar
Bikes: Co-Motion Cappuccino Tandem,'88 Bob Jackson Touring, Co-Motion Cascadia Touring, Open U.P., Ritchie Titanium Breakaway, Frances Cycles SmallHaul cargo bike
Quoted: 102 Post(s)
Liked 16 Times in 12 Posts
Why the Juins over the TRP Hy/Rds? The Hy/Rds are excellent, well proven and way less expensive...
dwmckee is offline
Old 11-05-19, 07:57 PM
  #607
dwmckee
dwmckee's Avatar
Quoted: 102 Post(s)
Originally Posted by csrpenfab View Post
I had those 37c Terreno Zero's on my prior gravel bike, set up tubeless, and they were great mixed used tires. A bit more road oriented, but still did decent on hard packed trails.
If you like these, try the Terreno Drys. Every bit as fast but a bit more versatile and better traction on gravel. I have about 100 miles on a set of the Drys in 650b and they are really fast and offer a bit more grip in light mud/sand/gravel.
dwmckee is offline
Old 11-05-19, 10:06 PM
  #608
jeffreythree
Quoted: 62 Post(s)
I just like trying new and different things, plus they were not much more when I purchased them. $230 shipped for the pair on ebay from a US seller. Last I looked TRP's come singly and about $100 each(?). I like them better than the HY/RD's on a bike I borrowed now that I have ridden with them for a while . It even had compressionless housing, whereas mine just has the factory Jagwire LEX.
Old 11-05-19, 10:39 PM
  #609
mstateglfr
Sunshine
mstateglfr's Avatar
Bikes: '18 class built steel roadbike, '19 Fairlight Secan, '87 Schwinn Prelude, Black Mountain Cycles Monstercross V4, '89 Novara Trionfo, '18 Diamondback Syncr
Quoted: 3450 Post(s)
Liked 446 Times in 307 Posts
Are hyrd brakes 4 piston like the juin brakes you are replying to?
I bought juin f1 brakes for my recent gravel build because they are smaller, lighter, and less expensive compared to the hyrd calipers.
Trifecta right there.
The hyrds were $110 more and significantly larger in size.
They work great so far. I want to slow down and they slow me down. I want to stop and they stop me. Pretty straight forward.
mstateglfr is offline
Old 11-06-19, 07:39 AM
  #610
RidingMatthew
Let's Ride!
Quoted: 296 Post(s)
i bought brake pads one set for my TRP HY/RD calipers. I need to buy a second set to have spares ready. I also bought an origin 8 stub to add a light for winter commuting on the side of my fork.
Old 11-06-19, 06:30 PM
  #611
DarKris
DarKris's Avatar
Bikes: Giant Revolt 2 (ALUXX) (2020), Specialized Hellga (2017), Nashbar Cyclocross Bike (Soon to be on a Trainer))
Quoted: 111 Post(s)
Maxxis Ramblers in 700x*I canít believe they have it in this size* 45mm
Will they be better than the Riddlers? Hell if I know 😂
DarKris is offline
Old 11-06-19, 07:38 PM
  #612
wheelsmcgee
Quoted: 80 Post(s)
Liked 13 Times in 11 Posts
I replaced my worn 700x45 Riddlers with the 45mm Ramblers this spring...loved the Riddlers, just wanted to try something different. Both tires are great, I think for my gravel riding 45mm might be the ideal width.
wheelsmcgee is offline
Old 11-11-19, 06:57 PM
  #613
HTupolev
Quoted: 1324 Post(s)
Liked 131 Times in 86 Posts
HED Belgium+ 650b rims
CX-Ray Spokes
RS770 hubs
Applying grease to spoke nipple holes in rim...
Spokes ready, and black brass nipples
Hub logo through valve hole.
Wheels laced, 3-cross.
1569g, or 1639g with the axles.
Still need to tension and true them, but I'm waiting for a bladed spoke holder tool thingy to arrive.
I'm really bad at being a weight weenie. I set out on this build intending to make something considerably lighter than the Stumpy, but I keep making non-weight-saving choices. 32H front and rear? Brass nipples?
I just installed my bottle cages, and I used the steel bolts that came on the frame instead of the aluminum bolts that came with the cages. That was a 7g decision!
I guess I'll see where I end up.
