Cleats and toe numbness
I’m experiencing some toe numbness when doing laps. What i do instead of stopping is to just move my toes during laps. I wear thick socks, no movement of the foot inside the shoes. I thought this has something to do with saddle height, coz i noticed in one lap session that there’s a bit more leg angle and i remembered i forgot to adjust the saddle height when i switched from flat to clipless a few months back. I adjusted saddle 3 times till i got to abt 15 mm, which felt perfect, but there’s still that numbness mid-ride. Someone suggested i try moving the cleats back a bit. If i do this, will this affect the bike fit and will i need to do some readjustments?
Quoted: 359 Post(s)
Liked 85 Times
This may also see you need to lower your saddle slightly as a result.
Ignore leg angle IMO. You want your saddle fore and aft set so that you are not using your quads or hamstrings more than one another.
You want to set your saddle height so that you are not rocking.
Likes For sumgy:
How far behind the ball of the foot? I’d like to adjust it 1 or 2mm at a time. It’s currently set exactly in line with the ball of the foot. Any other adjustments i may need aside from saddle height?
Quoted: 359 Post(s)
Liked 85 Times
I just slam mine back as far as possible.
https://www.stevehoggbikefitting.com...leat-position/
And a video:
https://vimeo.com/9589645
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Always found Hogg's advice a bit 'interesting' on this topic; though can't follow for myself -- my feet are too big, and the resulting additional toe/wheel overlap would be pretty significant. ymmv
Quoted: 359 Post(s)
Liked 85 Times
I get some overlap if I try, but I need to be actually turning the bars to do it, and I don't generally steer around corners too much.
Oh yeah, the toe overlap needs to be considered too. I have some toe overlap, although i haven’t experiended it yet while riding. Can i still move my cleats a bit back with this?
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Might be this. When riding, your feet can swell a bit and cause toe numbness. You don't want your shoes to be tight. I learned to start brevets with my shoes feeling a bit loose, and now I wear SPD sandals that are easy to loosen while riding. My toes are much happier now.
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,434 Times
Cleat settings that put the pedal axles right on the back of the balls of my feet are what work best for me.
Quoted: 359 Post(s)
Liked 85 Times
The only time I EVER have touched my tyre on the wheel has been at very slow speeds or stopped, as I don't generally turn corners by turning my bars.
Likes For billyymc:
Quoted: 4559 Post(s)
Liked 2,802 Times
Try thinner socks. Thick socks make my toes go numb even in warm weather -- the pressure along the top of the foot cuts off my circulation.
I don't need padding on the top of the foot so I switched to thinner socks -- mostly ankle high socks, three for a buck from the dollar store.
And to relieve metatarsal hotspots I use Profoot Miracle insoles. Best I've found. Thin, lightweight, resilient, costs only $8-$10 at Walgreens or CVS.
I also moved my cleats all the way back but that's to solve another problem. It didn't cause any circulation problems. Just arch strain and some knee twinges. Cleat position can be influenced by foot length. My feet are long and narrow, so I prefer the pedal axle roughly midway between the ball of the foot and the arch. I tried the classic position back in the 1970s -- ball of the foot over the arch, with cleated shoes -- and it caused all kinds of problems, from pain in the arches to the calves and knees. Bike "fitting" in the 1970s mostly consisted of LBS guys slavishly adhering to whatever they read in a magazine and insisting it was gospel.
Xsive
Fitting Your Bike
24
08-04-14 08:18 PM
RichardGlover
13
02-25-12 07:50 PM
