I may have SLIGHTLY over inflated my inner tube
Old 05-11-19, 06:58 AM
  #101
FiftySix
I'm the anecdote.
FiftySix's Avatar
Bikes: Norco CityGlide, Schwinn "Speedster" Willy
Quoted: 520 Post(s)
Liked 320 Times in 240 Posts
Originally Posted by I-Like-To-Bike View Post
The tube (at least 16 years old) had never been previously patched and was in like new condition. . . . I expect the tube to last at least another 16 years, though the tire is due for replacement due to tread wear.
If that tube is standard issue Walmart quality, I got $10 saying it won't make it another year while riding the thing with a load on it.
If its made of some sort of better material, all bets are off.
FiftySix is offline
Old 05-11-19, 09:22 AM
  #102
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6950 Post(s)
Liked 257 Times in 211 Posts
In a certain isolated village, the barber shaves every man who doesn't shave himself. Does the barber have a beard?
Is that barber Sweeney Todd ?
fietsbob is offline
Old 05-13-19, 08:31 AM
  #103
RubeRad
Keepin it Wheel
RubeRad's Avatar
Quoted: 17 Post(s)
Liked 206 Times in 160 Posts
?? Cheap walmart tubes are like 3x as thick as expensive ones, they last longer
RubeRad is offline
Old 05-13-19, 08:35 AM
  #104
acidfast7
Bikes: 2010 Cube Acid / 2013 Mango FGSS
Quoted: 1053 Post(s)
Liked 30 Times in 25 Posts
I only use SCHWALBE tubes with my SCHWABLE tyres. Why half-ass it?
edit: Forgot the hyphen in half-ass. Corrected now.
acidfast7 is offline
Old 05-13-19, 08:37 AM
  #105
Skipjacks
Skipjacks's Avatar
Quoted: 998 Post(s)
Liked 219 Times in 145 Posts
Yeah but maybe they could tend to have weaker seams and lower overall build quality
Just because the rubber is thick enough to stop a nail from penetrating doesn't mean the seams will hold together or the valve won't separate from the rubber due to just deteriorating. Cheaper glues, lower quality assurance....all these things could contribute to higher failure rates in different ways than a thinner more expensive tube would
I don't know any of this to be true. I'm just sayin'...it could be.
Skipjacks is offline
Old 05-13-19, 08:38 AM
  #106
RubeRad
Keepin it Wheel
RubeRad's Avatar
Quoted: 17 Post(s)
Originally Posted by acidfast7 View Post
Why half-ass it?
Because half-ass = half-price?
Therefore, price = ass. QED.
RubeRad is offline
Old 05-13-19, 08:40 AM
  #107
acidfast7
If one's time has no value.
Old 05-13-19, 09:14 AM
  #108
RubeRad
Keepin it Wheel
RubeRad's Avatar
Quoted: 17 Post(s)
The more of a cheapskate one is, the less value time has relative to money. I am the cheapest of skates.
RubeRad is offline
Old 05-13-19, 11:16 AM
  #109
MadKaw
MadKaw's Avatar
Bikes: 1977 Raleigh Super Course, 1993 Trek 8000, 2016 Diamondback Haanjo Comp, 2018 Marin B-17, 2018 Specialized Roubaix
Quoted: 11 Post(s)
Originally Posted by ksryder View Post
Even more damning is the complete lack of denial that he isn't a bot.
Although, if I were programming a bot, I would program it to say, "I'm not a bot!"
Wouldn't you?
MadKaw is offline
Old 05-13-19, 11:25 AM
  #110
Skipjacks
Skipjacks's Avatar
Quoted: 998 Post(s)
Wouldn't you?
But would you? All I have to do is divine from what I know of you: are you the sort of man who would program the bot to say it is not a bot? Now, a clever man would program the bot to say it is not a bot, because he would know that only a great fool would believe the answer he was given. I am not a great fool, so I can clearly not believe you would program the bot to admit it is a bot. But you must have known I was not a great fool, you would have counted on it, so I can clearly not believe that you would program a bot to deny it was a bot!