HTupolev is offline
Likes For HTupolev:
Old 11-13-19, 02:26 PM
  #614
Smitty2k1
Quoted: 18 Post(s)
CX-Ray Spokes
RS770 hubs
Wheels look great! I'm about to put together my first set with Shimano R7070 hubs and Pacenti Forza Disc rims. I refused to pay the extra $15 for black brass nipples so I'm going black on black on black on silver.
Smitty2k1 is offline
Old 11-13-19, 07:19 PM
  #615
DarKris
DarKris's Avatar
Quoted: 111 Post(s)
CX-Ray Spokes
RS770 hubs
Nice wheel build. I wanted to get my 650b wheels re-built from QR to TA but I think I'll just buy a new set. Oh how difficult it is to find not so pricey 650b wheels with a 12mm front hub
DarKris is offline
Old 11-13-19, 07:25 PM
  #616
Smitty2k1
Quoted: 18 Post(s)
Check out the Velomine website. They seem to have good deals on wheels and even though some may be 15mm thru axles you may be able to get an adapter or different end caps.
Old 11-13-19, 08:21 PM
  #617
DarKris
DarKris's Avatar
Quoted: 111 Post(s)
Welp, thanks for the recommendation. I got these Mercury Ryde Edge M30 650B wheels for under $275 + Shipping. And 12x100mm front hub
DarKris is offline
Likes For DarKris:
Old 11-15-19, 02:35 AM
  #618
HTupolev
This is the part where I charge headfirst into what is most likely a really, really bad idea.
RX800-series hydraulic disc brifters for 1x11 mechanical drivetrain.
GRX810 (2x11) rear derailleur.
And an 11-32 cassette to go with.
A nice shiny modern Dura-Ace box...
...which, naturally, contains a friction shifter.
HTupolev is offline
Old 11-16-19, 08:49 PM
  #619
dwmckee
dwmckee's Avatar
Quoted: 102 Post(s)
Okay, wasn't sure what the advantages were. I thought the Juins were about $100 more for the pair... They do look really light and pretty sleek compared to the Hy/RDs which I think are one large cylinder per side...
dwmckee is offline
Old 11-19-19, 08:46 AM
  #620
str8jakett
I pedal in my sleep...
str8jakett's Avatar
Bikes: Giant Propel Advanced Pro 2017, Giant Propel Advanced Pro 2015, Giant TCR Advanced 0 ISP 2008, Cube Cross Race SL 2018
Quoted: 107 Post(s)
Liked 24 Times in 15 Posts
Pretty excited to get this second wheelset done.
DT Swiss R32 Spline Disc
Avid G3CL 160
Vittoria Rubino Pro All Round 700x28
Sram 11-36 (stolen from stock wheelset, going 11-42 there)
Schwalbe G One Speed All-Round 700x38 on factory wheels to replace the Panaracers Comets.
str8jakett is offline
Old 11-20-19, 05:32 AM
  #621
gequiroga
This build made me think, you could update the deraileur to the 10 speed GRX and still run your current STI and casette, so you would gain the benefits of a clutch derraileur.
gequiroga is offline
Old 11-21-19, 08:29 PM
  #622
biketampa
Bikes: 2014 Jamis Ventura Race, 2014 Cervelo P2, 2017 Raleigh Tamland 1, 2015 Jamis Trail X
Quoted: 105 Post(s)
Liked 7 Times in 7 Posts
Bought look x-track pedals. They look nice. Havenít used them yet. Waiting for my new bike
biketampa is offline
Old 11-22-19, 04:11 PM
  #623
HTupolev
New brake pad day!
HTupolev is offline
Likes For HTupolev:
Old 11-22-19, 05:57 PM
  #624
jeffreythree
Quoted: 62 Post(s)
Installed a set of Vee Rubber Speedster 26x2.125" tires today. I turned my old Trek 920 into a budget drop bar gravel bike for when I want fat tires instead of a third wheelset for my Jamis, but I have found the pickings are slim for decent, affordable, tubeless 26" gravel appropriate tires. First ride impression is mostly positive, with a bit of annoying self steer at low pressures being the only negative.
Old 11-22-19, 06:10 PM
  #625
csrpenfab
Quoted: 56 Post(s)
Liked 36 Times in 30 Posts
Today I took advantage of the REI 20% coupon to add a new Kuat NV 2.0 rack to carry my Niner to far away gravel. Iím very impressed with the quality and ease of function on the Kuat. Itís rock solid with zero wobble.
csrpenfab is offline