Likes For Skipjacks:
Old 05-13-19, 11:32 AM
  #111
Korina
Happy banana slug
Korina's Avatar
Bikes: 1992 Specialized Rockhopper Sport, 2016 Giant Liv Rove Lite, 1995 Trek Singletrack 930, 1994 Trek Multitrack 750
Quoted: 510 Post(s)
Liked 136 Times in 103 Posts
@Skipjacks, and never get involved in land wars in Asia!
Thanks for the chortle.
Korina is offline
Old 05-13-19, 11:46 AM
  #112
Mr. Wiggles
Mr. Wiggles's Avatar
Bikes: Rans Stratus - Surly Disc Trucker
Quoted: 8 Post(s)
I had the exact same thing happen on my commute home one day. Made the mistake of inflating without my glasses on. Bad mistake.
Mr. Wiggles is offline
Old 05-13-19, 12:33 PM
  #113
biketube guy
Quoted: 10 Post(s)
If you want to geek out on tubes, here you go: Although this type of explosion is usually the result of a section of tube being stuck between the bead and rim, excessive pressure can force a bead off a rim, and when the tube escapes it expands and explodes. (BTW a tire set up tubeless will come off a rim much easier because inner tubes tend to force the bead to stay under the rim hook). Tires do in fact get bigger in diameter as pressure increases, but not enough to damage the tube. Factories have cost-cutting tricks to produce cheap tubes, including; 1) inexpensive additives to make the butyl rubber "go farther", 2) the extrusion process is sped up, causing the wall of the tube to vary excessively, resulting in thin spots, 3) inadequate filtering of the butyl, leaving granular contaminants in the rubber, which cause pinhole failures, 4) cheap or poorly controlled valve production resulting in rubber around the valve not galvanizing properly with the rest of the tube, which is why you see "cut" failures around there. Tubes do deteriorate over time, especially if left in the sun. Using a tube that is slightly undersized is generally not a problem if the quality is good, although if extremely undersized, you will feel the area around the valve as a *whump* when you ride, because that area is reinforced and does not stretch as much as the rest of the tube.
biketube guy is offline
Likes For biketube guy:
Old 05-13-19, 12:37 PM
  #114
RubeRad
Keepin it Wheel
RubeRad's Avatar
Quoted: 17 Post(s)
Very interesting, thanks!
RubeRad is offline
Likes For RubeRad:
Old 05-13-19, 12:39 PM
  #115
cp256
Bikes: Klein Team Super, Gios Super Record, old Peugeot beater
I was 12 or 13 when I first repaired a flat by myself. I had to walk my bike a half mile to the local gas station for some air. That was uneventful and while riding my bike home I stopped to watch a guy flying a gas powered model airplane on a tether. Around and around it screamed until all of a sudden BANG!!! and the plane augered into the ground somewhat spectacularly, with pieces flying everywhere. Of course it was my new inner tube that had exploded from being twisted and the pilot must have jerked the tether when it startled him. He and his friends were much older than I was and I realized that I might be in danger of a beating if they figured out that the explosion was from my tire. I tried to look just as bewildered as they did. I was fortunately far enough away from them that they couldn't see that my tire was flat and I was able to innocently walk my bike away from them without being accosted.
After I figured out what happened to that tube I learned to make sure freshly changed tubes weren't twisted before fully inflating them.
cp256 is offline
Old 05-13-19, 12:43 PM
  #116
RubeRad
Keepin it Wheel
RubeRad's Avatar
Quoted: 17 Post(s)
That's funny! I also started repairing tubes frequently at age 12-13 because I used a bike to deliver newspapers. I learned the hard way that you cannot have ANY amount of tube sticking out and rubbing on the frame.
RubeRad is offline
Old 05-13-19, 01:25 PM
  #117
julius rensch
Bikes: 1972 Raleigh Tourist
Quoted: 12 Post(s)
Originally Posted by Skipjacks View Post
This happened in a store once. I was there with my then 2 year old. We were next to a rack of bikes when BANG!!!! A random tube on one of the bikes gave out.
My 2 year old looked up at me, saw I wasn't scared, and just smiled and ignored it.
The store manager gave me a 10% off coupon because it DIDN'T scare the kid and make him cry.
Ironically...I was there to buy a spare inner tube that day. The same spare inner tube I will be putting on my bike in about an hour.
Welcome to the Big Bang Theory of discount purchases, Skipjacks
julius rensch is offline
Old 05-13-19, 03:18 PM
  #118
Renato GF Naso
Bikes: Atala (racer) OK, Schrade (racer) OK, Mittelholzer (tourer) not yet, Künsting (city-bike) OK, Huffy (winter-bike [spikes]) OK, Graziella (tandem) not yet.
Quoted: 24 Post(s)
Happened to me quite a few times, until...
So I'm sitting here in my office in my bike in front of my desk....everything is nice and quiet
Then BANG!!!!
Sounded like a gun went off...followed by a slow 'pffpffffftftftftftfff' as I watched my bike drop an inch and a half
My rear inner tube exploded
It's possible I may have SLIGHTLY over inflated it.
Scared the snot out of me! hahaha
Oh well good thing I keep a spare with me. Guess I know what I'm doing at lunch time.
I've got myself, later on, a pump with manometer!! (Those 'explosions' happened to me as I was a teenager, back in the 60s...)
Renato GF Naso is offline
Old 05-13-19, 05:33 PM
  #119
BadGrandma
Bikes: Surly Cross, Franklin tandem, Culprit Jr., BMX racer
Quoted: 8 Post(s)
Liked 6 Times in 2 Posts
An exploding tube is much more exciting if it blows in the church nave. (I was cleaning the sanctuary).
BadGrandma is offline
Old 05-13-19, 06:03 PM
  #120
LDBenjamin
Bikes: Schwinn Madison, Haluzak Horizon, Mongoose Brutus, Roland MTB, Sinclair A-Bike
Then BANG!!!!
The only time I had a bead failure was after replacing the tires and inner tubes on a 1960s era balloon tire cruiser. The guy at the bike shop asked me if I'd ever mounted a balloon tire before (I hadn't). He said that I should have inflated it slowly, rotating and inspecting it carefully to make sure that the bead was seating properly in the rim. Inflating it like it was a narrow racing tire won't work.
The bead popped off the rim at a high point while I was riding, allowing the tube to exit and explode with a sound like a gun going off, shredding the tire in the process.
LDBenjamin is offline
Old 05-13-19, 08:06 PM
  #121
FiftySix
I'm the anecdote.
FiftySix's Avatar
Quoted: 520 Post(s)
It's a $10 bet.
For charity.
And I'm the charity if I win.
FiftySix is offline
Old 05-13-19, 10:31 PM
  #122
I-Like-To-Bike
I-Like-To-Bike's Avatar
Bikes: Vaterland and Ragazzi
Quoted: 11 Post(s)
Liked 199 Times in 129 Posts
Yeah but maybe...
And maybe tubes sold by Walmart last 3 times longer than the name brand tube sold at your favorite LBS. Why not, it could be?
Anybody can post any sort of baloney to fit their preconception, bias or agenda without a shred of evidence just by qualifying the fabricated factoid with "just sayin' ".
I-Like-To-Bike is offline
Old 05-14-19, 12:03 AM
  #123
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 1675 Post(s)
Liked 261 Times in 169 Posts
Why would she?
This thread has become very strange.
Genesis 49:16-17
Darth Lefty is offline
Old 05-14-19, 07:39 AM
  #124
Skipjacks
Skipjacks's Avatar
Quoted: 998 Post(s)
It wasn't baloney. It was a reasonable scenario.
Saying Wal Mart Tubes fail because the glue used by the aliens who make them disintegrates in Earth's nitrogen heavy atmosphere is baloney.
Saying that cheap parts might have some quality assurance issues isn't exactly going out on a limb.
  #125
Skipjacks
Skipjacks's Avatar
Quoted: 998 Post(s)
Why would she?
"She" was the only clear way out of the riddle I could find too.
